Data Sheet
Dual Range DC Power Supplies
Models 1737 & 1747
B&K Precision’s models 1737 and 1747 are
general purpose dual range DC power sources.
These power supplies can output higher voltage
at a lower current range or more current at a
lower voltage range. Two 4-digit LED displays
continuously monitor the output voltage and
current. The power supplies can be operated
locally from the front panel or remotely through
the RS-232 interface.
The 1737 and 1747 both exhibit excellent
regulation and low ripple characteristics. Their
mechanical configuration conserves bench space
and allows for easy portability.
Features and Benefits
These power supplies are well-suited for a wide
variety of electrical and electronics applications in
service shops, engineering labs, production,
school laboratories, and home use.
Low ripple and noise
Excellent regulation
Constant voltage (CV) and constant current
Two 4-digit LED displays provide
Output Ratings/Model
1737
Voltage
0-3 A (0-30 V range)
0-2 A (0-60 V range)
Dual range to accommodate applications
requiring either a higher voltage or a higher
current
(CC) mode operation
good visibility in bright or low light
1747
0 - 60 V
Current
0-10 A (0-35 V range)
0-5 A (0-60 V range)
LED indication for CV and CC modes
Automatic recall of last settings on power up
RS-232 interface
Front panel emulation software available for
download
1737 Operating Range
1747 Operating Range
Range 1
Range 2
Range 1
Range 2
60
Voltage (V)
Voltage (V)
60
30
2
Current (A)
Technical data subject to change
© B&K Precision Corp. 2012
3
35
10
Current (A)
w w w.bk prec ision.c om
Isolated output
Overload protection
Reverse polarity protection
Models 1737 & 1747
Front Panels
Rear Panels
Two Power Supplies in One
Fanless heatsink
design for quiet
bench operation
The 1737 and 1747's unique dual range
feature offers the best of both worlds by
supplying two different ranges with either
higher voltage or more current depending
on your application, avoiding the higher
cost of buying more power than necessary.
17 37
RS-232 interface enables the
instrument to be remotely
controlled via PC
Bright, 4-digit
LED displays
Voltage and current
coarse and fine control
Output terminals
17 47
LED indicators for constant voltage
and constant current modes
Software Application
Bright, 4-digit LED displays
Utilize B&K Precision’s application software, available
for download at www.bkprecision.com. This software
provides a virtual front panel and a simple data logging
function to store and log data to a text or CSV file.
Voltage and
current coarse
and fine control
2
Output ON-OFF
switch
Output
terminals
LED indicators for
constant current and
constant voltage modes
Models 1737 & 1747
Specifications
Mode l
1 73 7
1 747
Out put Rati ngs ( 0 °C~4 0 °C)
Voltage
Current
0-60 V
Load Re gul at ion ±(% o f output+o ffse t)
Voltage
0.01% + 3 mV
Current
0.01% + 5 mV
0.2% + 3 mA
Line Re gul at ion ±(% o f output+o ffset )
Voltage
0.01% + 3 mV
Current
0.2% + 3 mA
Ri ppl e & No ise (2 0 Hz ~ 20 MHz)
Voltage
1 mVrms
Current
≤ 3 mArms
Time
≤ 100 µs
Re co very Time
Me ter Resol ut ion
Voltage
Current
10 mV
1 mA
1 mA (0-5 A)
10 mA (5-10 A)
Me ter Accuracy
Voltage
0.5% + 9 digits
0.5% + 5 digits
Current
0.5% + 9 digits
0.5% + 5 digits
AC Input
120/220 VAC ±10%, 50/60 Hz
115/230 VAC ±10%, 50/60 Hz
Power Consumption
≤ 180 VA
≤ 560 VA
Gen eral
Protection
Reverse polarity, current limiting
Operat ing Envi ron ment
Temperature
32 °F to 104 °F (0 °C to 40 °C)
Humidity
75% R.H.
Temperature coefficient (0 °C~35 °C)
(?of output+offset)
300 ppm/°C
Storage Temperature
5 °F to 158 °F (-15° to +70° C)
Storage Humidity
85% R.H.
Me ch an ical Specificatio ns
Weight
10.5 lbs (4.8 kg)
30.2 lbs (13.7 kg)
Dimensions (W x H x D)
5.5” x 6.2” x 12.5" (140 x 158 x 318 mm)
10.75” x 6” x 14” (273 x 153 x 356 mm)
Two-Year Warranty
Included Accessories
Power cord, instruction manual, RS-232 cable, shorting bar
Note: All specifications apply to the unit after a temperature stabilization time of 30 minutes.
3
v080414
很抱歉,暂时无法提供与“1737”相匹配的价格&库存,您可以联系我们找货
