1686A
1686A
    B&K
    POWER SUPPLY 3-14VDC 12A
1686A 数据手册
Data Sheet 3-14 V DC Power Supply Model 1686A Model 1686A is a high quality 3 to 14 V bench DC power supply primarily designed for powering automotive and marine electronic equipment. It has a maximum output current proportional to the voltage setting (see voltage and current output graph) and two panel mounted meters that continuously monitor the output voltage and current. Designed for continuous duty without overheating, this 12 A DC power supply is an ideal car battery substitution allowing servicing or powering of mostly any car radio, car stereo, PA systems, low to medium power CB transceivers, or marine equipment. The 1686A uses thermostatically controlled fan cooling for improved heat dissipation while keeping bulk and weight to a minimum. Model 1686A Features & Benefits Specifications 1686A Voltage Current (Proportional to Output Voltage) Load Regulation Line Regulation (108-132V AC) Ripple and Noise 3 - 14 V *12 A (at 13.8 V) ≤ 0.8% ≤ 0.8% ≤ 10 mVrms ■ 3 V to 14 V variable output ■ 12 A output at 13.8 V* ■ Thermostatically controlled cooling fan Output ■ ■ Metering 0-20 V ±7% F.S. 0-20 A ±7% F.S. General AC Input Power Consumption Operating Temperature Storage Temperature Dimensions (HxWxD) Weight 115/230 VAC ±10%, 50/60 Hz 400 W 32˚ to 104˚F (0˚ to 40˚C), ≤ 85% R.H. 5˚ to 158˚F (-15˚ to 70˚C), ≤ 75% R.H. 4.9” x 8.5” x 11.5" (124 x 216 x 292 mm) 12.1 lbs (5.45 kg) One-Year Warranty Included Accessories Instruction Manual, Line Cord, Spare Fuse * see graph for output current and output voltage Connect two or more units in parallel or series for higher current or voltage ■ Convenient 2 A tie point terminals on front panel ■ Overvoltage protection, foldback current limiting, and reverse polarity protection Output Voltage and Current Output Current (A) Voltmeter Range Voltmeter Accuracy Ammeter Range Ammeter Accuracy Continuous operation at full load without overheating 20 15 10 5 0 0 2 4 6 8 10 12 14 Output Voltage (V) Graph showing relationship between output voltage and output current Technical data subject to change © B&K Precision Corp. 2014 v050114 www.bkprecision.com 16
1686A 价格&库存
很抱歉,暂时无法提供与“1686A”相匹配的价格&库存,您可以联系我们找货
