1514
    B&K
    14 电路 0.375"(9.53mm) 阻隔块 连接器, 螺钉
1514 数据手册
SPECIFICATION 1514 Description: 3.3/4.5/6/7.5/9/12VDC, 3Amps Switching Mode Power Supply Power supply AC Input: 120VAC 60Hz Environment Temperature: 25C° Rated Output 3.3V Rated Output 4.5V Rated Output 6V Rated Output 7.5V Rated Output 9V Rated Output 12V MIN. 3.1 4.3 5.8 7.3 8.8 11.8 Output Current TYP. 3.3 4.5 6 7.5 9 12 3 Voltage Regulation: Load (0-100%) Line (+- 10% variation) Ripple & Noise (peak to peak) No Load Input Current Full Load Input Current Insulation Resistance (500VDC) Withstanding Test (@ 12V, 3A) MAX. 3.6 4.9 6.4 7.9 9.4 12.4 100 75 79 UNIT V V V V V V A 300 60 100 mV mV mVp-p 60 700 mV mA M? % Operation: Plug model 1514 into AC outlet. Turn power switch on, power light will come on. Adjust control knob to desired voltage.
很抱歉,暂时无法提供与“1514”相匹配的价格&库存,您可以联系我们找货
