1510
    GLOBALSPECIALTIES
    VARIABLE TRANSFORMER 140V 15A
1510 数据手册
Model: 1510 Description: 0-20VDC 5A, 0-80VDC 10mA, 0-500Vdc 10mA AC: 1.1V, 2.2V, 3.3V, 4.4V, 5.5V, 6.6V 2A Input Voltage: 115VAC 60Hz Environment Temperature: 25C° MIN. 0-20VDC: Output Voltage Range Min. output Voltage Max output Voltage Output Current Protection Current (start point) Load Voltage Regulation (0-100%) Line Voltage Regulation Power Supply TYP. MAX. UNIT 0.8 20 1 22.5 8 2.5 2.5 V V V A A V V 50 mVrms 120 100 V V mA 800 V V mA 1.4 2.5 3.6 5.0 6.1 7.5 200 1.8 V V V V V V mA A +-2.5% +-2.5% Fs% Fs% 1 20.5 5 5 (100-130VAC Variation) Ripple & Noise 0-80VDC: Max. Output Voltage No Load Max. Output Voltage Full Load Output Current 0-500VDC: Max. Output Voltage No Load Max. Output Voltage Full Load Output Current AC Output Voltage 1 AC Output Voltage 2 AC Output Voltage 3 AC Output Voltage 4 AC Output Voltage 5 AC Output Voltage 6 No Load Input Current Full Load Input Current Meter Accuracy: Voltmeter Ammeter 90 80 10 600 500 10 1.0 2.1 3.2 4.2 5.3 6.3 Fuse 3 Dimensions (W X D X H): 10.2 x 8.50 x4.25” Weight: 12.8 LBS. Operation: Plug model 1510 into AC outlet. Turn power switch on. Select desired voltage, use control knobs to adjust output. A
很抱歉,暂时无法提供与“1510”相匹配的价格&库存,您可以联系我们找货
