291
Digital Clamp-on
Meter Amp Plus
Instruction Manual
TABLE OF CONTENTS
A. INTRODUCTION
A. INTRODUCTION
1. Congratulations ..........................3
2. Product Description ....................3
3. Declaration of Conformity ..........4
1. Congratulations!!
B. SAFETY CONSIDERATIONS ..............5
C. TECHNICAL DATA
1. Features and Benefits..................6
2. Product Applications ..................7
3. Specifications..............................8
D. MEASUREMENT TECHNIQUES
1. Controls and Functions ............10
2. Step by Step Procedures: ........13
E. ACCESSORIES ................................21
F.
MAINTENANCE ................................22
G. TROUBLE SHOOTING GUIDE ..........23
2
Thank you for purchasing TPI products. The
Amp Plus is easy to use and is built to last.
It is backed by a 3 year limited warranty.
Please remember to complete and return
your product warranty registration card.
The 291 is a hand-held manual ranging clamp-on DMM.
The 291 is an affordable choice offering measurements
in all basic electrical functions.
• Bar Graph
When measuring frequency, bar
graph indicates current level.
• Peak Mode
For start-up and inrush currents.
• Sleep Mode
Preserves battery life.
• Data Hold
Holds the reading on the display for
easy viewing.
The 291 comes complete with the following accessories:
Carrying Pouch
Test Lead Set
Instruction Manual
Battery
3
TABLE OF CONTENTS
A. INTRODUCTION
A. INTRODUCTION
C. TECHNICAL DATA
F.
2
• Bar Graph
• Peak Mode
• Sleep Mode
• Data Hold
easy viewing.
Carrying Pouch
Test Lead Set
Instruction Manual
Battery
3
3. EC Declaration of Conformity
This is to certify that TPI Model 291 conforms to the
protection requirements of the council directive
89/336/EEC, in the approximation of laws of the member
states relating to Electromagnetic compatibility and
73/23/EEC. The Low Voltage Directive by application of
the following standards:
EN 50081-1
EN 50082-1
EN 61010-1
EN 61010-2-031
EN 61010-2-032
1992 Emissions Standard
1992 Immunity Standard
1993 Safety Standard
1995 Safety Standard
To ensure conformity with these standard, this instrument must be operated in accordance with the instructions and specifications given in this manual.
! WARNING: Please follow manufacturers test
procedures whenever possible. Do not attempt to
measure unknown voltages or components until a
complete understanding of the circuit is obtained.
GENERAL GUIDELINES
ALWAYS
CAUTION: Even though this instrument complies with
the immunity standards, it’s accuracy can be affected
by strong radio emissions not covered in the above
standards. Sources such as hand-held radio transceivers, radio and TV transmitters, vehicle radios and
cellular phones generate electromagnetic radiation
that could be induced into the test leads of this instrument. Care should be taken to avoid such situations or
alternatively, check to make sure that the instrument is
not being influence by these emissions.
Test the 291 before using it to make sure it is
operating properly.
Inspect the test leads before using to make sure there
are no breaks or shorts.
Double check all connections before testing.
Have someone check on you periodically if
working alone.
Have a complete understanding of the circuit
being measured.
Disconnect power to circuit, then connect test leads to
the 291, then to circuit being measured.
NEVER
Attempt to measure unknown high voltages.
Attempt to measure current with the meter in
parallel to the circuit.
Connect the test leads to a live circuit before
setting up the instrument.
Touch any exposed metal part of the test lead assembly.
CAUTION: Please follow manufacturers test procedures whenever possible. Do not attempt to measure
unknown voltages or components until a complete
4
5
EN 50081-1
EN 50082-1
EN 61010-1
EN 61010-2-031
EN 61010-2-032
GENERAL GUIDELINES
ALWAYS
operating properly.
working alone.
being measured.
NEVER
4
5
INTERNATIONAL SYMBOLS
CAUTION: RISK OF ELECTRIC SHOCK
AC (Alternation Current)
DC (Direct Current)
REFER TO INSTRUCTION MANUAL
GROUND
DOUBLE INSULATION
EITHER DC OR AC
C. TECHNICAL DATA
Agency
UL Listed to U.S. and Canadian
Safety Standards. Meets CE
and IEC 1010.
4000 Count Improves the resolution on all
functions and ranges.
Data Hold
Maintains the reading on the
display for hard to reads areas.
Peak Mode Measure the inrush current of
motors, relays and solenoids.
Sleep Mode Automatically powers down
after 10 minutes of inactivity.
6
Perform the following tests and/or measurements with
the 291 and the appropriate function:
HVAC/R
ACA
ACV
ACV or DCV
OHMS
OHMS
OHMS
ACA
OHMS
ALL
Heat anticipator current in thermostats.
Line voltage.
Control circuit voltage.
Heating element resistance (continuity).
Compressor winding resistance.
Contactor and relay coil resistance.
Motor and compressor start up current.
Continuity of wiring.
Bar graph to indicate rapid fluctuations.
ELECTRICAL
ACV
ACA
OHMS
DCV
ACA
Measure line voltage.
Measure line current.
Continuity of circuit breakers.
Voltage of direct drive DC motors.
Start up current of motors, relays,
contactors and transformers.
ELECTRONIC
ACV
• Measure power supply voltage.
ACA
• Measure power supply current.
OHMS
• Continuity of circuit breakers and fuses.
7
DC (Direct Current)
GROUND
DOUBLE INSULATION
EITHER DC OR AC
C. TECHNICAL DATA
Agency
and IEC 1010.
Data Hold
6
HVAC/R
ACA
ACV
ACV or DCV
OHMS
OHMS
OHMS
ACA
OHMS
ALL
Line voltage.
ELECTRICAL
ACV
ACA
OHMS
DCV
ACA
ELECTRONIC
ACV
ACA
OHMS
7
3. Specifications
e. OHM (Resistance, )
IEC 1010 Over Voltage:
CAT II - 1000V
CAT III - 600V
Pollution Degree 2
UL 3111-1
Range
Res.
Accuracy
Overload
Protection
400Ω
0.1Ω
±1% of reading, ±10 digits
600V DC or
AC Peak
a. DCV
Range
Resolution
Accuracy
Impedance
40V
0.01V
±0.75% of reading,
10MΩ
400V
0.1V
±3 digits
600V
1V
Range
Resolution
Accuracy
Impedance
400V
0.1V
±1.2% of reading,
10MΩ
750V
1V
±3 digits
8
Threshold
Over Load Protection
3V
< 50Ω (100 digits)
600 V DC or Peak AC
Max. Volt. between
any Input and Ground
Display Type
Operating Temp.
Storage Temp.
Relative Humidity
c. ACA
Res.
0.1A
1A
Test Voltage
h. General Specifications
b. ACV
Range
400A
700A
f. Continuity Buzzer
Accuracy
±1.5% of reading,
±4 digits
Freq. Response
45Hz to 450Hz
*Warning: Test Leads. Use only correct type and
overvoltage category rating.
Power Supply
Battery Life
Size (H x L x W)
Weight
600V
4,000 Count, 4 times per
second update
-10° to 45°C (14° to 113°F)
-20° to 55°C (-4° to 131°F)
0% to 80% (0° - 35°C/32° - 95°F)
0% to 70% (35° - 50°C/95° - 122°F)
9 Volt Battery
80 hrs. Alkaline
40mm x 190mm x 65mm
(1.5in x 7.25in x 2.5in)
315g (11.1oz)
9
3. Specifications
CAT II - 1000V
CAT III - 600V
Pollution Degree 2
UL 3111-1
Range
Res.
Accuracy
Overload
Protection
400Ω
0.1Ω
600V DC or
AC Peak
a. DCV
Range
Resolution
Accuracy
Impedance
40V
0.01V
±0.75% of reading,
10MΩ
400V
0.1V
±3 digits
600V
1V
Range
Resolution
Accuracy
Impedance
400V
0.1V
±1.2% of reading,
10MΩ
750V
1V
±3 digits
8
Threshold
3V
< 50Ω (100 digits)
600 V DC or Peak AC
Max. Volt. between
Display Type
Operating Temp.
Storage Temp.
Relative Humidity
c. ACA
Res.
0.1A
1A
Test Voltage
b. ACV
Range
400A
700A
Accuracy
±1.5% of reading,
±4 digits
Freq. Response
45Hz to 450Hz
Power Supply
Battery Life
Size (H x L x W)
Weight
600V
second update
9 Volt Battery
80 hrs. Alkaline
40mm x 190mm x 65mm
315g (11.1oz)
9
1. Controls and Functions:
Push Buttons
PEAK
Activates the Peak Hold function
(ACA only.)
HOLD
until the button is pushed a
second time.
1. Controls and Functions: (cont.)
Input Jacks
COM
Black test lead connection for
ACV, DCV, Ω, Continuity Buzzer
and Diode Test functions.
Ω
V/Ω
Red test lead connection for all
ACV, DCV, Ω , Continuity Buzzer
Rotary Switch
10
OFF
Turns the 291 completely off.
V
Used to measure DC volts.
V
Used to measure AC volts.
Ω
Used to measure resistance and
use the continuity buzzer.
A
Used to measure AC amps.
11
Push Buttons
PEAK
(ACA only.)
HOLD
second time.
Input Jacks
COM
Ω
V/Ω
Rotary Switch
10
OFF
V
V
Ω
A
11
a. Measuring DC Volts
WARNING!
Do not attempt to make a voltage measurement of
more than 600V or of a voltage level that is unknown.
Application Notes
When measuring DC Voltage of a battery, the most accurate reading can be
attained by testing the battery under
load. To accomplish this, follow steps
1 through 4 shown on page 13 and
the following (with the battery in
holder and device turned on):
• Connect the red test lead from the
meter to the positive (+) terminal
of the battery.
• Connect the black test lead to the
negative (-) terminal of the battery.
• Reconnect power to the circuit and
read the voltage on the 291.
12
Instrument set-up:
FUNC.
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAXI
READING
V
COM
0.1mV
750V
V/Ω
Measurement Procedure:
1. Disconnect power to circuit to be measured.
2. Plug black test lead into the COM input jack.
3
Plug red test lead into the V/Ω input jack.
4. Set rotary switch to the appropriate V range.
5. Connect test leads to circuit to be measured.
6. Reconnect power to circuit to be measured.
7. Read the voltage on the 291.
Optional Modes
• HOLD:
Freezes the reading on the LCD.
• PEAK:
Measures the peak voltage.
13
WARNING!
Application Notes
of the battery.
12
Instrument set-up:
FUNC.
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAXI
READING
V
COM
0.1mV
750V
V/Ω
3
Optional Modes
• HOLD:
• PEAK:
13
b. Measuring AC Volts
Application Notes
Disconnect power from the
terminal block, find the fuse or
circuit breaker that controls
the block and turn it off.
Set up the meter following the
steps under “Measurement
Procedure” on page 15. Then
proceed with the following:
• Connect the red test lead to
the hot side of the block and the
black lead to the neutral side of the block.
Reconnect power to the block and read the
voltage on the meter. The reading should be
approximately 110V to 130V.
• Disconnect power from the block and move
the red wire to ground. Reconnect power to
the block and read the voltage on the meter.
Typically less than 20V should exist from
neutral to ground. If 110V or above exists,
the block may be wired incorrectly.
14
WARNING!
Instrument set-up:
FUNC.
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAX
READING
V
COM
0.1mV
750V
V/Ω
1.
2.
3.
4.
5.
6.
7.
Plug black test lead into COM input jack.
Plug red test lead into V/Ω input jack.
Set the rotary switch to the appropriate V function.
Optional Modes
• HOLD:
• PEAK:
15
Application Notes
14
WARNING!
Instrument set-up:
FUNC.
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAX
READING
V
COM
0.1mV
750V
V/Ω
1.
2.
3.
4.
5.
6.
7.
Optional Modes
• HOLD:
• PEAK:
15
c. Measuring AC Amps
Application Notes
CAUTION!
Do not attempt to make a current measurement with
the test leads. The 291 measures the current by
clamping the jaw around one conductor (wire).
Clamping around more than one wire will result in
erroneous readings.
Instrument set-up:
FUNC.
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAX
READING
A
NOT USED NOT USED
0.01A
700A
When measuring AC Amps of a motor there
are two types of measurements that can be
made, running current and in-rush or start-up
current. Start-up current will usually be much
higher than running current.
Set up the meter following the steps under
“Measurement Procedure” on page 16, and
then proceed with the following:
2. Set rotary switch to A function.
3. Clamp the jaws around one conductor of the circuit
to be measured.
4. Reconnect power to circuit to be measured.
5. Read the current on the 291.
Optional Modes
• HOLD: Freezes the reading on the LCD.
• PEAK: Measures the peak amperage.
16
Clamp the meter around a single wire
and reconnect power to the device. Read
the current displayed on the meter. This
is the running current of the motor.
Disconnect power to the motor and put
the meter in PEAK HOLD mode.
Reconnect the power and read
meter. This is the in-rush or
start-up current
of the motor.
17
Application Notes
CAUTION!
erroneous readings.
Instrument set-up:
FUNC.
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAX
READING
A
NOT USED NOT USED
0.01A
700A
to be measured.
Optional Modes
16
start-up current
of the motor.
17
d. Measuring Resistance
WARNING!
Do not attempt to make resistance measurements with
circuit energized. For best results, remove the resistor
completely from circuit before attempting to measure it.
NOTE:
To make accurate low ohm measurements, short the
ends of the test leads together and record the resistance
reading. Deduct this value from actual readings.
Instrument set-up:
18
Application Notes (Resistance)
FUNC.
When measuring resistance of a motor, make
sure the power is disconnected prior to testing.
Set up meter following steps under
“Measurement Procedure” on page 19, and
Ω
Connect the red test lead to one power
input line of the motor and the black test
lead to the other power input line of the
motor. In most applications if the reading
is OFL, the motor winding is open.
Connect the red test lead to the frame of
the motor and the black test lead to the
winding. In most applications if a reading
of 0 Ohms is displayed, the winding is
shorted to the motor frame (ground).
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAX
READING
COM
0.1Ω
400Ω
V/Ω
1.
2.
3.
4.
5.
6.
Set the rotary switch to the 400 Ω function.
Read the resistance value on the 291.
Optional Modes
19
WARNING!
NOTE:
Instrument set-up:
18
FUNC.
Ω
BLACK
RED
TEST LEAD TEST LEAD
MIN
READING
MAX
READING
COM
0.1Ω
400Ω
V/Ω
1.
2.
3.
4.
5.
6.
Optional Modes
19
e. Continuity Buzzer
g. Peak Mode
WARNING!
Do not attempt to make continuity measurements with
circuit energized.
Instrument set-up:
FUNC.
Ω
BLACK
TEST LEAD
COM
RED
TEST LEAD
V/Ω
1.
2.
3.
4.
5.
6.
Set the 291 to either the 400 or 700 ACA range and
allow the reading on the LCD to settle down to
zero. Clamp the jaw around one wire of the device
the peak current is to be measured from and again
allow the LCD to settle down to zero. Apply power
to the device and read the initial current draw by
the device being measured.
Set the rotary switch to the Ω function.
Listen for the buzzer to confirm continuity.
E. ACCESSORIES*
Standard Accessories
Part No.
9 Volt Alkaline Battery
Test Lead Set
Soft Carrying Pouch
A009A
A040
A200
Optional Modes
Optional Accessories
Part No.
f. Data Hold
Deluxe Test Lead Set
IEC 1010 Deluxe Test Lead Kit
Hard Carrying Case
SDK1C
TLS2000BC
A201
Press the HOLD button at any time on any function
to freeze the reading on the LCD display. This
function is very useful when measuring in locations where the display is difficult to read.
*These accessories have not been evaluated by UL and are not
considered as part of the UL Listing of this product.
21
g. Peak Mode
WARNING!
circuit energized.
Instrument set-up:
FUNC.
Ω
BLACK
TEST LEAD
COM
RED
TEST LEAD
V/Ω
1.
2.
3.
4.
5.
6.
E. ACCESSORIES*
Part No.
Test Lead Set
Soft Carrying Pouch
A009A
A040
A200
Optional Modes
Part No.
f. Data Hold
Hard Carrying Case
SDK1C
TLS2000BC
A201
21
F. MAINTENANCE
1. Battery Replacement: The 291 will display a battery symbol when the internal 9 Volt battery needs
replacement. The battery is replaced as follows:
Problem
a. Disconnect and remove all test leads
from live circuits and from the 291.
b. Loosen the screw from the back of the
291 battery cover.
c. Remove the battery compartment cover.
d. Remove old battery and replace with new
battery, observing the correct polarity.
e. Reassemble the instrument in reverse
order from above.
2. Cleaning your 291:
Use a mild detergent and slightly damp cloth to
clean the surfaces of the 291.
Probable Causes
Does not power up
• Dead or defective battery
• Broken wire from battery
snap to PCB
Won’t display current readings
• Open fuse
• Open test lead
• Improperly connected to
circuit under test
All functions except ohms read high
• Very weak battery that will
not turn on the low battery
indicator on the LCD
AC Volts do not read
WARRANTY
Please refer to product warranty card for
warranty statement.
22
23
F. MAINTENANCE
Problem
291 battery cover.
order from above.
Probable Causes
Does not power up
snap to PCB
• Open fuse
• Open test lead
circuit under test
WARRANTY
warranty statement.
22
23
291 SPECIFICATIONS
±0.75% Basic DCV Accuracy (also see pages 8-9)
Func.
Range
Res.
DCV
40V
400V
600V
0.01V
0.1V
1V
ACV
400V
750V
0.1V
1V
ACA
400A
700A
0.1A
1A
OHM
400Ω
0.1Ω
Continuity
Test Voltage
3V
Max Test Current
< 50Ω (100 digits)
Test Products International, Inc.
9615 SW Allen Blvd., Ste. 104
Beaverton, OR USA 97005
503-520-9197 • Fax: 503-520-1225
tpiusa@msn.com
Test Products International plc
2 Newcourt Business Park
Perry Road
Harlow, Essex CM18 7PR
England
Tel: 01279 439647 • Fax: 01279 450553
L291M • 12/1/97
copyright © 1997 Test Products International, Inc.
