Data Sheet
30 MHz Delay Trace Analog Oscilloscope With Probes
Model 2125A
Spe ci ficat ions
212 5A
VERTICAL AMPLIFIERS (CH 1 and CH 2)
Sensitivity
5 mV/div to 5 V/div, 1 mV/div to 1 V/div at x5
Attenuator
10 steps in 1-2-5 sequence. Vernier control provides full adjustment between steps
Accuracy
±3%, ±5% at x5
Input Resistance
1 MΩ +2%
Input Capacitance
25 pF ±10pF
Frequency Response
5 mV to 5 V/div: DC to 30 MHz (-3dB), X5: DC to 10 MHz (-3dB)
Rise Time
12ns (Overshoot ≤5%)
Operating Modes
CH 1: CH 1, single trace
CH 2
CH 2, single trace
ALT
dual trace, alternating
CHOP
dual trace, chopped
ADD
agebraic sum of CH 1 + CH 2
Polarity Reversal
CH 2 only
Max. Input Voltage
400 V (DC to AC peak)
SWEEP SYSTEM
B&K Precision's model 2125A is a dual trace oscilloscope
with a delayed sweep that offers high performance at a low
price. Most competitor's entry level oscilloscopes have a
20 MHz bandwidth, while B&K Precision's models 2125A
has a bandwidth of 30 MHz. This oscilloscope is built by
and backed by B&K Precision, a company that has been
selling reliable, durable, value priced test instruments for
over 50 years.
Delayed sweep in 23 steps
Built in component tester for capacitors, inductors,
diodes, transistors, zener diodes
23 step time base to 0.1ms/div
Deluxe handle/tilt stand
cUL certified
Operating Modes
Main, mix (both main sweep and delay sweep displayed),
or Delay (only delay sweep displayed), X-Y
Main Sweep SpeeD
0.1 µs/div to 2.0 s/div in 1-2-5 sequence,
23 steps Vernier control provides fully adjustable sweep time between steps
Accuracy
±3%
Sweep Magnification
10X, ±5%
Delayed Sweep Speed
0.1 ms/div to 0.1s/div in 1-2-5 sequence, 23 steps
Holdoff
Continuously variable for Main sweep up to 10 times normal
Delay Time Position
Continuously variable to control percentage of display that is devoted to main and delay sweep
TRIGGERING
Triggering Modes
AUTO (free run) or NORM, TV-V, TV-H
Trigger Source Maximum External CH 1, CH 2, ALT, EXT, LINE
Trigger Voltage
300 V (DC + AC peak)
AC 30 Hz to 30 MHz, TV H Used for triggering from horizontal sync pulses,
Trigger Coupling
TV V Used for triggering from vertical sync pulses
TRIGGER SENSITIVITY
Auto
Bandwidth: 100Hz - 40MHz, Internal: 1.5 div, External: ≥0.1Vp-p
Norm
Bandwidth: 100Hz - 40MHz, Internal: 1.5 div. External: ≥0.1Vp-p
TV-V
Bandwidth: DC -1kHz, Internal: 0.5 div, External: ≥0.05Vp-p
TV-H
1 kHz - 100kHz, Internal: 0.5 div, External: ≥0.05Vp-p
HORIZONTAL AMPLIFIER (Input through channel 1 input)
X-Y Mode
Switch selectable using X-Y switch. CH 1: X axis, CH 2: Y axis
Sensitivity
Same as vertical channel 2
Accuracy
Y-Axis: ±3%. X-Axis: ±6%
Input Impedance
Frequency Response
DC to 1MHz typical (-3 dB), to 6 div horizontal deflection
X-Y Phase Difference
3˚ or less at 50 kHz
Max. Input Voltage
CRT
Type
Rectangular with internal graticule
Display Area
8 x 10 div (1 div = 1 cm)
Accelerating Voltage
2 kV
Phosphor
P31
Trace Rotation
Electrical, front panel adjustable
COMPONENT TESTER
Components Tested
Resistors, Capacitors, Inductors, and Semiconductors
Test Voltage
6 V rms maximum (open)
Test Current
11 mA maximim (shorted)
Test Frequency
Line Frequency (60 Hz in USA)
Calibrating Voltage
1 kHz (±10%) Positive Square Wave, 0.2 V p-p (±2%)
GENERAL
Within Specified Accuracy: 50˚ to 95˚F (10˚ to 35˚C), ≤85% RH
Full Operation: 32˚ to 104˚ F (0˚ to 40˚C), ≤85% RH
Temperature
Storage: -4˚ to 158˚ F (-20˚ to +70˚C)
Power Requirements
100/120/220/240 VAC ±10%, 50/60 Hz, Approximately 40 W
Dimensions (WxHxD)
7 x 14 .5 x 14.25" (180 x 370 x 440 mm)
Weight
Approximately 17.2 lbs (7.8 kg)
Three Year Warranty
Supplied Accessoriesa
Optional Accessories
Technical data subject to change
© B&K Precision Corp. 2012
v013112
Instruction Manual, Two PR-33A x1/x10 Probes or equivalent, AC Power Cord, Spare Fuse
PR-32A Demodulator Probe, PR-37A x1/x10/REF. Probe, PR-100A x100 Probe,
PR-55 High Voltage x1000 Probe, LC-210A Carrying Case
www.bkprecision.com
Tel.: 714.921.9095
