Approval sheet
RFBPF Series – 2012(0805)- RoHS Compliance
MULTILAYER CERAMIC BAND PASS FILTER
2.4 GHz ISM Band Working Frequency
P/N: RFBPF2012080A7T
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_RFBPF2012080A7T_V04
Mar. 2010
Approval sheet
FEATURES
1.
Miniature footprint: 2.0 X 1.2 X 0.8 mm
2.
Low Profile Thickness
3.
Low Insertion loss
4.
High Rejection Rate
5.
High attenuation on 2
6.
LTCC process
nd
3
harmonic suppressed
APPLICATIONS
1.
2.4GHz ISM band RF applications
2.
Bluetooth, Wireless LAN 802.11b/g, HomeRF
CONSTRUCTION
P4
P1
03
PIN
Connection
PIN
Connection
1
GND
4
INPUT/OUTPUT
2
INPUT/OUTPUT
3
GND
P3
P2
DIMENSIONS
Figure
L
B
D
W
03
Page 2 of 7
Dimension (mm)
L
2.00 ± 0.15
W
1.25 ± 0.15
T
0.80 ± 0.10
A
1.00 ± 0.15
B
0.30 ± 0.15
C
0.50 ± 0.15
D
0.25 ± 0.15
E
0.25 ± 0.15
T
E
C
Symbol
A
Mar. 2010
Approval sheet
ELECTRICAL CHARACTERISTICS
RFBPF2012080A7T
Specification
Frequency range
2450 ± 50 MHz
Insertion Loss
2.8 dB max (typ. 2.5 dB )
VSWR
2.0 max
Impedance
50 Ω
40 dB @ DC~1600 MHz
35 dB @ 1710 MHz
25 dB @ 1900 MHz
12 dB @ 2100 MHz
Attenuation (min.)
8 dB @ 2170 MHz
30 dB @ 3100 MHz
40 dB @ 4800~5000 MHz
20 dB @ 7200~7500 MHz
Operation Temperature Range
-45°C ~ +85°C
Typical Electrical Chart
SOLDER LAND PATTERN
Figure
Line width to be design to match 50Ω
Ω characteristic impedance,
depending on PCB material and thickness.
Φ are the grounding through holes.
Page 3 of 7
Symbol
Dimension (mm)
L1
1.270 ± 0.10
L2
0.508 ± 0.05
L3
0.610 ± 0.05
L4
0.381 ± 0.05
L5
0.508 ± 0.05
W1
0.762 ± 0.10
W2
1.016 ± 0.10
W3
0.406 ± 0.05
W4
0.762 ± 0.05
S1
0.489 ± 0.05
S2
0.254 ± 0.05
S3
0.381 ± 0.05
Φ
0.406 ± 0.10
Mar. 2010
Approval sheet
RELIABILITY TEST
Test item
Test condition / Test method
Specification
Solderability
JIS C 0050-4.6
*Solder bath temperature:235 ± 5°C
At least 95% of a surface of each terminal
JESD22-B102D
*Immersion time:2 ± 0.5 sec
electrode must be covered by fresh solder.
*Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 ± 5°C
Loss of metallization on the edges of each
of metallization)
*Leaching immersion time:30 ± 0.5 sec
electrode shall not exceed 25%.
IEC 60068-2-58
*Solder : SN63A
(Resistance to dissolution
Resistance to soldering heat
*Preheating temperature:120~150℃,
JIS C 0050-5.4
1 minute.
No mechanical damage.
Samples shall satisfy electrical specification
*Solder temperature:270±5°C
after test.
*Immersion time:10±1 sec
Measurement to be made after keeping at
room temperature for 24±2 hrs
Drop Test
JIS C 0044
*Height:75 cm
*Test Surface:Rigid surface of concrete
after test.
or steel.
*Times:6 surfaces for each units;2
times for each side.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
Bending test
JIS C 0051- 7.4.1
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
The middle part of substrate shall be
pressurized by means of the pressurizing
rod at a rate of about 1 mm/s per second
after test.
until the deflection becomes 1mm/s and
then pressure shall be maintained for 5±1
sec.
room temperature for 24±2 hours
Page 4 of 7
Mar. 2010
Approval sheet
Temperature cycle
JIS C 0025
1.
30±3 minutes at -40°C±3°C,
2.
10~15 minutes at room temperature,
3.
30±3 minutes at +85°C±3°C,
4.
specification after test.
Total 100 continuous cycles
Vibration
JIS C 0040
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
after test.
mutually perpendicular directions)
High temperature
JIS C 0021
*Temperature:85°C±2°C
*Test duration:1000+24/-0 hours
after test.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:40±2°C
JIS C 0022
*Time:1000+24/-0 hrs.
after test.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40°C±2°C
after test.
Page 5 of 7
Mar. 2010
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
RF
BPF
201208
Walsin
Product Code
Dimension code
RF device
BPF : Band Pass
Filter
Per 2 digits of
Length, Width,
Thickness :
A
Unit of
dimension
0 : 0.1 mm
7
T
Application
Specification
Packing
A : 2.4GHZ ISM
Band
Design Code
T : Reeled
1 : 1.0 mm
e.g. :
201208 =
Length 20,
Width 12,
Thickness 08
Minimum Ordering Quantity: 2000 pcs per reel.
PACKAGING
P2
P1
ΦD
P0
E
F
W
03
03
03
03
03
B0
T
A0
Plastic Tape specifications (unit :mm)
Index
Dimension (mm)
Index
Dimension (mm)
Page 6 of 7
ΦD
Ao
1.45 ± 0.10
Bo
2.25 ± 0.10
1.55 ± 0.10
T
1.10 ± 0.10
W
8.00 ± 0.30
E
1.75± 0.10
F
3.50 ± 0.05
Po
4.00 ± 0.10
P1
4.00 ± 0.10
P2
2.00± 0.10
Mar. 2010
Approval sheet
Reel dimensions
C
Index
A
Φ178.0
Dimension (mm)
B
Φ60.0
A
B
C
Φ13.0
Taping Quantity:2000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for
the prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Aircraft equipment
Aerospace equipment
Undersea equipment
Medical equipment
Disaster prevention / crime prevention equipment
Traffic signal equipment
Transportation equipment (vehicles, trains, ships, etc.)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be
confirmed.
(2)
Storage environment condition.
Products should be storage in the warehouse on the following conditions.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Page 7 of 7
Temperature
: -10 to +40℃
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Mar. 2010
很抱歉,暂时无法提供与“RFBPF2012080A7T”相匹配的价格&库存,您可以联系我们找货
