DATASHEET
DC Filters FN 2211 and FN 2210
Compact high current DC EMC/EMI filter
Reduces conducted emissions towards the solar
panel
Approvals
Reduces the probability of EMI radiation off the
solar panel
Helps to prevent premature panel aging
Helps to meet international EMC regulations
Most compact standard solution in the industry
FN 2210 without Cy capacitors to ground
The FN 2211 / FN 2210 series are the most compact
dedicated high current DC filters for PV inverters in
the industry and therefore are an optimum fit with
most modern PV inverter generation. In addition the
filters can be configured in a very flexible way to fulfil
customized application requirements.
All FN 2211 / FN 2210 come in unsymmetrical
housings, which help to prevent inverse installation
and wrong electrical connection. Along with grid-side
installed Schaffner AC EMC/EMI filters FN 2211 / FN
2210, the DC filters FN 2211 / FN 2210 are key to meet
the stringent international standards for
electromagnetic compatibility and help to ensure a
reliable and fault-free operation of the entire PV
system.
Features and benefits
Technical specifications
Maximum continuous operating voltage
Operating frequency
1000 VDC
DC
High potential test voltage
P -> E 4800VDC for 2 sec
P -> P 3600VDC for 2 sec
Rated currents
Protection category
Overload capability
Temperature range (operation and storage)
Climatic category
Terminals/Housing
Flammability corresponding to
Design corresponding to
250 to 2300 A @50°C
IP00
4x rated current at switch on, max. 8 sec
1.5x rated current for 1 minute, once per hour
-40°C to +100°C
40/100/21 acc. to IEC60068-1
Ni plated cu bars/Metal
UL 94V-0
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939,
EN60721-3, EN62109
Installed between the PV inverter and the solar panel,
the FN 2211 and FN 2210 DC filters are used to
influence positively the conducted emissions on the
panel side of the system. Therefore the DC filters
significantly reduce the potential for highfrequency
(HF) interference radiation of the panel. The filter also
helps to prevent premature panel aging because of
HF stray and leakage currents.
Typical applications
The FN 2211 / FN 2210 series are primarily designed
for PV inverter applications between 250 and 2'300 A.
However, they can potentially also be applied in other
DC applications within published specifications, like
UPS, DC motor drives, energy/battery storage
systems, or DC charger installations.
Typical electrical schematic FN 2211
Typical electrical schematic FN 2210
2
EMC/EMI Products
Schaffner Group
Datasheets
2015
Filter selection table
Filters *
Rated current
Power losss
@ 50 °C
[A]
FN 2211 with Cy caps
FN 2211-250-99-C30-R55
@ 25 °C/DC
[W]
FN 2211-600-99-C30-R55
[kg]
250
15
3.0
600
25
4.6
400
FN 2211-400-99-C30-R55
Weight
FN 2211-1000-99-C30-R55
1000
FN 2211-2300-99-C30-R55
24
55
1500
4.0
6.8
2300
84
116
11.5
FN 2210-250-99-R5
250
15
2.4
FN 2210-600-99-R5
600
25
3.8
FN 2211-1500-99-C30-R55
FN 2210 without Cy caps
400
FN 2210-400-99-R5
FN 2210-1000-99-R5
1000
FN 2210-2300-99-R5
2300
24
55
1500
FN 2210-1500-99-R5
84
116
17.5
3.1
6.2
11.3
17.5
* Filters with reduced Cy capacitance to ground for high asymmetrical currents and higher voltages available upon request.
Typical filter attenuation FN 2211-xxx-99-C30-R55
Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym
250 / 400 / 600 A types
1000 A types
1'500 / 2'300 A types
Typical block schematic
1 PV modules
2 Schaffner DC filter FN 22xx
3 Central Inverter
4 Schaffner magnetic components
5 Schaffner AC EMC/EMI filter FN 3xxx
Important note: depending on the grounding scheme of the solar power system, including the solar panel and the grid side transformer, the appropriate DC- and AC
EMC/EMI filter version need to be selected. For support, please contact your local Schaffner sales office or partner.
EMC/EMI Products
3
Schaffner Group
Datasheets
2015
Busbar connections
Mechanical data
250 to 2'300 A types
250 to 1'000 A types
1'500 A types
2'300 A types
Note: all FN 2211 and FN 2210 provide unsymmetrical mounting hole patterns to prevent inverse filter installation in the field.
Dimensions
FN 2211
FN 2210*
FN 2211
FN 2210*
FN 2211
FN 2210*
FN 2211
FN 2210*
FN 2211
FN 2210*
FN 2211
FN 2210*
A
220
205
235
215
240
225
265
265
275
275
305
305
C*
135
95
150
100
150
100
160
110
200
150
210
210
277
260
240
265
250
300
300
315
315
345
345
250 A
B
D
E
F1
F2
G
H
J
160
250 A
145
285
270
130
120
245
135
Ø7
1.5
M6
125
Ø7
1.5
M6
400 A
175
310
140
145
Ø9
2
M8
400 A
160
290
125
130
Ø9
2
M8
600 A
175
315
140
145
Ø9
2
M8
600 A
170
300
135
140
Ø9
2
M8
1'000 A
180
380
140
145
Ø 11
2.5
M8
1'000 A
180
380
140
145
Ø 11
2.5
M8
1'500 A
215
440
175
180
Ø 11
2.5
M10
1'500 A
215
440
175
180
Ø 11
2.5
M10
2'300 A
230
495
190
195
Ø 11
2.5
M10
2'300 A
230
495
190
195
Ø 11
2.5
M10
K
250 (+/- 1)
230 (+/- 1)
265 (+/- 1)
245 (+/- 1)
270 (+/- 1)
255 (+/- 1)
310 (+/- 1)
310 (+/- 1)
321 (+/- 1)
321 (+/- 1)
351 (+/- 1)
351 (+/- 1)
M
41
41
46
46
49.5
49.5
53
53
58
58
60.5
60.5
93 (+/- 0.5)
L
N
265
245
285
265
290
275
330
330
345
26
345
26
375
35
P
84 (+/- 0.5)
74 (+/- 0.5)
86 (+/- 0.5)
71 (+/- 0.5)
84 (+/- 0.5)
79 (+/- 0.5)
86 (+/- 0.5)
86 (+/- 0.5)
86 (+/- 0.5)
86 (+/- 0.5)
93 (+/- 0.5)
V
25
25
25
40
40
60
60
70
10
12.5
12.5
12.5
12.5
Ø9
Ø 11
Ø 11
Ø 11
Ø 11
S
W
X
Y
Z
3
10
32.5
Ø9
3
32.5
4
37.5
4
37.5
8
37.5
8
37.5
8
Ø 13.5
26
26
40
375
35
40
70
8
10
10
15
15
57.5
82.5
82.5
82.5
95
Ø 13.5
17
Ø 13.5
17
Ø 13.5
* FN 2210 with flat top (Dimension C)
All dimensions in mm; 1 inch=25.4mm
Tolerances according: ISO 2768-m / EN 22768-m, if not stated otherwise
Please see the brochure "Basics in EMC and Power Quality" on our website www.schaffner.com/downloads to find more details on filter connectors.
Ø 13.5
Ø 13.5
4
EMC/EMI Products
Headquarters, global
innovation and development
center
Switzerland
Schaffner Group
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 630
info@schaffner.com
http://www.schaffner.com
Schaffner Group
Sales and application centers
China
Schaffner EMC Ltd. Shanghai
T20-3, No 565 Chuangye Road
Pudong New Area
201201 Shanghai
T +86 21 3813 9500
F +86 21 3813 9501 / 02
cschina@schaffner.com
http://www.schaffner.com.cn/
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 19 35 72 71
finlandsales@schaffner.com
France
Schaffner EMC S.A.S.
112 Quai de Bezons
Boîte postale 133
95100 Argenteuil
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Galileo Galilei 47
20092 Cinisello Balsamo (MI)
T +39 02 66 04 30 45 /47
F +39 02 61 23 943
italysales@schaffner.com
To nd your local partner within Schaffner‘s
global network: www.schaffner.com
© 2015 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published speci cations are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never be
operated
outside
their
published
speci cations. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Datasheets
Japan
Schaffner EMC K.K.
1-32-12, Kamiuma, Setagaya-ku
7F Mitsui-seimei Sangenjaya Bldg.
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
http://www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1
05-09 Kampong Ubi Industrial Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E,
Alcobendas
El Soto de la Moraleja
Alcobendas
28109 Madrid
M +34 618 176 133
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Sweden
Schaffner EMC AB
Turebergstorg 1, 6
19147 Sollentuna
T +46 8 5792 1121 / 22
F +46 8 92 96 90
swedensales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 681 66 26
F +41 32 681 66 41
switzerlandsales@schaffner.com
Taiwan R.O.C.
Schaffner EMV Ltd.
6 Floor, No. 413
Rui Guang Road
114 Neihu District Taipei City
T +886 2 87525050
F +886 2 87518086
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
UK
Schaffner Ltd.
5 Ashville Way
Molly Millars Lane
Wokingham
RG41 2PL Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
http://www.schaffner.uk.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
08837 Edison, New Jersey
T +1 800 367 5566
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
http://www.schaffner.com/us
Schaffner MTC LLC
6722 Thirlane Road
24019 Roanoke, Virginia
T +1 276 228 7943
F +1 276 228 7953
http://www.schaffner-mtc.com
Schaffner Trenco LLC
2550 Brookpark Road
44134 Cleveland, Ohio
T +1 216 741 5282
F +1 216 741 4860
http://schaffner-trenco.com
2015
很抱歉,暂时无法提供与“FN2210-1500-99-R5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9605.632931+1191.57431
