FN3311-1000-99-C16-R55 数据手册
DATASHEET
3-Phase Filters FN 3311 and FN 3310
Compact power line AC EMC/EMI filter
High current 3-phase filter up to 2300A
Extremly compact and light weight design
Approvals
Minimum installation foot print
Performance optimised for standard purpose
applications
FN 3310 series without Cy capacitors to ground
The FN 3311 / FN 3310 poduct series of standard
EMC/EMI filters are based on Schaffner’s many years of
expertise in filter design for all types of converter and
inverter applications. Installed between the PV
inverter and the power grid, the FN 3311 / FN 3310 AC
filters are used to influence positively the conducted
emissions on the grid side to help to comply with the
required emission standards.
Features and benefits
Technical specifications
Maximum continuous operating voltage
Operating frequency
Rated currents
High potential test voltage
Protection category
Overload capability
Temperature range (operation and storage)
Climatic category
Terminals/Housing
Flammability corresponding to
Design corresponding to
3x 520/300 VAC for FN 3311
3x 520 VAC for FN 3310
DC to 60Hz
250 to 2300 A @ 50°C
P –> E 2kVAC for 2 sec
P –> P 2.25kVDC for 2 sec
IP00
4x rated current at switch on, max. 8 sec
1.5x rated current for 1 minute, once per hour
-40°C to +100°C
40/100/21 acc. to IEC60068-1
Ni plated cu bars/Metal
UL 94V-0
UL 1283, CSA 22.2 No. 8, IEC/EN 60939, EN60721-3
The FN 3311 / FN 3310 series are the most compact
dedicated high current AC filters, not only suitable for
PV applications, but being an optimum fit with most
modern PV inverter topologies. In addition the filters
can be configured in a very flexible way to fulfil
custom specific application requirements. All FN 3311
/ FN 3310 come in unsymmetrical housings, which
help to prevent inverse installation and wrong
electrical connection. Along with solar panel-side
installed Schaffner DC EMC/EMI filters FN 2211 / FN
2210, the AC filters FN 3311 / FN 3310 are key to meet
the stringent international standards for electromagnetic compatibility and help to ensure a reliable
and fault-free operation of the entire PV system.
Typical applications
The FN 3311 / FN 3310 series are primarily designed
for all kind of power line connected converter and
inverter applications between 250 and 2'300 A.
However, they are optimised for PV inverter and can
potentially also be applied for general purpose motor
drives applications.
Typical electrical schematic FN 3311
Typical electrical schematic FN 3310
2
EMC/EMI Products
Schaffner Group
Datasheets
2015
Filter selection table
Filters */**
Rated current
FN 3311 with Cy caps
FN 3311-250-99-C16-R55
Typical inverter
FN 3311-600-99-C16-R55
100
0.06
18
2.3
600
250
0.06
33
4.0
FN 3311-1000-99-C16-R55
1000
FN 3311-2300-99-C16-R55
2300
1500
FN 3311-1500-99-C16-R55
FN 3310 without Cy caps
400
500
800/1000
250
FN 3310-250-99-R5
9.9
250
33
4.0
FN 3310-2300-99-R5
2300
1500
5.5
2.3
400
0.06
133
18
1000
FN 3310-1500-99-R5
0.06
70
3.1
100
FN 3310-1000-99-R5
600
0.06
30
18.2
150
FN 3310-600-99-R5
0.06
[kg]
201
400
FN 3310-400-99-R5
@ 25 °C/DC
[W]
Weight
250
150
@ 520VAC/50Hz
[mA]
Power losss
AC power rating***
[kVA]
400
FN 3311-400-99-C16-R55
Leakage current****
@ 50 °C
[A]
30
70
500
133
800/1000
201
3.1
5.5
9.9
18.2
* Filters with higher current ratings available upon request.
** Filters with reduced Cy capacitance to ground for high asymmetrical currents and higher voltages available upon request.
*** Calculated at rated current, 480 VAC (FN 3311) / 690 VAC (FN 3311HV) and cos phi = 0.8. The exact value depends upon the efficiency of the drive, the motor and the
entire application.
**** Leakage current according IEC 60939-1
Typical filter attenuation FN 3311-xxx-99-C16-R55
Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym
250 / 400 A types
600 A types
1'000 / 1'500 A types
2'300A types
Typical block schematic
1 PV modules
2 Schaffner DC filter FN 22xx
3 Central Inverter
4 Schaffner magnetic components
5 Schaffner AC EMC/EMI filter FN 3xxx
Important note: depending on the grounding scheme of the solar power system, including the solar panel and the grid side transformer, the appropriate DC- and AC
EMC/EMI filter version need to be selected. For support, please contact your local Schaffner sales office or partner.
EMC/EMI Products
3
Schaffner Group
Datasheets
2015
Busbar connections
Mechnical data
250 to 2'300 A types
250 to 1'000 A types
1'500 A types
2'300 A types
Note: all FN 3311 and FN 3310 provide unsymmetrical mounting hole patterns to prevent inverse filter installation in the field.
Dimensions
FN 3311 / FN 3310
250 A
FN 3311 / FN 3310
400 A
FN 3311 / FN 3310
600 A
FN 3311 / FN 3310
1'000 A
FN 3311 / FN 3310
1'500 A
FN 3311 / FN 3310
2'300 A
A
170
175
190
190
195
220
C
140
140
140
140
150
165
B
D
E
F1
F2
G
H
J
195
235
195
155
160
210
250
205
170
175
220
265
220
180
185
220
305
220
180
185
225
360
240
215
220
280
410
265
235
240
Ø7
Ø9
Ø9
Ø9
Ø 11
Ø 11
M6
M8
M8
M8
M10
M10
1.5
2
2
2.5
2.5
2.5
K
200 (+/- 1)
210 (+/- 1)
225 (+/- 1)
225 (+/- 1)
241 (+/- 1)
266 (+/- 1)
M
41
46
50
53
59
60.5
L
N
O
215
24.5
230
27
245
29.5
245
29.5
265
26
34.8
P
49 (+/- 0.5)
54 (+/- 0.5)
59 (+/- 0.5)
59 (+/- 0.5)
69.5 (+/- 0.5)
V
25
40
60
X
10
12.5
12.5
Ø9
Ø 11
Ø 11
S
W
Y
Z
3
32.5
4
37.5
8
37.5
8
57.5
Ø 13.5
26
10
17
82.5
Ø 13.5
All dimensions in mm; 1 inch=25.4mm
Tolerances according: ISO 2768-m / EN 22768-m, if not stated otherwise
Please see the brochure "Basics in EMC and Power Quality" on our website www.schaffner.com/downloads to find more details on filter connectors.
290
35
40
80 (+/- 0.5)
40
70
15
Ø 13.5
4
EMC/EMI Products
Headquarters, global
innovation and development
center
Switzerland
Schaffner Group
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 630
info@schaffner.com
http://www.schaffner.com
Schaffner Group
Sales and application centers
China
Schaffner EMC Ltd. Shanghai
T20-3, No 565 Chuangye Road
Pudong New Area
201201 Shanghai
T +86 21 3813 9500
F +86 21 3813 9501 / 02
cschina@schaffner.com
http://www.schaffner.com.cn/
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 19 35 72 71
finlandsales@schaffner.com
France
Schaffner EMC S.A.S.
112 Quai de Bezons
Boîte postale 133
95100 Argenteuil
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Galileo Galilei 47
20092 Cinisello Balsamo (MI)
T +39 02 66 04 30 45 /47
F +39 02 61 23 943
italysales@schaffner.com
To nd your local partner within Schaffner‘s
global network: www.schaffner.com
© 2015 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published speci cations are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never be
operated
outside
their
published
speci cations. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Datasheets
Japan
Schaffner EMC K.K.
1-32-12, Kamiuma, Setagaya-ku
7F Mitsui-seimei Sangenjaya Bldg.
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
http://www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1
05-09 Kampong Ubi Industrial Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E,
Alcobendas
El Soto de la Moraleja
Alcobendas
28109 Madrid
M +34 618 176 133
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Sweden
Schaffner EMC AB
Turebergstorg 1, 6
19147 Sollentuna
T +46 8 5792 1121 / 22
F +46 8 92 96 90
swedensales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 681 66 26
F +41 32 681 66 41
switzerlandsales@schaffner.com
Taiwan R.O.C.
Schaffner EMV Ltd.
6 Floor, No. 413
Rui Guang Road
114 Neihu District Taipei City
T +886 2 87525050
F +886 2 87518086
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
UK
Schaffner Ltd.
5 Ashville Way
Molly Millars Lane
Wokingham
RG41 2PL Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
http://www.schaffner.uk.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
08837 Edison, New Jersey
T +1 800 367 5566
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
http://www.schaffner.com/us
Schaffner MTC LLC
6722 Thirlane Road
24019 Roanoke, Virginia
T +1 276 228 7943
F +1 276 228 7953
http://www.schaffner-mtc.com
Schaffner Trenco LLC
2550 Brookpark Road
44134 Cleveland, Ohio
T +1 216 741 5282
F +1 216 741 4860
http://schaffner-trenco.com
2015
FN3311-1000-99-C16-R55 价格&库存
很抱歉,暂时无法提供与“FN3311-1000-99-C16-R55”相匹配的价格&库存,您可以联系我们找货
