T0052921399N
T0052921399N
    ATG
    HANDPIECE55W12V
T0052921399N 数据手册
Product information WXMP MS Code No. : T0052921399 Active Tip Heizkörper Technologie Mikro-Lötkolben WXMP MS 55 W, 12 V - Für WX Stationen - Sehr feiner, schlanker Lötkolben, der sich ideal für Arbeiten unter dem Mikroskop eignet. - Hohe Leistungsfähigkeit durch eine integrierte, aktive Lötspitze. Achtung Im Lieferumfang ist KEINE Lötspitze enthalten! Technical data Voltage (heater): 12 V Heating output: 40 W (55W with RT MS11) Heat-up time: approx. 3 s 50°C - 350°C (120°F - 660°F) Temperature range: 100°C - 450°C (212°F - 850°F) Tip type: RT MS Connectable to: Weller WX Stations Note:The WXMP soldering iron by Weller may only be used with Weller WX supply units. The MS tip family is designed MIL-STD-2000. The handles and the tips have All MS Tools can be used like MS Tools and Tips must always for customers they are working according to isolation between the mass and the potential. the standard WXMP and WXMT. be used together. Active Tip Heating Technology ● ● ● ● Quick tip exchange without any tools Extremely short heating time 100°/sec. Energy saving by standby function Optimal reaction time Optimum for soldering applications Page 1 / 2 Optimal tool where heating element and sensor are integrated in the soldering tip. By lowering the soldering joint temperature a faster reaction time is possible. With this tool the performance is exactly at solder joint. the Page 2 / 2
T0052921399N 价格&库存
很抱歉,暂时无法提供与“T0052921399N”相匹配的价格&库存,您可以联系我们找货
