SMD2040
Datasheet revision 1.3
www.chipquik.com
Sn96.5/Ag3.0/Cu0.5 Solder Spheres for BGAs
Product Highlights
Chip Quik® BGA solder spheres are manufactured from virgin materials to meet or exceed the requirements of building or
repairing BGA packages. Chip Quik® BGA solder spheres also exceed both the IPC and MIL standards for purity levels and
size tolerances. Nominal sizes are available from 8 to 30 mil.
Product Specifications
Part Number
SMD2016
SMD2016‐25000
SMD2020
SMD2020‐25000
SMD2024
SMD2024‐25000
SMD2028
SMD2028‐25000
SMD2032
SMD2032‐25000
SMD2036
SMD2036‐25000
SMD2040
SMD2040‐25000
SMD2050
SMD2050‐25000
SMD2055
SMD2055‐25000
SMD2060
SMD2060‐25000
Alloy
Melting Point
Diameter
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
0.008" (0.2mm)
0.010" (0.25mm)
0.012" (0.3mm)
0.014" (0.35mm)
0.016" (0.4mm)
Sn96.5/Ag3.0/Cu0.5
Shelf Life:
Test Results
Test J-STD-004 or other
requirements as stated
Conflict Minerals Compliance
REACH Compliance
217‐220°C (423‐428°F)
0.018" (0.45mm)
0.020" (0.5mm)
0.024" (0.6mm)
0.025" (0.63mm)
0.030" (0.76mm)
>24 months
Test Requirement
Result
Electronic Industry Citizenship
Coalition (EICC)
Articles 33 and 67 of Regulation (EC)
No 1907/2006
Compliant
Conforms to the following Industry Standards:
J-STD-006C, Amendments 1 & 2 (Solder Alloys and Fluxed/Non-Fluxed Solders):
RoHS 2 Directive 2011/65/EU:
1
Quantity (by weight)
© 1994-2018 Chip Quik® Inc.
Contains no substance >0.1% w/w that
is listed as a SVHC or restricted for
use in solder materials
Yes
Yes
Additional Alloys Available
Part Number
SMD2140
SMD2140‐25000
SMD2150
SMD2150‐25000
SMD2165
SMD2165‐25000
SMD2170
SMD2170‐25000
SMD2180
SMD2180‐25000
SMD2185
SMD2185‐25000
SMD2190
SMD2190‐25000
SMD2195
SMD2195‐25000
SMD2200
SMD2200‐25000
SMD2205
SMD2205‐25000
SMD2215
SMD2215‐25000
2
Alloy
Melting Point
Diameter
0.008" (0.2mm)
0.010" (0.25mm)
0.012" (0.3mm)
0.014" (0.35mm)
0.016" (0.4mm)
Sn63/Pb37
183°C (361°F)
0.018" (0.45mm)
0.020" (0.5mm)
0.022" (0.55mm)
0.024" (0.6mm)
0.025" (0.63mm)
0.030" (0.76mm)
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
250,000
25,000
很抱歉,暂时无法提供与“SMD2190”相匹配的价格&库存,您可以联系我们找货
