71-01-02
    MASTERAPPLIANCECO(晨星半导体)
    TIP,CHISEL,2.4MM(STANDARD)
71-01-02 数据手册
Your butane powered heat tool was carefully lested and Inspected before 11was sh~ppedlrom the factory We warrant thls product to be free from defects m materials and workmansh~punder normal use and servlce for one year from date of purchase In the event of a defect tn mater~alsor workmansh~p,we will e~therrepalr or replace. w~thoutcharge, at our optton, any part which In our judgement shows evidence of such defect. This warranty does not apply to the attachments. t~ps,burner, or ejector, vhlch are Items requlnng penodlc replacement, nor does ~tapply ~f the butane powered heat tool has been mlsused. abused, altered, tampered wlth, or used with butane fuel other than Master Appl~anceUltratane butane fuel At the end of the warranty per~od, Master Appl~anceshall be under no further obl~gation,expressed or ~mpl~ed. Some on how long an ~mpl~ed warranty lasts, so the above states do not allow l~mltat~ons limltat~onmay not apply to you Masler Appl~anceassumes no responslblllty for and thls warranty shall not cover any tncldental or consequent~aldamages from any defect m this product or 11suse Some slates do not allow the excluston or l~mflat~on of ~nctdentafor consequential damages, so the above exclus~onmay not apply to you. This warranty glves you specrflc nghts and you may also have other nghts which may vary from slate to state For warranty repalr a proof ofr % purchase t i && f dthei appropriate proof of date 1s required w~thyour retum for warranty repair to Master Appl~ance All warranty cla~msmust be made to Master Appliance and not the dlstr~butorWe decllne respons~b~lrty where repairs have been made or attempted by others Any d~tferentguarantee made by others IS not authorized by us If a warranty clam 1s to be made please retum your Master Heat Tool prepa~d,w~thproof of purchase and a note descr~b~ng the problem to our Repar Department. See below. For repalr servlce we charge a flat rate fee Please call Master Appl~ancefor the flat rate charge return your Master Heat Toot prepa~d.w~tha note descrlblng the problem to ULTRATORCH " UT-50 Please read, understand and keep this manual for future reference Operating Instructions ( I Unit operates on butane gas and creates infrared heat effectively by the use of a catalyst. Before filling, make sure switch ring is off. Press the nozzle into the refill opening. When the unit is full, the gas will overflow the refill nozzle. OCheck the window for fuel level. N0TICE:Before igniting your Ultratorch the first time, completely fill the tank with butane. Then wait 5 minutes. During this time tilt the Ultratorch up and down several times. This initial waiting period gives the wick inside the fuel tank time to absorb the butane and allows for lubrication of the filter. 1.WARNING.Tha product, when uSed for soldering and slmllar appllcat~ons. produces chemlcels known to the State of Calrfom~ato cause cancer and birth defects or other reproductive harm ADVERTENC1A:EI estado de Callfornla tlene conoclmlentos de que este producto, cuando se usa en soldaduras o apllcac~onesstmtlares, produce agentes quunlcos que pueden provocar cancer, defectos mgenitos y danos al sistema reproductor 2.WARNING:By-products of the combust~onof the fuel used by thls product contaln chernlcals known to the State of Cal~forn~a to cause cancer and repro dudlve harm, ADVERTENCIA:EI estado de Callfomia tlene conoclmlentos de que 10s produclos re~~duales de la combus~ondel combustible usado por este producto, cont~enesubstanc~asquimicas que pueden provocar cancer y danos al sistema reproductor 3.WARNING:The Department of Transportatloo Hazardous Mater~alRegulat~om forb~dthe carnage of butane or other flammable gas products on passenger a~rcraflDo not pack thls Item or any other Hammable gas Item. In any checked or carry-on baggage mUSTERR - ---- -- A P P L I A N C E KNURLED NUT SWITCH RING Ignition hstructions 1. Push the switch ring up and turn to the right. Place the indicator dot on 1 or lower. 2. Push the knurled nut upward exposing the ignition vents. 3. Ignite as shown by Figure 3, keeping the vent open. Hold knurled nut until glow appears from catalyst. Release the knurled nut, which will return to its original position. 4. The heat of the soldering tip can be controlled by rotating the switch ring between position 1 and 3. Des~gnersand Manufacturers of Heat Tool. for Industry Master Appl~anceCorp 2420-18th Street Raclne. WI 53402 U S A Tel (262) 633-7791 Facs~m~te (262) 633-9745 web www masterappl~ance.com e-mall sales@masterappllance com Please sh~ptool prepa~dEnclose a note descrlb~ng your problem IGNITION VENT Rev 2 Made 10Japan 4. CAUTION: Temperature is high at tip area. Wait for tips to cool before changing. Keep hands and combustibles from tip area while in use. 5. Do not immerse heated parts in water; allow to cool naturally. I SWITCH RING 6. Use only butane gas specified by manufacturer. Do not use propane gas or any other types of fluids. I 7. Do not store in temperatures over 4O0C/104"F. 1. Loosen and remove tip by turning the knurled nut to the 8. Do not store in a car during periods of high temperatures as fuel tank could possibly rupture. right as shown in Figure 4. 2. Push the switch ring up and turn to the right until the indicator dot is on 1 or lower. 9. Store away from children. 3. Ignite as shown by Figure 5. 1 Trouble - shooting 4. Adjust the flame length by rotating the switch ring between position 1 and 3. I Optional Parts A vailable TROUBLE CAUSE SOLUTION DOES NOT IGNITE 1. Empty fuel 1. Refuel 2. Loosen retaining ring. screw out ejector & replace. 3. Reduce the fuel setting on the switch ring. 2. Ejector nozzle is clogged 3. Fuel setting too high SOLDERING TIPS --- LOW GAS PRESSURE 1. Forelgn object blocklngtips. 1. Clean out or replace tips. LOW FLAME 2. Cold fuel 2. Hold in handsto allow unit to warm up. -. - - - -- -. . - - - - . -- - - *. -----i5u--T HANDLE. 3. Low fuel 3. Refuel NOT ENOUGH HEAT 1. Used-up catalyst 1. Purchase new tip 2. Low fueL 2. Refuel NOTE: The Mini-Ultratorch UT-50 utilizes the energy produced while evaporating butane gas. Ambient temperatures affect operation. Adjust the unit as necessary. CARRYING STRAP . Sizelwithout cap 165 mm with c a ~ 173 mm arld turning right till tight. Soldering Iron 200-45O0C1392-842°F equivalent to 80 watt electric solderina iron 1. Avoid filling in areas where flames are present. 2. Be sure to turn switch ring "off" after use. Keep protective cap on unit when not in use. 3. Do not use alcohol or alcohol base cleaner on fuel window. Flameless Heat Tool 430°C/806"F max. Butane Torch 1300°C(2372'F)max. Operating Time/full tank Approx. 20 min. Specifications may change without notice.
71-01-02 价格&库存
很抱歉,暂时无法提供与“71-01-02”相匹配的价格&库存,您可以联系我们找货
