SMD1
Datasheet revision 1.0
www.chipquik.com
SMD Removal Kit (Chip Quik® Alloy 2.5ft, flux, alcohol pads) leaded
Product Highlights
Easily remove SMD parts with Chip Quik® removal alloy
Reduce heat and reduce damage to circuit boards and SMD parts during removal
Comes with SMD291 flux
Specifications
Alloy:
Flux Type:
Flux Classification:
Melting Point:
Chip Quik®
No-Clean
REL0
58°C (136°F)
Chip Quik® Instructions
1
Apply Chip Quik flux to all leads of SMD with syringe or flux applicator.
Melt Chip Quik low temperature alloy uniformly on all pins of SMD.
2
3
Maintain alloy in molten state long enough for complete reflow.
Lift chip from board with dental pick or vacuum pen.
Thoroughly clean site with swab dipped in flux while applying heat.
4
1
Clean thoroughly with alcohol pad.
© 1994-2015 Chip Quik® Inc.
SMD Removal
(With solder iron or warm air bath)
Apply flux to all leads.
Melt CHIP QUIK® uniformly on all pins.
Maintain alloy in molten state long enough to release chip.
CLEAN UP
While molten, use cotton swab and flux to move excess to an unused section of board.
While applying heat, polish each pad with a swab and flux until thoroughly clean.
At room temperature, clean residue with alcohol pad.
You are now ready to install the new chip.
2.5 ft of Chip Quik® material, removes 1250 to 1500 SMD pins.
Conforms to the following Industry Standards:
J-STD-006C, Amendments 1 & 2 (Solder Alloys and Fluxed/Non-Fluxed Solders):
RoHS 2 Directive 2011/65/EU:
2
Yes
No
很抱歉,暂时无法提供与“SMD1”相匹配的价格&库存,您可以联系我们找货
