SMD8NL
SMD8NL
    CHIPQUIK
    REMOVAL ALLOY 8' LEAD FREE
SMD8NL 数据手册
SMD8NL Datasheet revision 1.0 www.chipquik.com Chip Quik Removal Alloy (8ft. In 15-6.5in. Lengths) lead-free Product Highlights Easily remove SMD parts with Chip Quik® removal alloy Reduce heat and reduce damage to circuit boards and SMD parts during removal Use with SMD291 flux RoHS II and REACH compliant Specifications Alloy: Melting Point: Chip Quik® lead-free 79-91°C (174-195°F) Chip Quik® Instructions 1 2 3 4 1 Apply Chip Quik flux to all leads of SMD with syringe or flux applicator. Melt Chip Quik low temperature alloy uniformly on all pins of SMD. Maintain alloy in molten state long enough for complete reflow. Lift chip from board with dental pick or vacuum pen. Thoroughly clean site with swab dipped in flux while applying heat. Clean thoroughly with alcohol pad. © 1994-2015 Chip Quik® Inc. SMD Removal (With solder iron or warm air bath) • Apply flux to all leads. • Melt CHIP QUIK® uniformly on all pins. • Maintain alloy in molten state long enough to release chip. • Lift chip from board with dental pick or vacuum pen. CLEAN UP • While molten, use cotton swab and flux to move excess to an unused section of board. • While applying heat, polish each pad with a swab and flux until thoroughly clean. • At room temperature, clean residue with alcohol pad. • You are now ready to install the new chip. 2.5 ft of Chip Quik® material, removes 1250 to 1500 SMD pins. Conforms to the following Industry Standards: J-STD-006C, Amendments 1 & 2 (Solder Alloys and Fluxed/Non-Fluxed Solders): RoHS 2 Directive 2011/65/EU: 2 © 1994-2015 Chip Quik® Inc. Yes Yes
SMD8NL 价格&库存
很抱歉,暂时无法提供与“SMD8NL”相匹配的价格&库存,您可以联系我们找货
