18 TURNS CERMET TRIMMERS
RoHS compliant
CT-94
INTERNAL STRUCTURE
⑩
② ①
③
⑨
④
⑤
⑥
⑦
Part name
■ FEATURES
RoHS compliant
Thin body design (4.8 mm thick)
18 turns, sealed, precision type
Resin material is UL Recognized 94V-0
⑧
Material
①
Housing
②
Base element
③
Wiper
④
Resistive element
RuO2 cermet
⑤
Electrode
Ag-Pd cermet
⑥
Adhesive
Epoxy
⑦
Terminal pin
⑧
Rotor gear
⑨
Rubber cushion
⑩
Shaft
Polybutyleneterephthalate
Ceramic
Multi metal alloy
Copper, Tin-plated
Polyamide
Silicone rubber
Brass, Nickel-plated
■ PART NUMBER DESIGNATION
C T - 9 4 E W 1 kΩ ( 1 0 2 )
Series name
Terminal pin
E:Sn (Lead-free)
Product shape
W, Y :Top adjustment
X, P, Z :Side adjustment
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Resistance code
Resistance value
CT-94
CERMET TRIMMERS
■ LIST OF PART NUMBERS
Top adjustment
Form of packaging
Shape of
terminal
(Top view)
Adjustment
position
③
③
Plastic bag
②
③
②
③
①
③
①
②
CT-94EZ
①
■ ELECTRICAL CHARACTERISTICS
10 Ω ~ 2 MΩ
± 10 %
Power ratings
0.5 W (70 °C) 0 W (125 °C)
Resistance law
Linear law
DC300 V or power rating, whichever is smaller
Maximum wiper current 100 mA or power rating, whichever is smaller
Effective electrical turn
15 turns
End resistance
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
Dielectric strength
Net weight
5 kΩ
pack
②
Maximum input voltage
2 kΩ
2 MΩ
50 pcs./
③
①
③
Resistance tolerance
1 kΩ
1 MΩ
The products indicated by → mark are manufactured upon
receipt of order basis.
CP-94EP
②
Nominal resistance range
50 Ω 100 Ω 200 Ω
②
①②
③
CT-94EX
500 Ω
20 kΩ → 25 kΩ 50 kΩ 100 kΩ 200 kΩ → 250 kΩ 500 kΩ
※ The above part numbers are all available with the respective
combination of (Fig. 1).
※ Verify the above part numbers when placing orders.
CT-94EW
①
①
10 kΩ
Fig.1
CT-94EY
①
③
Side adjustment
(↑ Adjustment
direction)
→ 10 Ω → 20 Ω
Pieces in
package
②
②
③
①
①
②
〈Nominal resistance values〉
−55 ~ 125 °C
10 Ω , 20 Ω : ± 250 10-6/°C maximum
50 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
1000 MΩ minimum (DC500 V)
AC900 V, 60 s
Approx. 0.88 g (CT-94EP)
Approx. 0.92 g (CT-94EW, EX, EY, EZ)
■ MECHANICAL CHARACTERISTICS
Mechanical turn
18 turns
Operating torque
35 mN·m {357 gf·cm} maximum
Mechanical stop
Clutch action
200 cycles [ΔR/R ≦ ± (2 Ω + 3 %)]
Rotational life
Terminal strength
10 N {1.02 kgf} minimum
(Tensile strength)
Thrust to shaft
Solderability
245 ± 3 °C, 2 ~ 3 s
{ }:Reference only
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Specifications
Thermal shock
−65 ~ 125 °C (0.5 h),
5 cycles
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
−10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
[ΔR/R ≦ 2 %]
Humidity
Shock
981 m/s , 6 ms
6 directions for 3 times each
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.5 W, 1000 h
2
Low temp. operation
−55 °C, 2 h
High temp. exposure
125 °C, 250 h
Immersion seal
85 °C, 60 s
Flow
260 ± 3 °C, 5 ~ 6 s, two times
Soldering heat maximum
Manual soldering
380 ± 10 °C, 3 ~ 4 s
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 3 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 2 %]
[ΔR/R ≦ 3 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
[ΔR/R ≦ 1 %]
ΔR/R:Change in total resistance
S.S. :Setting stability
CT-94
CERMET TRIMMERS
■ MAXIMUM INPUT RATINGS
Nominal resistance values ( Ω )
Resistance code
10
100
200
500
Maximum input voltage (V)
Maximum wiper current (mA)
100 1.00 100
200 2.00 100
500 5.00 100
101
7.07
70.7
201
10.0
50.0
501
15.8
31.6
1 k
102
22.4
22.4
2 k
202
31.6
15.8
5 k
502
50.0
10.0
10 k
103
70.7
7.07
20 k
203
100
5.00
25 k
253
112
4.48
50 k 503 158 3.16
100 k
200 k
250 k
500 k
1 M
2 M
104
204
254
504
105
205
224
300
300
300
300
300
2.24
1.50
1.20
0.60
0.30
0.15
The products indi-cated by → mark are manufactured upon receipt of order basis.
■ OUTLINE DIMENSIONS
● CT-94EW
Top adjustment
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
Φ 2.3, Slot 0.6 W × 0.8 D
9.6
①
5 min.
2
9.6
1.4
3
1.1
2.5
1
1.3
3 – Φ 0.5±0.05
2.3
Resistace/Date code and Lead-free Identification mark
● CT-94EX
Side adjustment
1.4
1.3
3 –Φ 0.5±0.05
1.1
9.6
2.5
3
2
9.6
5 min.
2.5
1
4.8
③
CW rotation
2.5
4.8
2.3
②
CT-94
CERMET TRIMMERS
● CT-94EP
Side adjustment
①
2.5
3 – Φ 0.5±0.05
2.5
1.3
4.8
7±2
1
1.1
4.8
9.6
3 –Φ 0.5±0.05
2
1
2.5
9.6
1.4
3
2.5
● CT-94EY
Top adjustment
1.1
1.3
7±2
1.1
2.5
● CT-94EZ
Side adjustment
1.4
3 – Φ 0.5±0.05
2.5
1.3
2
1.1
9.6
3
4.8
Resistace/
Date code
2.5
1
9.6
7±2
■PACKAGING SPECIFICATIONS
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 100 pcs. per box.
1.1
2.5
2.5
1.4
9.6
2
9.6
③
CW rotation
3
②
很抱歉,暂时无法提供与“CT94EX503”相匹配的价格&库存,您可以联系我们找货
