14 TURNS CERMET TRIMMERS
RJ-5
RJ-5 構造図
RoHS compliant
INTERNAL STRUCTURE
①
⑩
②
③
④
⑤
⑥
⑦
Part name
⑧
⑨
Material
■ FEATURES
①
Housing
②
Base element
③
Electrode
Ag-Pd cermet
④
Resistive element
RuO2 cermet
⑤
Adhesive
⑥
Wiper
⑦
Terminal pin
⑧
Rubber cushion
⑨
Rotor gear
⑩
Shaft
RoHS compliant
Fine setting is possible
Sealed construction (Washable: Refer to 698)
Resin material is UL Recognized 94V-0
Polybutyleneterephthalate
Ceramic
Epoxy
Multi metal alloy
Copper, Tin-plated
Silicone rubber
Polyamide
Brass, Nickel-plated
■ PART NUMBER DESIGNATION
R J - 5 E W 1 0 0 kΩ ( 1 0 4 )
Series name
Resistance code
Terminal pin
E:Sn (Lead-free)
Product shape
W :Top adjustment
X :Side adjustment
P :Side adjustment
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Resistance value
RJ-5
CERMET TRIMMERS
■ LIST OF PART NUMBERS
Adjustment Shape of terminal
position
(Top view)
③
①
Form of packaging
Plastic bag
Pieces in
package
Side
adjustment
(↑Adjustment
direction)
1 kΩ
2 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
2 MΩ
5 kΩ
Fig. 1
RJ-5EW
The products indicated by → mark are manufactured upon receipt of
order basis.
①
50 pcs./pack
RJ-5EX
②
①
20 kΩ
※ The above part numbers are all available with the respective
combination of (Fig. 1).
※ Verify the above part numbers when placing orders.
②
③
→10 Ω →20 Ω 50 Ω 100 Ω 200 Ω 500 Ω
10 kΩ
③
②
RJ-5EP
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
Resistance tolerance
10 Ω ~ 2 MΩ
± 10 %
Power ratings
0.25 W (85 °C) 0 W (120 °C)
Resistance law
Linear law
Maximum input voltage DC200 V or power rating, whichever is smaller
Maximum wiper current 100 mA or power rating, whichever is smaller
Effective electrical turn
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
Temp. coefficient
Insulation resistance
Mechanical turn
14 turns
Operating torque
20 mN·m {204 gf·cm} maximum
Mechanical stop
Clutch action
Rotational life
Terminal strength
Thrust to shaft
200 cycles
10 Ω ~ 200 Ω [ΔR/R ≦ ± (0.5 Ω +3 %)]
500 Ω ~ 2 MΩ [ΔR/R ≦ ± (0.5 Ω +2 %)]
10 N {1.02 kgf} minimum
(Tensile strength)
5 N {0.51 kgf} minimum
Solderability
245 ± 3 °C, 2 ~ 3 s
{ }:Reference only
11 turns
End resistance
Operating temp. range
■ MECHANICAL CHARACTERISTICS
−55 ~ 120 °C
10 Ω ~ 50 Ω : ± 250 10 /°C maximum
100 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
-6
1000 MΩ minimum (DC500 V)
Dielectric strength
AC600 V, 60 s
Net weight
Approx. 0.37 g
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Thermal shock −65 ~ 125 °C (0.5 h), 5 cycles
−10 ~ 65 °C (80 ~ 98 %),
Humidity
10 cycles, 240 h
981
m/s2, 6 ms
Shock
6 directions for 3 times each
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
85 °C, 0.25 W, 1000 h
Low temp. operation
− 55 °C, 2 h
High temp. exposure
120 °C, 250 h
Immersion seal
85 °C, 60 s
Soldering heat
Flow
260 ± 3 °C, 5 ~ 6 s, two times
maximum
Manual soldering
380 ± 10 °C, 3 ~ 4 s
Specifications
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 1 %]
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
[ΔR/R ≦ 1 %]
ΔR/R:Change in total resistance
S.S. :Setting stability
RJ-5
CERMET TRIMMERS
■ MAXIMUM INPUT RATINGS
Nominal resistance values ( Ω )
Resistance code
Maximum input voltage (V)
Maximum wiper current (mA)
10
100
200
500
100 1.00 100
200 2.00 100
500
3.53
70.7
101
5.00
50.0
201
7.07
35.3
501
11.1
22.3
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
15.8
22.3
35.3
50.0
70.7
111
15.8
11.1
7.07
5.00
3.53
2.23
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
158
200
200
200
200
1.58
1.00
0.40
0.20
0.10
■ OUTLINE DIMENSIONS
manufactured upon
receipt of order
basis.
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
● RJ-5EW
Top adjustment
①
φ1.6, Slot 0.6 W × 0.8 D
Resistance code & Production date code
③
CW rotation
3 –φ0.4±0.05
Lead-free Identification mark
1
3
2.5
2
2.5
0.9
6
②
1
4.3
1
6.75
7±2
2.5
1.2
2.5
1.2
● RJ-5EX
Side adjustment
3 –φ0.4±0.05
0.9
2.5
2
6
3
2.5
1
1
● RJ-5EP
Side adjustment
6.75
Resistance code &
1
7±2
3 –φ0.4±0.05
3
2.5
2.5
0.9
6.4
2
2.5
1
6.75
4.5
7±2
1
3.2
1
3.2
4.3
RJ-5
CERMET TRIMMERS
■PACKAGING SPECIFICATIONS
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
很抱歉,暂时无法提供与“RJ5EX101”相匹配的价格&库存,您可以联系我们找货
