RJ13PR253
RJ13PR253
    NIDEC(尼得科)
    精密微调电阻 25KΩ ±10% 3/4W ±100ppm/℃
RJ13PR253 数据手册
RJ-13 SINGLE TURN CERMET TRIMMERS RJ-13 構造図 RoHS compliant INTERNAL STRUCTURE ② ① ⑩ ⑨ ③ ④ ⑧ ⑤ ⑥ Part name ■ FEATURES ● RoHS compliant ● Wide resistance range from10 Ω to 5MΩ ● Precious metal alloy wiper ● Resin material is UL Recognized 94V-0 ⑦ Material ① Rotor Polybutyleneterephthalate ② Cover Stainless steel ③ Electrode Ag-Pd cermet ④ Resistive element RuO2 cermet ⑤ Base element ⑥ Terminal pin ⑦ Adhesive Epoxy ⑧ “O” ring Silicone rubber ⑨ Wiper Multi metal alloy ⑩ Rubber cushion Silicone rubber Ceramic Nickel, Gold-plated ■ PART NUMBER DESIGNATION R J - 1 3 P 2 0 kΩ ( 2 0 3 )  Resistance code Series name  Resistance value Product shape P :Top adjustment B :Panel mount S :Side adjustment PR :Top adjustment with knob SR :Side adjustment with knob ※ Please refer to the LIST OF PART NUMBERS when placing orders. RJ-13 CERMET TRIMMERS ■ LIST OF PART NUMBERS Adjustment Shape of terminal position (Top view) Top adjustment ② ① ③ 〈Nominal resistance values〉 Form of packaging Pieces in package Plastic bag RJ-13P 50 pcs./pack ③ ③ ① 10 kΩ 1 MΩ 2 MΩ → 5 MΩ Fig. 1 The products indicated by of order basis. 25 pcs./pack ③ RJ-13S ③ RJ-13SR → mark are manufactured upon receipt ② ① ■ ELECTRICAL CHARACTERISTICS Nominal resistance range 10 Ω ~ 5 MΩ Resistance tolerance ± 10 % ■ MECHANICAL CHARACTERISTICS Mechanical angle 270 ° (1 turn) Operating torque 3 ~ 35 mN·m {30.6~357 gf·cm} Stop strength Power ratings 100 mN·m {1.02 kgf·cm} 0.75 W (70 °C) 0 W (120 °C) Rotational life Resistance law Linear law Maximum input voltage DC300 V or power rating, whichever is smaller Terminal to strength 200 cycles 10 Ω ~ 200 Ω [ΔR/R ≦ ± (0.5 Ω +3 %)] 500 Ω ~ 5 MΩ [ΔR/R ≦ ± (0.5 Ω +2 %)] 20 N {2.04 kgf} minimum (Tensile strength) 10 N {1.02 kgf} minimum Thrust to rotor Maximum wiper current 100 mA or power rating, whichever is smaller Effective electrical angle 1 % or 2 Ω , whichever is greater C.R.V. 1 % or 3 Ω , whichever is greater Operating temp. range Temp. coefficient Insulation resistance Dielectric strength Solderability 245 ± 3 °C, 2 ~ 3 s { }:Reference only 230 ° (1 turn) End resistance Net weight 5 kΩ RJ-13PR ② Side adjustment (↑Adjustment direction) 100 kΩ 200 kΩ → 250 kΩ 500 kΩ 2 kΩ RJ-13B ② ① 20 kΩ → 25 kΩ 50 kΩ 1 kΩ ※ The above part numbers are all available with the respective combination of (Fig. 1). ※ Verify the above part numbers when placing orders. ② ① → 10 Ω → 20 Ω 50 Ω 100 Ω 200 Ω 500 Ω −55 ~ 120 °C 10 Ω , 20 Ω , 5 MΩ : ± 250 10-6/°C maximum 50 Ω ~ 2 MΩ : ± 100 10-6/°C maximum 1000 MΩ minimum (DC500 V) AC900 V, 60 s Approx. Approx. Approx. Approx. Approx. 1.90 g (RJ-13P) 4.50 g (RJ-13B) 2.15 g (RJ-13PR) 2.50 g (RJ-13S) 2.78 g (RJ-13SR) ■ ENVIRONMENTAL CHARACTERISTICS Test item Thermal shock Humidity Shock Test conditions Specifications −65 ~ 125 °C (0.5 h), 5 cycles −10 ~ 65 °C (80 ~ 98 %), 10 cycles, 240 h 981 m/s2, 6 ms 6 directions for 3 times each [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] Vibration (Amplitude) 1.52 mm or (Acceleration) 196 m/s2, 10 ~ 2000 Hz, 3 directions, 12 times each Load life 70 °C, 0.75 W, 1000 h Low temp. operation −55 °C, 2 h High temp. exposure 120 °C, 250 h Immersion seal 85 °C, 60 s Flow Soldering heat [ΔR/R ≦ 1 %] [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] [ΔR/R ≦ 2 %] [S.S. ≦ 1 %] [ΔR/R ≦ 1 %] [S.S. ≦ 2 %] [ΔR/R ≦ 2 %] [S.S. ≦ 2 %] No leaks (No continuous bubbles) 260 ± 3 °C, 5 ~ 6 s, two times maximum [ΔR/R ≦ 1 %] Manual soldering 380 ± 10 °C, 3 ~ 4 s ΔR/R:Change in total resistance S.S. :Setting stability RJ-13 CERMET TRIMMERS ■ MAXIMUM INPUT RATINGS Nominal resistance valus ( Ω ) Resistance code → 10 → 20 50 100 200 500 Maximum input voltage (V) Maximum wiper current (mA) 100 1.00 100 200 2.00 100 500 5.00 100 101 8.66 86.6 201 12.2 61.0 501 19.4 38.8 1 k 102 27.4 27.4 2 k 202 38.7 19.3 5 k 502 61.2 12.2 10 k 103 86.6 8.66 20 k 203 122 6.10 → 25 k 253 137 5.48 50 k 503 194 3.88 → → 100 k 200 k 250 k 500 k 1 M 2 M 5 M 104 204 254 504 105 205 505 RJ-13P 外形図 274 300 300 300 300 300 300 2.74 1.50 1.20 0.60 0.30 0.15 0.06 ■ OUTLINE DIMENSIONS  ● RJ-13P Top adjustment The products indicated by → mark are manufactured upon receipt of order basis. Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) Resistance code ① 3 –Φ0.7±0.05 270˚ Nom. ③ CW rotation 2 RJ-13B 外形図 ● RJ-13B Panel mount 2.5 Φ 12.4 +– 0.4 0.1 ② 1 3 Production date code 6.3 0.7 W × 5 L × 1 D M5 (P = 0.8 L = 6 min.) Nut M5, t = 3.2 Washer t = 1 Φ 14 max. 7.5±2 2.5 2.5 Resistance code & Production date code 2 3 –Φ 0.7±0.05 Red paint 2.5 Φ9 Φ3 RJ-13PR 外形図 0.6 3 1 90˚ 7 7.5±0.5 7±2 1 2.5 2.5 Mechanical stops Resistance code 3 – Φ 0.7±0.05 Straight knurl 2 2.5 +0.4 Φ 12.4 –0.1 270˚ Nom. Φ 4.90.2 ● RJ-13PR Top adjustment with knob ストッパ位置 1 3 Production date code 0.7 W × 3.8 L × 1.1 D 7±0.5 6.3 17±2 2.5 2.5 Shaft details RJ-13 CERMET TRIMMERS ■ OUTLINE RJ-13S 外形図 DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● RJ-13S Side adjustment ① ③ CW rotation ② 0.7 W × 5 L × 1 D Resistance code Adjustment Production date code 3 8.8 2 2.5 7.5±2 J-13SR 外形図 1.2 7.3 +0.4 13.6–0.1 2.5 1 +0.4 –0.1 270˚ Nom. 2.5 12.5+0.4 –0.1 3 – Φ 0.7±0.05 ● RJ-13SR Side adjustment with knob Φ 4.9±0.2 270˚ Nom. Straight knurl Production date code 3 1.2 13.6+0.4 –0.1 2.5 1 2 2.5 7.5±2 7.3 7±0.5 Resistance code 8.8+0.4 –0.1 0.7 W × 3.8 L × 1.1 D 2.5 12.5+0.4 –0.1 3 –Φ 0.7±0.05 ■PACKAGING SPECIFICATIONS ● Unit of bulk pack in a plastic bag is 25 pcs. per pack, only that RJ-13P is 50 pcs. per pack. ● Boxing of bulk in a plastic bag is performed with 50 pcs. per box, only that RJ-13P is 100 pcs. per box.
RJ13PR253 价格&库存
很抱歉,暂时无法提供与“RJ13PR253”相匹配的价格&库存,您可以联系我们找货
