PSP 3000 2-Axis Analog Thumb Joystick
PRODUCT ID: 3103
Description
Sometimes a simple analog control device can be the perfect tactile solution for your project, but
PSP 3000 2WKH\FDQEHVXUSULVLQJO\KDUGWRFRPHE\/XFNLO\ZH
YHIRXQGDORZFRVWTXDOLW\¬P
Axis Analog Thumb Joystick to fulfill your directional analog input needs!
This is a replacement component for the PSP 3000, but we think they'd make for a great little
joystick/thumbstick add-on for a wearable, or portable project. It's similar to this other version, but has a
cable for connecting rather than direct-solder
The joystick is a 'self-centering' analog-type. That means it basically acts like two 10K
potentiometers, one for up/down and another for left/right. It has a built-in flex cable that can
plug right into a fine pitch (0.5mm) connector. The four pins connect to power, ground and then
two analog outputs. As the joystick is moved around, the voltage will follow the motion. When
you release the joystick it will center itself.
The connector is very fine pitch, and not easy to solder to - so we suggest using our 4-pin breakout board
to make it easier to connect to a breadboard (it is not included!)
Technical Details
Product Dimensions: 44.1mm x 18.6mm x 11.7mm / 1.7" x 0.7" x 0.5"
Product Weight: 1.8g / 0.1oz
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3103”相匹配的价格&库存,您可以联系我们找货
