M22L10-000-102
M22L10-000-102
    NIDEC(尼得科)
    电位器(操纵杆) 1KΩ ±5% ±50ppm/℃
M22L10-000-102 数据手册
WIREWOUND MULTITURN TYPE M22L10 series Basic construction Wirewound multiturn type RoHS compliant ■ FEATURES OFine setting is possible OLong life ORoHS compliant ■ PART NUMBER DESIGNATION M22L10-000-102 Series name Nominal resistance value(Ω) 000-102: 1 k 000-202: 2 k 000-502: 5 k 100-103:10 k 100-203:20 k ■ LIST OF PART NUMBERS Nominal resistance value (Ω) Part number 1k M22L10-000-102 2k M22L10-000-202 5k M22L10-000-502 10 k M22L10-100-103 20 k M22L10-100-203 M22L10 series POTENTIOMETERS ■ STANDARD SPECIFICATIONS Item Resistance torelance Independent linearity End resistance, maximum Effective electrical angle Mechanical angle Power rating Dielectric strength Insulation resistance Rotational torque Strength of tighten screw Stop strength Peak noise Temp. coefficient of resistance Operating temp. range Rotational life Net weight Protection grade Part number M22L10 series ±5 ± 0.2 5Ω 3600° 3600° +10° 0 2 1000 1 min 1000 (at DC 500 V) 9.81 {100} 0.98 {10} 0.196 {2} 50 (at 4 min-1) ± 50 − 40 ~ 85 5 million turns (At the reciprocation of ten rotations) Approx. 19 IP40 % % W Vrms MΩ minimum mN·m {gf·cm} maximum N·m {kgf·cm} maximum N·m {kgf·cm} maximum Ω maximum ppm/°C °C g ■ 120,1$/5(6,67$1&(‡5(62/87,21‡5$7('92/7$*(‡5$7('&855(17 Nominal resistance value (Ω) Resolution(%) M22L10 series Rated voltage(V) M22L10 series Rated current(mA) M22L10 series 1k 2k 5k 10k 20 k 0.025 0.020 0.014 0.018 0.014 44.7 63.2 100.0 141.1 200.0 44.7 31.6 20.0 14.1 10.0 ■ 5$7('32:(5'(5$7,1*&859( Power rating ratio (%) 100 + 40 – 40 + 85 Ambient temperature (℃) ■ OUTLINE DIMENSIONS –0.01 –0.04 0.8 6 R1 m ax (Wiring diagram) < Accessories > 1 M9 P0.75 3 φ 22 φ 10.3 3 2 40° 3–3 M9 P0.75 4.5 0 φ 6 –0.02 1 4 (Unit: mm) 3 – φ 1.5 1.2 1.6 18.5 ± 0.4 6.4 15 (23) 12 2 φ 9.4 0.5 φ 12.9 1 2 CW
M22L10-000-102 价格&库存
很抱歉,暂时无法提供与“M22L10-000-102”相匹配的价格&库存,您可以联系我们找货
