DSK-3R3H334T-HL
DSK-3R3H334T-HL
    ELNAAMERICA
    超级电容器 - 330mF -20~+80% 3.3V
DSK-3R3H334T-HL 数据手册
DS,DSK-614,621 DS,DSK-614,621 ELECTRIC DOUBLE LAYER ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP” CAPACITORS “DYNACAP” ® ® GREEN 60˚C CAP 70˚C Coin Cell Capacitors ● ● ● ● Reflow soldering method available. Unlike batteries, the number of charging/ discharging cycles unlimited and rapid charging/ discharging is possible. Unlike batteries, excellent charge and discharge characteristics with no chemical reactions. 1.8mm height type 614 made lineup in the DS, DSK series. Low profile DS DS (614) (621) For higher voltage tolerant Low profile DSK DSK (614) (621) Specifications Item Performance Series Name Series DS Max.operating voltage (V) 2.5 3.3 Category temperature range (℃) ー25 to +70 ー10 to +60 Tolerance at rated capacitance (%) ー20 to +80 ー20 to +80 Internal resistance (Ω) at 1 kHz Characteristics at high and low temperature Endurance Series DSK Size code 614 621 Size code 614 621 Rated capacitance (F) 0.2 0.33 Rated capacitance (F) 0.2 0.33 Internal resistance (Ω Max.) 100 100 Internal resistance (Ω Max.) 200 200 Size code 614 Size code 614 621 621 Percentage of capacitance change Within ±30% of the value at 20℃ Percentage of capacitance change Within ±50% of the value at 20℃ Within ±50% of the value at 20℃ Within ±30% of the value at 20℃ Internal resistance Less than five times of the value at 20℃ Less than five times of the value at 20℃ Internal resistance Size code Test time and temp. Percentage of capacitance change Internal resistance 614 70℃ 1000 hours 621 70℃ 500 hours Within ±30% of the initial measured value Within ±30% of the initial measured value 1kΩ Max. 400 Ω Max. Size code Test time and temp. Percentage of capacitance change Internal resistance Shelf life Less than five times of the initial specified value Less than five times of the value at 20℃ Same as endurance. 614 60℃ 1000 hours 621 60℃ 500 hours Within ±30% of the initial measured value Within ±30% of the initial measured value 2k Ω Max. 800 Ω Max. Same as endurance. Applicable standards Conforms to JIS C5160-1 2009(IEC 62391-1 2006) Outline Drawing Unit : mm Teriminal shaped :H2 (614) Recommended land pattern size Unit : mm Terminal shaped :H(621) 0 0.15±0.05 3.0±0.2 2.0±0.1 8.3±0.1 2.0±0.3 0.8±0.2 1.7±0.1 2.5±0.5 1.4±0.3 1.0±0.2 0.9±0.2 1.3±0.3 L Sn planted 0.15±0.05 +0.1 L−0.2 11.7Max. +0.1 −0.2 2.8±0.2 4.0±0.2 0.15±0.05 2.25±0.3 1.8 Max. 2.5±0.3 4.0±0.5 1.2±0.2 5−0.5 φD±0.2 0 4−0.5 0.15±0.05 3.0±0.2 ※Please consult with us about other terminal form. Part numbering system (example : 614, 2.5V0.2F, terminal shaped : H2) DS Series code ̶ 2R5 Max.operating voltage symbol H 204 T614 Rated capacitance symbol Additional symbol ̶ H2 L Terminal shaped Taping symbol Part numbering system (example:621, 3.3V0.33F, terminal shaped:H) DSK 3R3 Max.operating voltage symbol H 334 T ated capacitance symbol Additional symbol ̶ H L Terminal shaped Taping symbol Part number is refer to following table. EDLC Part number is refer to following table. Series code ̶ Standard Ratings Max. operating voltage (V) ELNA Parts No. φD×L (mm) 2.5 Rated capacitance (F) 0.2 DS-2R5H204T614-H2L 6.8×1.4 3.3 0.2 DSK-3R3H204T614-H2L 6.8×1.4 2.5 0.33 DS-2R5H334T-HL 6.8×2.1 3.3 0.33 DSK-3R3H334T-HL 6.8×2.1 *Soldering conditions are described on page 191. NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 211 CAT.No.2015/2016E
DSK-3R3H334T-HL 价格&库存
很抱歉,暂时无法提供与“DSK-3R3H334T-HL”相匹配的价格&库存,您可以联系我们找货
