Effective June 2017
Supersedes August 2013
Technical Data 4403
PHV Supercapacitors
Cylindrical pack
HALOGEN
HF
Pb
FREE
Features
Large capacitance for high energy density
Ultra-low ESR for high power density
Applications
Description
Eaton supercapacitors are unique, ultra-high
capacitance devices utilizing electrochemical
double layer capacitor (EDLC) construction
combined with new, high performance
materials. This combination of advanced
technologies allows Eaton to offer a wide variety
of capacitor solutions tailored to specific
applications that range from a few micro-amps
for several days to several amps for
milliseconds.
Pulse Power
Bridging or hold-up power
PHV Supercapacitors
Technical Data 4403
Effective June 2017
Ratings
Capacitance
0.5 F to 5.0 F
Maximum working voltage
5.4 V
Surge voltage
6.0 V
Capacitance tolerance
-10% to +30% (+20 °C)
Operating temperature range
-40 °C to +65 °C
Extended operating temperature range
-40 °C to +85 °C (with linear derating to 4.0 V @ +85 °C)
Specifications
Nominal
Capacitance (F)
Vertical
Part Number
Horizontal
Part Number
Maximum ESR
(Ω) (Equivalent Series
Resistance) Measured
@ 1 kHz
100Hz
Nominal leakage
current (µA) after
100 hours @ 5 V,
+20°C
Nominal
dimensions (mm)
Typical mass
(grams/piece)
0.5
PHV-5R4V474-R
PHV-5R4H474-R
0.300
0.40
13
8.5 x 16.8 x 14.0
2.6
1.5
PHV-5R4V155-R
PHV-5R4H155-R
0.120
0.16
18
8.5 x 16.8 x 21.5
3.0
2.5
PHV-5R4V255-R
PHV-5R4H255-R
0.075
0.08
24
10.5 x 20.8 x 22.5
4.5
3.0
PHV-5R4V305-R
PHV-5R4H305-R
0.075
0.08
25
8.5 x 16.8 x 31.5
4.8
5.0
PHV-5R4V505-R
PHV-5R4H505-R
0.065
0.07
28
10.5 x 20.8 x 32
6.8
Performance
Parameter
Capacitance change
(% of initial value)
ESR
(% of max. initial value)
Life (1000 hours @ +65 °C @ 5.4 Vdc)
≤ 30%
≤ 200%
Storage - Low and High Temperature (1000 hours @ -40 °C and +85 °C)
≤ 30%
≤ 200%
Dimensions (mm)
Vertical Part Number
Horizontal Part Number
A
B
C
d’
D
D’
E
E’
F
P
PHV-5R4V474-R
PHV-5R4H474-R
9.0
17.3
14.5
0.5
25
11.8
PHV-5R4V155-R
PHV-5R4H155-R
9.0
17.3
22.0
0.5
25
11.8
PHV-5R4V255-R
PHV-5R4H255-R
PHV-5R4V305-R
PHV-5R4H305-R
PHV-5R4H505-R
11.0
21.3
9.0
17.3
11.0
21.3
Maximum
23.0
32.5
32.5
0.6
0.5
0.6
± 0.02
15
15
25
25
25
2.0
2.0
± 0.5
5.3
11.8
5.3
PHV-5R4V505-R
Tolerances
Minimum
Note: Longer lead is positive.
B
Vertical
C
B
Horizontal
F
C
A
A
d'
d'
C
C
A
A
D
F
P
E
D'
E'
P
Positive lead
Positive lead
P
Part numbering system
P
HV
Family Code
Version
5R4
V
Voltage (V) R = Decimal
Configuration
5R4 = 5.4 V
V = Vertical
H = Horizontal
15
5
-R
Multiplier
Standard
product
Capacitance (µF)
P= Pack
Packaging information
2
Standard packaging: Bulk, 100 units per bag
Larger bulk packages available on request
www.eaton.com/electronics
Value
Example: 155 = 15 x 105 or 1.5 F
Part marking
Manufacturer
Capacitance (F)
Maximum operating voltage (V)
Family code (or part number)
Polarity marking
PHV Supercapacitors
Cylindrical pack
Technical Data 4403
Effective June 2017
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Profile Feature
Standard SnPb Solder
Lead (Pb) Free Solder
• Temperature max. (Tsmax)
100 °C
100 °C
• Time max.
60 seconds
60 seconds
D preheat to max Temperature
160 °C max.
160 °C max.
Peak temperature (TP)*
220 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Preheat and soak
Manual solder
+350 °C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended.
Reflow soldering
Do not use reflow soldering using infrared or convection oven heating methods.
Cleaning/Washing
Avoid cleaning of circuit boards, however if the circuit board must be cleaned use static or ultrasonic immersion in a standard circuit board
cleaning fluid for no more than 5 minutes and a maximum temperature of +60 °C. Afterwards thoroughly rinse and dry the circuit boards. In
general, treat supercapacitors in the same manner you would an aluminum electrolytic capacitor.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/electronoics
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4403 BU-SB13841
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“PHV-5R4V474-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+25.27439
- 50+24.73287
