DH
ELECTRIC
ELECTRICDOUBLE
DOUBLELAYER
LAYERCAPACITORS
CAPACITORS“DYNACAP”
“DYNACAP”
High Temperature Capacitors
GREEN
CAP
85˚C
High temperature tolerant (−25 to +85℃) and highly reliable.
Ideal for backing up of controls, electronic rice cooking jars,
home bakeries and the like.
DH
High temperature
Miniaturized
DB
DX
Marking color : White print on an indigo sleeve
Specifications
Item
Performance
Category temperature range (℃)
ー25 to +85
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Rated capacitance (F)
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (85℃)
0.047
0.1
0.22
0.47
0.68
1
300
200
120
50
50
30
Internal resistance (Ω Max.)
Within ±30% of the value at 20℃
Internal resistance
Less than five times of the value at 20℃
Test time
1000 hours
Within ±30% of the initial measured value
Internal resistance
Less than four times of the initial specified value
Shelf life (85℃)
Test time : 1000 hours ; Same as endurance.
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
Part numbering system (example : 5.5V0.1F)
Sleeve
0.5±0.1
5R5
Max.operating voltage
symbol
D
104
T
Rated capacitance
symbol
φD Max
6.0±1
Part number is refer to following table.
(4.0±0.5)
(3.0±0.5)
6.0±1
Series code
0.8±0.1
5.0±0.3
L Max
DH
1.2±0.1
Sn plated teminal
Standard Ratings
Max. operating voltage (V)
ELNA Parts No.
φD×L (mm)
5.5
0.047
DH-5R5D473T
13.5×9.5
5.5
0.1
DH-5R5D104T
13.5×9.5
5.5
0.22
DH-5R5D224T
13.5×9.5
5.5
0.47
DH-5R5D474T
21.5×9.5
5.5
0.68
DH-5R5D684T
21.5×9.5
5.5
1
DH-5R5D105T
21.5×9.5
EDLC
CAT.No.2015/2016E
206
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
很抱歉,暂时无法提供与“DH-5R5D104T”相匹配的价格&库存,您可以联系我们找货
