DC,DCK
Coin Cell Capacitors
ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP”
GREEN 60˚C
CAP
70˚C
• Small-sized, but large capacity.
• Unlike batteries, unlimited charge/discharge
cycles; ideal for solar watches, solar calculators,
solar remote control units, camaras and the like.
Coin Cell
DB
DC
For higher
voltage
tolerant
DCK
Specifications
Item
Performance
Series Name
DC series
Rated voltage (V)
2.5
DCK series
3.3
Category temperature range (˚C)
−25 to +70
−10 to +60
Tolerance at rated capacitance (%)
−20 to +80
−20 to +80
Rated Capacitance (F)
Internal resistance(Ω)
at 1 kHz
0.22
0.22
100
200
Characteristics at high
Percentage of capacitance change
Within ±30% of the value at 20˚C
Within ±50% of the value at 20˚C
and low temperature
Internal resistance
Less than five times of the value at 20˚C
Internal resistance
Within five times the initial specified value
Test temperature
70˚C
Test temperature
60˚C
Test time
1000 hours
Test time
1000 hours
Within ±30% of the initial measured value
Internal resistance
Within four times of the initial specified value
Internal resistance
Endurance
Test time :1000 hours ; Same as endurance.
Shelf life
Outline Drawing
Unit: mm
Terminal shaped: D
Terminal shaped: E
2.6MAX
2.3MAX
6.8
L±0.2
D±0.2
Sn+Cu plated
1.7±0.3
2.5± 0.3
0.5
0.15±0.05
0.5±0.1
2.0±0.3
Part numbering system (example: 2.5V0.22F, terminal shaped: E)
DC
2R5
Rated voltage
symbol
Series code
E
Part numbering system (example: 3.3V0.22F, terminal shaped: E)
— E
224
Rated capacitance
symbol
DCK
Additional
symbol
3R3
Rated voltage
symbol
Series code
E
— E
224
Rated capacitance
symbol
Additional
symbol
Part number is refer to below table.
Standard Ratings
Max. operating voltage(V)
Rated capacitance(F)
ELNA Parts No.
ø DxL(mm)
DC-2R5D224
2.5
0.22
6.8x2.1
DC-2R5E224U-E
DCK-3R3D224
3.3
0.22
6.8x2.1
DCK-3R3E224U-E
CAT.No.2005/2006E(2005.10.1)
148
NOTE
Design, Specifications are subject to change without notice.
Ask factory for technical specifications before purchase and/or use.
很抱歉,暂时无法提供与“DC-2R5E224U-E”相匹配的价格&库存,您可以联系我们找货
