DX-5R5L334T
DX-5R5L334T
    ELNAAMERICA
    轴向
    超级电容器 轴向 330mF -20~+80% 5.5V
DX-5R5L334T 数据手册
DX DX ELECTRIC DOUBLE LAYER CAPACITORS“DYNACAP” “DYNACAP” ELECTRIC DOUBLE LAYER CAPACITORS ® ® GREEN CAP 5.5V Miniaturized Standard Capacitors ● ● ● Smaller and lighter than Series DB. 5mm tall. Max. thin profile (H-shaped). Miniaturized but can encase up to 0.47F in 11.5×5mm case, and 1.5F in φ19.0×20.5Lmm case. 70˚C Miniaturized DX DB Marking color : White print on an indigo sleeve Specifications Item Performance Category temperature range (℃) ー25 to +70 Tolerance at rated capacitance (%) ー20 to +80 Internal resistance at 1 kHz Rated capacitance (F) Characteristics at high and low temperature Percentage of capacitance change Endurance (70℃) Percentage of capacitance change Internal resistance (Ω Max.) 0.047 0.1 0.22 0.33 120 75 75 75 0.47 0.47 75(φ11.5)30(φ19.0) 1 1.5 30 30 Within ±30% of the value at 20℃ Internal resistance Less than five times of the value at 20℃ Test time 1000 hours Within ±30% of the initial measured value Internal resistance Less than four times of the initial specified value Shelf life (70℃) Test time : 1000 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Outline Drawing Unit : mm φD±0.3 Terminal shaped : H (4.5) Sn plated (0.15) (0.15) 5.0±0.3 4.0±0.3 Sleeve Sleeve Sn plated 10.0±0.5 Note Part numbering system (example : 5.5V0.1F) ̶ 5R5 Max.operating voltage symbol Series code U 104 Terminal code (0.8) 5.0±0.5 (φ11.5 : 0.8, φ19 : 1.0) DX φD±0.3 5±0.3 L±0.5 L±0.5 12.4±0.5 (4.5) Terminal shaped : V Reted capacitance symbol Additional symbol Part number is refer to following table. Do not apply external force to products or terminals as stress such as twisting, bending, pushing, or falling of such products or terminals may remove the terminals, resulting in an open/short circuit or liquid leakage. Avoid applying excessive heat to capacitors during heating of an adhesive curing oven. For details, refer to the precautions in use of DYNACAP. Standard Ratings Max. operating voltage (V) Rated capacitance (F) 0.047 5.5 0.1 5.5 0.22 5.5 0.33 5.5 0.47 φD×L (mm) DX-5R5V473U 11.5×13.0 DX-5R5H473U 11.5× 5.0 DX-5R5V104U 11.5×13.0 DX-5R5H104U 11.5× 5.0 DX-5R5V224U 11.5×13.0 DX-5R5H224U 11.5× 5.0 DX-5R5V334U 11.5×13.0 DX-5R5H334U 11.5× 5.0 DX-5R5V474SU DX-5R5H474SU DX-5R5V474U 11.5×13.0 11.5× 5.0 19.0×20.5 5.5 1 DX-5R5V105U 19.0×20.5 5.5 1.5 DX-5R5V155U 19.0×20.5 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 201 CAT.No.2015/2016E EDLC 5.5 ELNA Parts No.
DX-5R5L334T 价格&库存
很抱歉,暂时无法提供与“DX-5R5L334T”相匹配的价格&库存,您可以联系我们找货
