DXJ-5R5L104T
DXJ-5R5L104T
    ELNAAMERICA
    轴向
    超级电容器 轴向 100mF -20~+80% 5.5V
DXJ-5R5L104T 数据手册
DXJ DXJ ELECTRICDOUBLE DOUBLELAYER LAYERCAPACITORS CAPACITORS“DYNACAP” “DYNACAP” ELECTRIC ® ® 5.5V Miniaturized z High Temperature Capacitors ● ● ● High temperature type of Series DX. 5mm tall. Max. thin profile (H-shaped). Miniaturized but can encase up to 0.33F in 11.5×5mm case, and 1.0F in φ19.0×20.5Lmm case. GREEN CAP 85℃ High temperature DXJ DX Marking color : White print on a black sleeve Specifications Item Performance Category temperature range (℃) ー10 to +85 Tolerance at rated capacitance (%) ー20 to +80 Internal resistance at 1 kHz Rated capacitance (F) 0.047 0.1 0.22 0.33 1 Internal resistance (Ω Max.) 200 150 150 150 75 Characteristics at high and low temperature Percentage of capacitance change Endurance (85℃) Percentage of capacitance change Within ±30% of the value at 20℃ Internal resistance Less than four times of the initial specified value. 1000 hours Test time Within ±30% of the initial measured value Less than four times of the initial specified value Internal resistance Shelf life (85℃) Test time : 1000 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Outline Drawing Unit : mm Terminal shaped : H (4.5) φD±0.3 φD±0.3 (0.8) (0.15) (0.15) 5.0±0.3 4.0±0.3 Sleeve Sn plated Sleeve Sn plated 10.0±0.5 Part numbering system (example : 5.5V0.1F) ̶ 5R5 Max.operating voltage symbol Series code Note 104 Terminal code (0.8) 5.0±0.5 (φ11.5 : 0.8, φ19:1.0) DXJ 5±0.3 L±0.5 L±0.5 12.4±0.5 (4.5) Terminal shaped : V Rated Capacitance symbol U Additional symbol Part number is refer to following table. Do not apply external force to products or terminals as stress such as twisting, bending, pushing, or falling of such products or terminals may remove the terminals, resulting in an open/short circuit or liquid leakage. Avoid applying excessive heat to capacitors during heating of an adhesive curing oven. For details, refer to the precautions in use of DYNACAP. Standard Ratings Max. operating voltage (V) ELNA Parts No. Rated capacitance (F) 5.5 0.047 5.5 0.1 0.22 5.5 0.33 5.5 1 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 203 11.5×13.0 DXJ-5R5H473U 11.5× 5.0 DXJ-5R5V104U 11.5×13.0 DXJ-5R5H104U 11.5× 5.0 DXJ-5R5V224U 11.5×13.0 DXJ-5R5H224U 11.5× 5.0 DXJ-5R5V334U 11.5×13.0 DXJ-5R5H334U 11.5× 5.0 DXJ-5R5V105U 19.0×20.5 CAT.No.2015/2016E EDLC 5.5 φD×L (mm) DXJ-5R5V473U
DXJ-5R5L104T 价格&库存
很抱歉,暂时无法提供与“DXJ-5R5L104T”相匹配的价格&库存,您可以联系我们找货
