GYC15003
GYC15003
    SPRAGUE-GOODMAN
    可调电容 2pF~15pF 100V 11.00 x 9.50mm
GYC15003 数据手册
Sprague-Goodman ENGINEERING BULLETIN SG-402H.1 Supercedes SG-402G FILMTRIM PLASTIC DIELECTRIC CAPACITORS ® TYPES • Six Dielectrics: - High temperature PTFE - Standard PTFE - Polypropylene - Polyimide - Polycarbonate - Polyphenyl sulfide • SMD and lead-through-hole mounting • Top, bottom and side mount models • Wide capacitance ranges • Compact sizes • Low cost for commercial/industrial applications • Linear capacitance change vs. rotation APPLICATIONS • • • • • • • Mobile Radios Transmitters Pagers Instruments Electronic Games Wireless Security and Fire Alarms CATV MODIFICATIONS AND VARIATIONS AVAILABLE • • • • • Special capacitance ranges Special terminal sizes and shapes Extended adjust shafts High temperature versions for PTFE Silver and/or gold plating Sprague-Goodman Electronics, Inc. 1700 SHAMES DRIVE, WESTBURY, NY 11590 TEL: 516-334-8700 • FAX: 516-334-8771 E-MAIL: info@spraguegoodman.com FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H 5mm TOP ADJUST 0.02 0.6 0.2 6 FEATURES 0.098 DIA 2.5 • High temperature PTFE or polyimide (PI) dielectrics • Compact size • Linear capacitance change vs. rotation 0.02 0.5 ‘H’ max 0.22 5.5 0.1 3 SPECIFICATIONS 0.2 5 Voltage Rating: 150 VDC Dielectric Withstanding Voltage: 300 VDC Contact Resistance: 0.010 Ohms max Insulation Resistance: 10 4 megohms min Torque: 15 to 200 g-cm (0.21 to 3 oz-in) ROTOR STATOR 0.043 DIA (2 HOLES) 1.1 0.051 (NOTE: FOR GZL32000) 1.3 MOUNTING HOLE LAYOUT All dimensions are in / mm. Dielectric Capacitance (pF) min max PTFE, High Temp PI 1.2 1.8 2.0 2.3 1.2 1.4 2.0 2.7 3.6 4.0 10.0 15.0 18.0 5.0 10.0 15.0 20.0 32.0 Q min (1MHz) 1500 1500 1500 1500 150 150 150 150 150 TCC (ppm / °C) 0 0 0 0 0 0 0 0 0 ± ± ± ± ± ± ± ± ± 350 300 300 300 350 350 250 250 250 Operating Temperature (°C) –40 –40 –40 –40 –40 –40 –40 –40 –40 to to to to to to to to to +125 +125 +125 +125 +85 +85 +85 +85 +85 ‘H’ max in/mm 0.20 0.23 0.24 0.24 0.20 0.20 0.23 0.23 0.25 / / / / / / / / / 5.0 5.8 6.0 6.0 5.0 5.0 5.8 5.8 6.3 Color Code Model Number Brown Black White Green Brown Black White Green None GXL4R000 GXL10000 GXL15000 GXL18000 GZL5R000 GZL10000 GZL15000 GZL20000 GZL32000 ECONOMY 7 mm TOP ADJUST 0.27 6.8 0.16 4.1 SPECIFICATIONS Operating Temperature Range: -25°C to +85°C Dielectric: Polyphenyl Sulfide Voltage Rating: 50 VDC Dielectric Withstanding Voltage: 100 VDC Insulation Resistance: 500 megohms min Torque: 20 - 200 g-cm (0.28 - 2.8 oz-in) 0.12 3.0 0.15 0.16 ± 0.01 4.0 ± 0.3 3.8 ROTOR 0.20 ± 0.02 5.0 ± 0.5 • Low cost • Compact size 2 0.059 1.5 0.26 6.5 Ammo Pack Model Number GCL10025 GCL20025 GCL30025 GCL40025 0.04 TYP 1.0 STATOR SEAL Model Number GCL10000 GCL20000 GCL30000 GCL40000 0.02 x 0.008 DP 0.5 x 0.2 DP 0.098 DIA 2.5 • High Q Bulk Pack MOUNTING HOLE LAYOUT TUNING SLOT • Low setting drift TCC Q min Color (ppm / °C) (1 MHz) Code 350 ± 500 500 Brown 350 ± 500 500 Green 350 ± 500 500 Yellow 350 ± 500 500 Blue 0.20 ± 0.01 5.0 ± 0.3 0.21 5.4 FEATURES Capacitance (pF) min max 0.7 10.0 0.8 20.0 0.9 30.0 1.0 40.0 0.051 DIA TYP 1.3 0.13 3.4 0.12 3.0 0.13 TYP 3.3 0.080 TYP 2.0 0.04 ± 0.004 TYP 1.0 ± 0.1 GCL _ _ _ 00 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H 7 mm SURFACE MOUNT FEATURES SPECIFICATIONS • Low setting drift Q min (at 10 MHz): 1000 Operating Temperature Range: -25°C to +85°C Dielectric: PTFE TCC: N100 ± 100 ppm/°C Voltage Rating: 100 VDC Dielectric Withstanding Voltage: 200 VDC Insulation Resistance: 10 4 megohms min Torque: 20-300 g-cm (0.28 - 4.2 oz-in) • High Q • Low cost • Linear Capacitance change vs. rotation • Compact size Capacitance (pF) min max 0.5 4.5 0.6 9.0 0.8 15.0 1.0 20.0 ‘ H’ max (in/ mm) 0.087 / 2.2 0.087 / 2.2 0.094 / 2.4 0.100 / 2.6 Color Code Orange Black Blue Green Model Number GSX364 GSX358 GSX365 GSX366 0.059 1.5 0.47 12 ‘H’ MAX 0.16 4.1 0.12 0.02 ± 0.002 3.0 0.4 ± .05 0.17 DIA 4.4 0.098 DIA 2.5 0.02 TYP 0.5 0.27 6.8 0.2 4 0.08 2 0.059 DIA TYP 1.5 0.01 ± 0.002 TYP 0.3 ± 0.05 COVER TAPE 0.222 5.65 0.067 1.7 0.11 2.8 0.3 8 STATOR 0.51 ± 0.02 DIA 13.0 ± 0.5 0.28 ± 0.008 7.2 ± 0.2 0.047 1.2 ROTOR COLOR CODE DISK 0.047 TYP 1.2 0.21 5.4 3.15 ± 0.2 DIA 80.0 ± 5.0 0.080 TYP 2.0 0.087 2.2 0.090 2.3 0.91 DIA 23.0 (STATOR SIDE) 0.13 3.4 0.17 4.3 13.0 ± 0.08 DIA 330.0 ± 2.0 0.094 TYP 2.4 0.531 13.5 SUGGESTED PAD LAYOUT 0.08 ± 0.008 TYP 2.0 ± 0.2 + 0.03 – 0.0 + 0.8 – 0.0 CARRIER & REEL 0.27 ± 0.01 6.8 ± 0.3 0.16 4.1 0.250 ± 0.51 TYP 6.35 ± 1.3 0.21 ± 0.01 5.4 ± 0.3 0.14 3.6 0.12 3.0 TUNING SLOT 0.059 1.5 COLOR CODED BASE 0.500 ± 0.04 TYP 12.7 ± 1.0 0.02 x 0.02 0.5 x 0.5 + 0.08 – 0.04 +2 –1 0.492 12.5 + 0.04 –0 +1 – 0.0 0.71 18.0 + 0.04 – 0.03 +1 – 0.8 0.16 DIA TYP 4.0 0.55 ± 0.04 14.0 ± 0.1 0.500 ± 0.01 TYP 12.7 ± 0.3 STATOR 0.04 1.0 0.08 2 0.630 ± 0.02 16.0 ± 0.5 0.22 ± 0.01 5.5 ± 0.3 0.13 3.2 0.63 ± 0.04 16.0 ± 0.1 0± 0.026 ± 0.004 0.65 ± 0.1 ROTOR 0.20 5.0 0.02 TYP 0.4 CARRIER 0.02 ± 0.004 TYP 0.5 ± 0.1 All dimensions are in / mm. GCL _ _ _ 25 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 3 FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H.1 7 mm SURFACE MOUNT NONMAGNETIC FEATURES SPECIFICATIONS • Low setting drift Relative Permeability: 1.0025 max Q min (at 10 MHz): 1000 Operating Temperature Range: -25°C to +85°C Dielectric: PTFE TCC: N100 ± 100 ppm/°C Voltage Rating: 100 VDC Dielectric W ithstanding Voltage: 200 VDC Insulation Resistance: 10 4 megohms min Torque: 20-300 g-cm (0.28 - 4.2 oz-in) • High Q • Low cost • Linear Capacitance change vs. rotation • Compact size Capacitance (pF) min max 0.5 4.5 0.6 9.0 0.8 15.0 1.0 20.0 ‘ H’ max (in/ mm) 0.087 0.087 0.094 0.100 / / / / Color Code 2.2 2.2 2.4 2.6 Model Number Orange Black Blue Green GSX364NM GSX358NM GSX365NM GSX366NM ‘H’ MAX 0.16 4.1 0.27 6.8 0.02 0.4 0.17 DIA 4.4 0.098 DIA 2.5 0.02 TYP 0.5 0.12 0.002 3.0 .05 0.2 4 0.08 2 0.059 DIA TYP 1.5 0.01 0.3 0.28 7.2 0.008 0.2 0.047 1.2 COLOR CODE DISK 0.047 TYP 1.2 0.087 2.2 0.47 12 0.002 TYP 0.05 COVER TAPE STATOR ROTOR 0.21 5.4 0.059 1.5 0.067 1.7 0.222 5.65 0.11 2.8 0.3 8 0.080 TYP 2.0 0.51 13.0 0.090 2.3 0.02 DIA 0.5 (STATOR SIDE) 0.13 3.4 0.17 4.3 0.094 TYP 2.4 3.15 80.0 0.2 DIA 5.0 SUGGESTED PAD LAYOUT 0.91 DIA 23.0 All dimensions are in / mm. 13.0 330.0 0.08 DIA 2.0 0.531 13.5 + 0.03 – 0.0 + 0.8 – 0.0 0.08 2.0 0.008 TYP 0.2 CARRIER & REEL SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 3A FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H 6 X 8 mm TOP/BOTTOM & SIDE ADJUST FEATURES • Compact size • High temperature PTFE dielectric • Linear capacitance change vs. rotation SPECIFICATIONS Voltage Rating: 300 VDC Dielectric Withstanding Voltage: 500 VDC Contact Resistance: 0.010 Ohms max Insulation Resistance: 10 4 megohms min Torque: 15 to 245 g-cm (0.21 to 3.4 oz-in) Capacitance (pF) Dielectric min max PTFE, High Temp 1.0 1.8 2.5 3.5 10.0 18.0 Top/Bottom Adjust Top/Bottom Adjust Side Adjust Operating Q min TCC Temperature Color 3 Lead 2 Lead (1MHz) (ppm / °C) (°C) Code Model Number Model Number Model Number 1500 1500 1500 0.29 7.4 0 ± 350 0 ± 350 0 ± 350 –40 to +125 Orange –40 to +125 White –40 to +125 Red GXE3R511 GXE10011 GXE18011 0.29 7.4 0.098 DIA 2.5 0.3 8 GXQ3R501 GXQ10001 GXQ18001 0.3 8 0.26 6.7 0.02 0.6 0.17 4.2 0.26 6.7 GXE3R501 GXE10001 GXE18001 0.3 8 0.26 6.7 0.03 0.7 0.14 3.5 0.02 0.6 0.02 0.6 0.098 DIA 2.5 0.03 0.7 0.098 DIA 2.5 0.043 1.1 0.03 0.7 0.3 8 SIDE ADJUST 0.17 4.3 STATOR STATOR 0.12 DIA 3.0 0.051 DIA 1.3 (3 HOLES) 0.17 4.3 ROTOR 0.075 1.9 0.128 3.25 0.3 8 0.30 7.5 ROTOR (2) ROTOR (2) STATOR 0.051 DIA 1.3 (2 HOLES) 0.200 5.08 0.12 DIA 3.0 2 LEAD 3 LEAD 0.043 1.1 0.051 DIA (3 HOLES) 1.3 0.30 7.5 SIDE ADJUST 3 LEAD 2 LEAD 0.098 2.5 MOUNTING HOLE LAYOUTS All dimensions are in / mm. 4 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H 8 mm TOP/BOTTOM & SIDE ADJUST SPECIFICATIONS FEATURES Voltage Rating: 200 VDC (High temp PTFE), 100 VDC (all others) Dielectric Withstanding Voltage: 300 VDC (High temp PTFE), 200 VDC (all others) Contact Resistance: 0.010 Ohms max Insulation Resistance: 10 4 megohms min Torque: 15 to 250 g-cm (0.21 to 3.5 oz-in) • Choice of dielectrics: High Temp PTFE, Standard PTFE, Polypropylene, or Polycarbonate • Linear capacitance change vs. rotation Capacitance Operating (pF) Q min TCC Temperature ‘H’ max Dielectric min max (1MHz) (ppm /°C) (°C) in/mm Top/Bottom Adjust Color Code Top/Bottom Adjust Side Adjust 3 Lead 2 Lead Model Number Model Number Model Number PTFE*, High Temp 1.5 1.8 2.6 3.5 4.5 5.0 5.0 9.0 18.0 27.0 36.0 45.0 1500 1500 1500 1500 1500 1500 0 0 0 0 0 0 ± ± ± ± ± ± 250 250 250 250 250 250 –40 –40 –40 –40 –40 –40 to to to to to to +125 +125 +125 +125 +125 +125 .402/10.2 .402/10.2 .402/10.2 .402/10.2 .449/11.4 .449/11.4 Clear Yellow Green Red Violet Orange GXE5R000 GXE9R000 GXE18000 GXE27000 GXE36000 GXE45000 GXE5R002 GXE9R002 GXE18002 GXE27002 GXE36002 GXE45002 GXR5R000 GXR9R000 GXR18000 GXR27000 GXR36000 GXR45000 PTFE 1.6 2.0 2.0 3.9 4.5 5.0 5.0 9.0 18.0 27.0 36.0 45.0 1500 1500 1500 1500 1500 1500 0 0 0 0 0 0 ± ± ± ± ± ± 350 350 300 300 300 300 –40 –40 –40 –40 –40 –40 to to to to to to +85 +85 +85 +85 +85 +85 .402/10.2 .402/10.2 .402/10.2 .402/10.2 .449/11.4 .449/11.4 Clear Yellow Green Red Violet Orange GXA5R000 GXA9R000 GXA18000 GXA27000 GXA36000 GXA45000 GXA5R002 GXA9R002 GXA18002 GXA27002 GXA36002 GXA45002 GXB5R000 GXB9R000 GXB18000 GXB27000 GXB36000 GXB45000 PP 1.6 2.0 2.0 2.2 2.3 3.0 5.0 10.0 15.0 22.0 27.0 36.0 1000 1000 1000 1000 1000 1000 0 0 0 0 0 0 ± ± ± ± ± ± 300 300 400 400 350 300 –40 –40 –40 –40 –40 –40 to to to to to to +70 +70 +70 +70 +70 +70 .402/10.2 .402/10.2 .402/10.2 .402/10.2 .402/10.2 .402/10.2 Clear Yellow Blue Green Red Violet GYA5R000 GYA10000 GYA15000 GYA22000 GYA27000 GYA36000 GYA5R002 GYA10002 GYA15002 GYA22002 GYA27002 GYA36002 GYB5R000 GYB10000 GYB15000 GYB22000 GYB27000 N/A PC 2.5 4.0 30.0 40.0 200 200 100 ± 300 –40 to +85 .402/10.2 Red 100 ± 300 –40 to +85 .402/10.2 Violet GZA30000 GZA40000 GZA30002 GZA40002 GZB30000 GZB40000 * Gold plated metal parts are standard on GXE and GXR models shown above. 0.098 DIA 2.5 0.33 8.5 0.33 8.5 0.18 4.6 0.31 MAX 7.9 0.02 0.6 0.33 8.5 0.30 7.7 0.30 7.5 0.03 0.7 ROTOR (2) 0.02 0.6 0.03 0.7 0.098 DIA 2.5 0.02 0.6 0.098 DIA 2.5 STATOR 0.14 3.5 ‘H’ MAX 0.03 0.7 SIDE ADJUST 0.075 1.9 0.148 3.75 ‘H’ MAX ‘H’ MAX 0.051 DIA 1.3 (3 HOLES) 0.30 7.5 0.17 4.3 STATOR 0.0413 TYP 1.05 3 LEAD ROTOR STATOR 2 LEAD 0.051 DIA 1.3 (3 HOLES) 0.051 DIA 1.3 (2 HOLES) 2 Lead 0.30 7.5 3 Lead 0.12 DIA 3.0 0.200 5.08 0.12 DIA 3.0 0.17 4.3 ROTOR (2) 0.0413 TYP 1.05 0.098 2.5 Side Adjust MOUNTING HOLE LAYOUTS All dimensions are in / mm. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 5 FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H 10 mm TOP/BOTTOM & SIDE ADJUST SPECIFICATIONS FEATURES Voltage Rating: 200 VDC (High temp PTFE), 100 VDC (all others) Dielectric Withstanding Voltage: 300 VDC (High temp PTFE), 200 VDC (all others) Contact Resistance: 0.010 Ohms max Insulation Resistance: 10 4 megohms min Torque: 15 to 360 g-cm (0.2 to 5 oz-in) • Choice of dielectrics: High Temp PTFE, Standard PTFE, Polypropylene (PP), or Polycarbonate (PC) • Linear capacitance change vs. rotation • Wide capacitance ranges Capacitance Operating (pF) Q min TCC Temperature ‘H’ max Dielectric min max (1MHz) (ppm /°C) (°C) in/mm PTFE*, High Temp 2.5 3.0 4.0 5.5 6.0 8.0 15.0 25.0 40.0 60.0 75.0 90.0 1500 1500 1500 1500 1500 1500 0 0 0 0 0 0 ± ± ± ± ± ± 250 250 250 250 250 250 –40 –40 –40 –40 –40 –40 to to to to to to +125 +125 +125 +125 +125 +125 2.0 3.0 3.5 6.0 7.0 8.0 10.0 13.0 26.0 38.0 60.0 75.0 90.0 150.0 1500 1500 1500 1500 1500 1500 1500 0 0 0 0 0 0 0 ± ± ± ± ± ± ± 400 350 300 300 300 300 300 –40 –40 –40 –40 –40 –40 –40 to to to to to to to PP 2.0 3.0 3.5 4.5 15.0 20.0 40.0 65.0 1000 1000 1000 1000 0 0 0 0 ± ± ± ± 400 400 350 350 –40 –40 –40 –40 PC 8.0 9.0 9.0 10.0 12.0 80.0 100.0 120.0 150.0 180.0 200 200 200 200 200 0 0 0 0 0 ± ± ± ± ± 200 400 350 350 350 –40 –40 –40 –40 –40 PTFE Top/Bottom Color Code Top/Bottom Top/Bottom Side 3 Lead-Std. 3 Lead-Spec. 2 Leads Model No. Model No. Model No. Model No. 0.402/10.2 Red 0.402/10.2 Clear 0.402/10.2 Yellow 0.449/11.4 Blue 0.449/11.4 Violet 0.488/12.4 Orange GXF15000 GXF25000 GXF40000 GXF60000 GXF75000 GXF90000 GXF15003 GXF25003 GXF40003 GXF60003 GXF75003 GXF90003 GXF15004 GXF25004 GXF40004 GXF60004 GXF75004 GXF90004 GXT15000 GXT25000 GXT40000 GXT60000 GXT75000 GXT90000 +85 +85 +85 +85 +85 +85 +85 0.402/10.2 0.402/10.2 0.402/10.2 0.449/11.4 0.449/11.4 0.488/12.4 0.488/12.4 GXC13000 GXC26000 GXC38000 GXC60000 GXC75000 GXC90000 GXC15100 GXC13003 GXC26003 GXC38003 GXC60003 GXC75003 GXC90003 GXC15103 GXC13004 GXC26004 GXC38004 GXC60004 GXC75004 GXC90004 GXC15104 GXD13000 GXD26000 GXD38000 GXD60000 GXD75000 GXD90000 N/A to to to to +70 +70 +70 +70 0.402/10.2 Blue 0.402/10.2 Green 0.402/10.2 Clear 0.402/10.2 Yellow GYC15000 GYC20000 GYC40000 GYC65000 GYC15003 GYC20003 GYC40003 GYC65003 GYC15004 GYC20004 GYC40004 GYC65004 GYD15000 GYD20000 GYD40000 GYD65000 to to to to to +85 +85 +85 +85 +85 0.402/10.2 0.449/11.4 0.449/11.4 0.472/12.0 0.472/12.0 GZC80000 GZC10100 GZC12100 GZC15100 GZC18100 GZC80003 GZC10103 GZC12103 GZC15103 GZC18103 GZC80004 GZC10104 GZC12104 GZC15104 GZC18104 GZD80000 GZD10100 GZD12100 GZD15100 GZD18100 Blue Green Clear Yellow Red Violet Orange Red Violet Orange Orange Orange * Gold plated metal parts are standard on GXF and GXT models shown above. 0.098 DIA 2.5 0.43 11 0.43 11 0.43 11 0.25 6.3 0.402 10.2 0.03 0.7 0.43 11 0.37 9.5 0.37 9.5 0.402 10.2 0.03 0.7 0.03 0.7 0.098 DIA 2.5 0.03 0.7 0.098 DIA 2.5 ‘H’ MAX 0.03 0.7 0.03 0.7 0.03 0.7 0.098 DIA 2.5 0.18 4.5 0.03 0.7 SIDE ADJUST 0.20 5.0 ‘H’ MAX ‘H’ MAX ROTOR (2) 0.0413 TYP 1.05 STATOR ‘H’ MAX 0.100 2.54 0.051 DIA 1.3 (3 HOLES) 0.39 10 0.200 5.08 0.18 4.5 STATOR 0.0413 TYP 1.05 3 LEAD STANDARD ROTOR (2) 0.18 4.5 STATOR 0.0413 TYP 1.05 3 LEAD SPECIAL 0.18 4.5 ROTOR STATOR 2 LEAD 3 Lead Special 3 Lead Standard 0.39 10 0.20 5.0 2 Lead 0.051 DIA 1.3 (3 HOLES) 0.300 7.62 0.12 DIA 3.0 ROTOR (2) 0.12 DIA 3.0 0.051 DIA 1.3 (3 HOLES) 0.051 DIA 1.3 (2 HOLES) 0.12 DIA 3.0 0.2 5 0.39 10 Side Adjust MOUNTING HOLE LAYOUTS All dimensions are in / mm. 6 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H 11 X 13 mm TOP/BOTTOM ADJUST FEATURES 0.449 11.4 • Housing protected • High capacitance range • Linear capacitance change vs. rotation COLOR CODE 0.51 13 0.02 MIN 0.6 SPECIFICATIONS 0.1 DIA 3 Voltage Rating: 100 VDC Dielectric Withstanding Voltage: 200 VDC Contact Resistance: 0.010 Ohms max Insulation Resistance: 10 4 megohms min Torque: 20 to 360 g-cm (0.28 to 5 oz-in) 0.02 0.5 0.571 MAX 14.5 0.17 4.3 STATOR ROTOR (2) 0.0413 TYP 1.05 0.12 DIA 3.0 0.39 10 Capacitance Operating (pF) Q min TCC Temperature Dielectric min max (1MHz) (ppm /°C) (°C) PC 15.0 30.0 230.0 430.0 200 150 0 ± 400 0 ± 350 –40 to +85 –40 to +85 Color Code Model Number Orange - 1 dot Orange - 2 dot GZC23112 GZC43112 0.051 DIA 1.3 (3 HOLES) 0.2 5 MOUNTING HOLE LAYOUT 16 mm TOP / SIDE ADJUST FEATURES 0.610 15.5 0.059 1.5 • Highest capacitance range SPECIFICATIONS Voltage Rating: 150 VDC Dielectric Withstanding Voltage: 300 VDC Contact Resistance: 0.010 Ohms max Insulation Resistance: 10 4 megohms min Torque: 20 to 360 g-cm (0.28 to 5 oz-in) 0.71 18 0.03 0.8 • Linear capacitance cange vs. rotation 0.71 18 0.14 3.5 0.610 15.5 0.14 DIA 3.5 STATOR ROTOR 0.08 2 0.0413 TYP 1.05 0.67 MAX 17 0.20 5.0 0.051 DIA 1.3 (2 HOLES) 0.03 0.8 0.059 1.5 0.14 DIA 3.5 0.67 MAX 17 MOUNTING HOLE LAYOUT SIDE ADJUST ROTOR (2) 0.0413 TYP 1.05 STATOR 0.14 3.5 0.30 7.5 0.59 15 Capacitance Operating (pF) Q min TCC Temperature Color Dielectric min max (1MHz) (ppm /°C) (°C) Code Top Adjust Side Adjust Model Number Model Number PC 9.0 18.0 200.0 300.0 200 200 0 ± 300 0 ± 300 –40 to +85 Orange –40 to +85 Clear GZN20100 GZN30100 GZP20100 GZP30100 PI 25.0 600.0 150 0 ± 350 –40 to +85 GZN60100 GZP60100 None 0.051 DIA 1.3 (3 HOLES) MOUNTING HOLE LAYOUT TOP ADJUST All dimensions are in / mm. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 7 FILMTRIM® PLASTIC DIELECTRIC CAPACITORS SG-402H PART NUMBERING SYSTEM GX A Dielectric Symbol Description GC PPS (Polyphenyl Sulfide) GSX** PTFE (Polytetrafluoroethylene) GX PTFE (Polytetrafluoroethylene) GY PP (Polypropylene) GZ PC or PI (Polycarbonate or Polyimide) Form Factor 9R0 00 Cap Code Modifications (Top Adjust Models) Industry Standard, Symbol Description Symbol Description i.e. 01 6 x 8 mm, 2 leads, A 8 mm Top/Bottom Adjust 1R6 = 1.6 pF, GXE and GXQ series B 8 mm Side Adjust only 400 = 40.0 pF, C 10 mm Top/Bottom Adjust, 02 8 mm, 2 leads 11 x 13 mm Top/Bottom Adjust 301 = 300.0 pF 03 10 mm, 3 lead, special D 10 mm Side Adjust 04 10 mm, 2 leads E* 6 x 8 mm Top/Bottom Adjust, 11 6 x 8 mm, 3 leads 8 mm Top/Bottom Adjust 12 11 x 13 mm, F* 10 mm Top/Bottom Adjust housing protected (available on all 10 mm L 5 mm Top Adjust, top and bottom adjust 7 mm Economy units) N 16 mm Top Adjust 25 Ammo pack version for GCL only P 16 mm Side Adjust Q* 6 x 8 mm Side Adjust R* 8 mm Side Adjust T* 10 mm Side Adjust * Extended temperature range: –40°C to +125°C ** GSX parts do not conform to part numbering system above. For other modifications such as high temperature base material or special lead plating, contact factory. SPECIFICATION NOTES Soldering and Cleaning of FILMTRIM® Trimmer Capacitors 1. Parts are 100% tested for capacitance range and dielectric withstanding voltage. 2. Capacitance range specified is that which is guaranteed, and is measured at 1 MHz at room temperature. 3. Q factor is measured at maximum rated capacitance and at room temperature. 4. Dielectric strength is measured at maximum rated capacitance and room temperature, with test voltage (as listed for each model) applied for 60 seconds. 5. Insulation resistance is measured at maximum rated capacitance and room temperature and at rated voltage, unless otherwise specified. 6. Temperature coefficient of capacitance (TCC) is measured at 1 MHz over the operating temperature range, with capacitor set at maximum rated capacitance. 7. Axial load during tuning should not exceed 200 grams force. At maximum axial load, capacitance change is no more than 15%. 8. Capacitors should not be operated outside of rated capacitance range and working voltage. Soldering Methods (1) Reflow soldering for GSX series Pre-heat: 140°C ±10°C for 2 to 3 minutes. Soldering: 200 to 250°C within 25 seconds. (Peak soldering temperature: 250°C maximum). (2) Dip soldering (does not apply to GSX models) 260°C ±10°C for 7 seconds maximum. (3) Hand soldering (for lead-through-hole models) Soldering: Tip temperature 350°C ±10°C for 3 to 4 seconds (4) Hand soldering (GSX models) Preheating: Fully preheat on a hot plate with a surface temperature of 100 to 150°C. Soldering: 260°C ±10°C for 5 seconds maximum. Cleaning (1) Water soluble fluxes and detergents with a water flush after soldering of the boards can be used for GX, GY and GZ models. (2) Do not immerse FILMTRIM models in chlorinated or fluorinated hydrocarbon solvents as this would adversely affect the plastic dielectrics and base materials. Some customers have successfully used GX models in scrubbers or sprayers where only the bottom of the printed circuit boards is exposed to solvents. If the process requires immersion in solvents for cleaning boards, the FILMTRIM capacitors should be hand soldered to board after the boards have been cleaned. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com ©2002 SPRAGUE-GOODMAN ELECTRONICS, INC., ALL RIGHTS RESERVED. PRINTED IN U.S.A. 50204
GYC15003 价格&库存
很抱歉,暂时无法提供与“GYC15003”相匹配的价格&库存,您可以联系我们找货
