SGNMNC2206EK
SGNMNC2206EK
    SPRAGUE-GOODMAN
    可调电容 2pF~20pF 6KV Ф13.97mm
SGNMNC2206EK 数据手册
SGNM – SERIES 1 CERAMIC HIGH VOLTAGE NON-MAGNETIC TRIMMER CAPACITOR Product Highlights Applications • High Voltage Ceramic Dielectric • MRI and NMR Coils • Internally Sealed to Withstand External • Transmitting and Receiving Sections of MRI and NMR Machines Pressure of Up to 40 PSI • • Residual Magnetic Value Less Than 20 nT Model Number Capacitance Range (pF) Cryogenic Projects Q Min Rated DC Working Dielectric Withstanding Voltage (V) Voltage (V) (at 25 MHz C Max) Min Max SGNMNC1054 0.50 5.00 2,000 4,000 8,000 SGNMNC1056 0.50 5.00 2,000 6,000 12,000 SGNMNC1059 0.50 5.00 2,000 8,750 17,500 SGNMNC1103 1.00 10.00 1,700 3,000 6,000 SGNMNC1106 1.00 10.00 1,700 6,000 12,000 SGNMNC1108 1.00 10.00 1,700 7,500 15,000 SGNMNC1152 1.00 15.00 1,500 2,000 4,000 SGNMNC1156 1.50 15.00 1,500 6,000 12,000 SGNMNC1206 2.00 20.00 1,500 6,000 12,000 Options: 1. Extended Shaft - Add suffix “E” to model number 2. Cryogenic Version – Add suffix “K” for model that operates and may be tuned at temperatures as low as 4K. This model is not sealed 3. No Lead Option – Add suffix “NL” for a model that does not include a wire lead attached to stator terminal 4. Please contact us directly for additional customization options SPRAGUE GOODMAN ELECTRONICS, INC. ▪ 1700 SHAMES DRIVE ▪ WESTBURY, NEW YORK 11590 ▪ (516) 334 - 8700 SGNM – SERIES 2 CERAMIC HIGH VOLTAGE NON-MAGNETIC TRIMMER CAPACITOR Product Highlights Applications • High Voltage Ceramic Dielectric • MRI and NMR Coils • Internally Sealed to Withstand External • Transmitting and Receiving Sections of MRI and Pressure of Up to 40 PSI • NMR Machines • Residual Magnetic Value Less Than 20 nT Cryogenic Projects Model Number Capacitance Range (pF) Min Max Q Min Rated DC Working Dielectric Withstanding Voltage (V) Voltage (V) (at 25 MHz C Max) SGNMNC2106 1.00 10.00 3,000 6,000 12,000 SGNMNC2156 1.50 15.00 2,000 6,000 12,000 SGNMNC2206 2.00 20.00 1,500 6,000 12,000 SGNMNC2236 2.00 23.00 1,200 6,000 12,000 SGNMNC2256 3.00 25.00 1,200 6,000 12,000 SGNMNC2306 3.00 30.00 600 6,000 12,000 SGNMNC2356 3.50 35.00 600 6,000 12,000 SGNMNC2406 4.00 40.00 500 6,000 12,000 SGNMNC2502 5.00 50.00 500 2,500 5,000 Options: 1. Extended Shaft - Add suffix “E” to model number 2. Cryogenic Version – Add suffix “K” for model that operates and may be tuned at temperatures as low as 4K. This model is not sealed 3. No Lead Option – Add suffix “NL” for a model that does not include a wire lead attached to stator terminal 4. Please contact us directly for additional customization options SPRAGUE GOODMAN ELECTRONICS, INC. ▪ 1700 SHAMES DRIVE ▪ WESTBURY, NEW YORK 11590 ▪ (516) 334 - 8700 SGNM – SERIES 3 CERAMIC HIGH VOLTAGE NON-MAGNETIC TRIMMER CAPACITOR Product Highlights Applications • High Voltage Ceramic Dielectric • MRI and NMR Coils • Internally Sealed to Withstand External • Transmitting and Receiving Sections of MRI and Pressure of Up to 40 PSI • Residual Magnetic Value Less Than 20 nT Model Number SGNMNC3101 SGNMNC3103 SGNMNC3106 SGNMNC3153 SGNMNC3205 SGNMNC3253 SGNMNC3256 SGNMNC3306 SGNMNC3505 SGNMNC3706 SGNMNC3708 SGNMNC3806 SGNMNC31006 Capacitance Range (pF) Min Max 1.00 10.00 1.50 10.00 2.00 10.00 1.50 15.00 3.00 20.00 5.00 25.00 7.00 25.00 4.00 30.00 5.00 50.00 2.00 70.00 6.50 70.00 5.00 85.00 10.00 100.00 NMR Machines • Cryogenic Projects Q Min Rated DC Working Dielectric Withstanding Voltage (V) Voltage (V) (at 25 MHz C Max) 2,000 1,500 3,000 2,000 3,000 6,000 1,800 6,000 12,000 2,000 3,000 6,000 600 4,500 9,000 1,200 3,000 6,000 1,200 6,000 12,000 1,000 6,000 12,000 700 4,500 9,000 600 6,000 12,000 600 7,500 15,000 500 6,000 12,000 500 6,000 12,000 Options: 1. Extended Shaft - Add suffix “E” to model number 2. Cryogenic Version – Add suffix “K” for model that operates and may be tuned at temperatures as low as 4K. This model is not sealed 3. No Lead Option – Add suffix “NL” for a model that does not include a wire lead attached to stator terminal 4. Please contact us directly for additional customization options SPRAGUE GOODMAN ELECTRONICS, INC. ▪ 1700 SHAMES DRIVE ▪ WESTBURY, NEW YORK 11590 ▪ (516) 334 - 8700
SGNMNC2206EK 价格&库存
很抱歉,暂时无法提供与“SGNMNC2206EK”相匹配的价格&库存,您可以联系我们找货
