USB DIY Connector - MicroB Female Plug
PRODUCT ID: 1829
DESCRIPTION
As an addition to our other USB DIY shells, we have a 'micro B female' in a panelmount-like connector. This isn't true panel mount but you could glue the black
plastic shell into your project and then press-fit in the micro B connector. The
5-pins are much easier to solder than a surface mount connector
We have other DIY "USB shells" are available in USB A plug, micro B, mini B and USB
A socket.
Each shell comes with a plastic shell and a proper connector with easy-to-solder
tabs.
http://www.adafruit.com/products/1829
10/7/2015
Technical Details
Assembled Dimensions: 10mm x 9mm x 4.5mm / 0.4" x 0.35" x 0.2"
Assembled Weight: 0.6g
MicroB-F Connector Dimensions: 10mm x 7mm x 2mm / 0.4" x 0.3" x 0.1"
MicroB-F Connector Weight: 0.4g
很抱歉,暂时无法提供与“1829”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.747981+1.30053
