USB DIY Slim Connector Shell - A-M Plug
PRODUCT ID: 1827
DESCRIPTION
Make your own USB connections without slicing apart a USB cable and soldering
those thin wires inside. This is the 'slim' version of the DIY USB-A Male connector.
It's a little more elegant because instead of snapping two pieces together the
connector press-fits into the overmolding for a modern look. We also carry the slim
size in Micro-B Male and USB-microB female.
Normal DIY "USB shells" are available in USB A plug, micro B, mini B and USB A
socket.
Each shell comes with a plastic shell and a proper connector with easy-to-solder
tabs.
http://www.adafruit.com/products/1827
10/5/2015
Technical Details
Assembled Dimensions: 30mm x 15mm x 7mm / 1.2" x 0.6" x 0.3"
Assembled Weight: 2.8g
A-M USB Connector Dimensions: 21mm x 12mm x 4.5mm / " x " x "
A-M USB Connector Weight: 1.9g
很抱歉,暂时无法提供与“1827”相匹配的价格&库存,您可以联系我们找货
