CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
Surface Mount
PXF
@Super low ESR, impedance and high heat resistance have been obtained by using
conductive polymer as electrolyte.
(ESR and rated ripple current values are improved from PXA series.)
@Rated voltage range : 2.5 to 16Vdc, Capacitance range : 33 to 2,700MF
@Case size range : F5B5.8L to F10B12.2L
@Suitable for DC-DC converters, voltage regulators and decoupling applications used on
computer motherboards etc.
@RoHS Compliant
Lower ESR
PXE
Lower ESR
PXA
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Surge Voltage
Leakage Current
Dissipation Factor
(tane)
Low Temperature
Characteristics
(Max. Impedance Ratio)
-55 to +105C
2.5 to 16Vdc
P20% (M)
Rated voltageB1.15
Shall not exceed values shown in STANDARD RATINGS.
(at 20C, 120Hz)
(at 105C)
(at 20C after 2 minutes)
0.12 max.
(at 20C, 120Hz)
Z(-25C)/Z(+20C)[1.15
Z(-55C)/Z(+20C)[1.25
(at 100kHz)
The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 2,000 hours
at 105C.
Appearance
No significant damage
Capacitance change
[P20% of the initial value
DF (tanE)
[150% of the initial specified value
ESR
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to the DC rated voltage at
60C, 90 to 95% RH for 1,000 hours.
Appearance
Capacitance change
DF (tanE)
ESR
Leakage current
The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105C for 30 seconds
through a protective resistor(R=1kO) and discharge for 5 minutes 30 seconds.
Appearance
Capacitance change
DF (tanE)
ESR
Leakage current
0.5% per 1,000 hours maximum (Confidence level 60% at 105C)
Endurance
Bias Humidity
Surge Voltage
Failure Rate
*Note : If any doubt arises, measure the leakage current after the following voltage treatment.
Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105C.
?DIMENSIONS [mm]
?MARKING
Size Code
E61
F61
F80
H70
H80
HA0
HC0
J80
JA0
JC0
@Terminal Code : A
P
CP0.2
BP0.2
FDP0.5
W
0.3max.
LP0.3 (Note)
AP0.2
(Note) LP0.5 for HA0, HC0, JA0, JC0
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
fD
5
6.3
6.3
8
8
8
8
10
10
10
A
B
C
L
5.8 5.3 5.3 5.9
5.8 6.6 6.6 7.2
7.7 6.6 6.6 7.2
6.7 8.3 8.3 9.0
7.7 8.3 8.3 9.0
10.0 8.3 8.3 9.0
12.0 8.3 8.3 9.0
7.7 10.3 10.3 11.0
10.0 10.3 10.3 11.0
12.2 10.3 10.3 11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
0.7 to 1.1
0.7 to 1.1
0.7 to 1.1
0.7 to 1.1
0.7 to 1.1
P
1.4
1.9
1.9
3.1
3.1
3.1
3.1
4.5
4.5
4.5
EX) 2.5V390MF
E49A
390
2.5V
18
A PXE AAA A RA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47MF:470,100MF:101)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100)
Series code
Category Please refer to "Product code guide (conductive polymer type)"
(1/2)
CAT. No. E1001J
Surface Mount
?STANDARD RATINGS
WV
(Vdc)
2.5
4
6.3
10
16
Cap
(mF)
Size
code
Leakage current
(mAmax/after 2min.)
180
390
470
560
560
560
680
820
820
1,000
1,200
1,500
1,500
2,200
2,700
100
150
270
330
390
470
560
680
1,000
1,000
1,200
1,200
1,500
1,800
1,800
100
120
220
270
330
330
330
390
470
820
820
820
1,200
1,500
1,500
47
56
68
120
150
220
270
330
390
470
680
33
39
68
82
100
100
120
150
180
220
220
330
E61
F61
F80
F61
F80
H70
H70
H80
HC0
H80
J80
HA0
HC0
JA0
JC0
E61
E61
F61
F61
F80
H70
H70
H80
HA0
J80
HC0
JA0
JA0
JA0
JC0
E61
E61
F61
F80
F61
F80
H70
H70
H80
HA0
HC0
J80
JA0
JA0
JC0
E61
E61
E61
F61
F80
H70
H70
H80
HA0
J80
JA0
E61
E61
F61
F80
F80
H70
H70
H80
HA0
HA0
J80
JA0
90
195
235
700
280
280
340
410
410
500
600
750
750
1,100
1,350
80
120
216
264
312
376
448
544
800
800
960
960
1,200
1,440
1,440
126
151
277
340
700
415
415
491
592
1,030
1,030
1,030
1,510
1,890
1,890
94
112
136
240
300
440
540
660
780
940
1,360
105
124
217
262
320
320
384
480
576
704
704
1,050
ESR
(momax/20c, 100k to 300kHz)
21
15
13
16
13
13
13
12
9
12
13
10
9
10
9
22
22
15
15
14
14
14
13
10
14
9
10
10
10
9
24
24
15
14
17
14
14
14
13
12
10
14
12
12
10
28
28
28
25
21
21
21
19
17
19
13
35
35
28
24
24
24
24
22
18
18
22
16
(2/2)
Rated ripple current
(mArms/105c, 100kHz)
2,670
3,160
3,600
3,500
3,600
4,100
4,100
4,260
5,400
4,260
4,450
5,220
5,400
5,500
5,600
2,610
2,610
3,160
3,160
3,470
3,950
3,950
3,950
5,220
4,300
5,400
5,500
5,500
5,500
5,600
2,500
2,500
3,160
3,470
3,390
3,470
3,950
3,950
3,950
4,770
5,150
4,300
5,025
5,025
5,500
2,310
2,310
2,310
2,530
2,880
3,220
3,220
3,390
4,000
3,800
4,820
2,070
2,070
2,390
2,700
2,700
3,010
3,010
3,150
3,890
3,890
3,450
4,350
Part No.
APXE2R5ARA181ME61G
APXE2R5ARA391MF61G
APXE2R5ARA471MF80G
APXE2R5ARA561MF61G
APXE2R5ARA561MF80G
APXE2R5ARA561MH70G
APXE2R5ARA681MH70G
APXE2R5ARA821MH80G
APXE2R5ARA821MHC0G
APXE2R5ARA102MH80G
APXE2R5ARA122MJ80G
APXE2R5ARA152MHA0G
APXE2R5ARA152MHC0G
APXE2R5ARA222MJA0G
APXE2R5ARA272MJC0G
APXE4R0ARA101ME61G
APXE4R0ARA151ME61G
APXE4R0ARA271MF61G
APXE4R0ARA331MF61G
APXE4R0ARA391MF80G
APXE4R0ARA471MH70G
APXE4R0ARA561MH70G
APXE4R0ARA681MH80G
APXE4R0ARA102MHA0G
APXE4R0ARA102MJ80G
APXE4R0ARA122MHC0G
APXE4R0ARA122MJA0G
APXE4R0ARA152MJA0G
APXE4R0ARA182MJA0G
APXE4R0ARA182MJC0G
APXE6R3ARA101ME61G
APXE6R3ARA121ME61G
APXE6R3ARA221MF61G
APXE6R3ARA271MF80G
APXE6R3ARA331MF61G
APXE6R3ARA331MF80G
APXE6R3ARA331MH70G
APXE6R3ARA391MH70G
APXE6R3ARA471MH80G
APXE6R3ARA821MHA0G
APXE6R3ARA821MHC0G
APXE6R3ARA821MJ80G
APXE6R3ARA122MJA0G
APXE6R3ARA152MJA0G
APXE6R3ARA152MJC0G
APXE100ARA470ME61G
APXE100ARA560ME61G
APXE100ARA680ME61G
APXE100ARA121MF61G
APXE100ARA151MF80G
APXE100ARA221MH70G
APXE100ARA271MH70G
APXE100ARA331MH80G
APXE100ARA391MHA0G
APXE100ARA471MJ80G
APXE100ARA681MJA0G
APXE160ARA330ME61G
APXE160ARA390ME61G
APXE160ARA680MF61G
APXE160ARA820MF80G
APXE160ARA101MF80G
APXE160ARA101MH70G
APXE160ARA121MH70G
APXE160ARA151MH80G
APXE160ARA181MHA0G
APXE160ARA221MHA0G
APXE160ARA221MJ80G
APXE160ARA331MJA0G
CAT. No. E1001J
