2114
    ADAFRUIT
    无线充电线圈
2114 数据手册
Universal Qi Wireless Charging Module - 20mm Reverse MicroUSB PRODUCT ID: 2114 Description If you have a modern smart phone you may have noticed that it comes with built in wireless charging capability called 'Qi charging.' Qi is a trademark name for a thin and smart inductive charging system. Many large gadget companies have standardized on Qi, which means it's easy to find a charging dish and we thought it might be cool if your electronics project or phone with a microUSB port can recharge itself wirelessly. Thus, we now have four different MicroUSB Modules for different phone/device orientations. This is the 20mm ReverseYHUVLRQRIRXUGLIIHUHQW4L¬0LFUR86%0RGXOHV:HDOVRKDYHD20mm Forward, a 60mm Reverse, and a 60mm Forward Check out the big photo above of the microUSB connector orientation to determine which module you need! We have a generic photo showing how the module sticks to the back of our Android phone, but you'll have to check the MicroUSB connector orientation to determine which length/type of Qi PRGXOH\RXQHHG 7KHVHUHFHLYHUVRQO\SURYLGHSRZHURQWKH86% V9DQG*URXQGSLQV6RPHSKRQHV OLNHWKH 0RWR; UHTXLUHDVSHFLDOYROWDJHRQWKHGDWDOLQHVDQGZRQ WFKDUJH&KHFNRQOLQH documentation for your phone to see if you can get away with not having any voltages or connections on the data lines! You do need a Qi transmitter to go along with the receivers - which we now carry in the Adafruit store. Technical Details Output Voltage: DC5V Output Current: 600mA Max Max Power Transmission: DC 5W Operating Frequency: 100-200Khz Conversion efficiency: >70% Charging distance: 2-6mm Weight: 25g Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2114”相匹配的价格&库存,您可以联系我们找货
    • 1+218.47192
    库存:4
