681S21WA4PL001
681S21WA4PL001
    NORCOMP
    21(17 + 4 电源) 位 D-Sub,组合式 插头,公引脚 连接器, 自由悬挂 焊接
681S21WA4PL001 数据手册
DESCRIPTION: POWER / SIGNAL - VERTICAL BOARD - MALE - IP67 SPECIFICATIONS: ELECTRICAL: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: SIGNAL CONTACT RESISTANCE: POWER PINS: SIGNAL PINS: 2.732 [69.40] ±0.010 [±0.25] 2.500 [63.50] ±0.010 [±0.25] 2.181 [55.40] ±0.010 [±0.25] A1 A2 1 2 3 4 5 6 Ø 0.120 [Ø 3.05] 2-PLACES 8 7 9 A3 250V -55°C TO +125°C 1.0 mΩ MAX. 10 mΩ MAX. 40 AMPS 5 AMPS MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SEAL: SHELL: HARDWARE: F08 FLEXIBLE ADHESIVE NICKEL PLATED STEEL NICKEL PLATED BRASS 230°C PROCESS TEMP. A4 10 11 12 13 14 15 16 17 0.112 [2.84] 10° 5 GΩ MIN. 1000 VAC FOR 1 MIN 0.327 [8.30] ±0.010 [±0.25] 681S21WA4PLYYY 0.492 [12.50] ±0.010 [±0.25] 0 = 40 AMP 0 1 2 3 4 5 0.240 [6.10] 0.433 [11.00] = NO HARDWARE = 0.098" CN PCB SIDE = 0.236" CN PCB SIDE = 0.236" CN MATING SIDE = 0.237" BOARDLOCK PCB SIDE = 0.224" BOARDLOCK PCB SIDE 1 = GOLD FLASH 0.031 [0.80] ±0.012 [±0.30] MEETS IP67 STANDARDS SEE SHEET 2 FOR DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. (SEE PAGE 2 FOR SEALING DETAILS) UNITS = INCHES [MM] DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 4 681S21WA4PLYYY 2 DESCRIPTION: 681 SERIES CONTACTS NOTE: SIGNAL AND POWER CONTACTS COME PRE-LOADED INTO INSULATORS Ø 0.026 [0.65] A 0.112 [2.84] 0.22 ± .012 [5.60 ± 0.30] A SIGNAL CONTACTS FRONT SEAL APPLIED OVER INSULATOR AND BETWEEN FRONT & REAR SHELLS 0.209 ± 0.012 [5.30 ± 0.30] 0.031 ± 0.012 [0.80 ± 0.30] DETAIL A-A SHOWN FOR REFERENCE ONLY Ø 0.148 [3.75] 0.059 ± 0.012 [1.50 ± 0.30] POWER CONTACTS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 4 681S21WA4PLYYY 2 DESCRIPTION: 681 SERIES CONTACTS 2.500 0.894 0.613 0.894 0.613 0.436 0.436 0.327 0.327 0.218 0.218 0.109 0.109 0.112 0.055 Ø 0.130 2-PLACES 0.055 Ø 0.165 4-PLACES 0.163 0.163 0.272 0.272 0.381 0.381 Ø 0.043 17-PLACES RECOMMENDED PCB LAYOUT RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 4 681S21WA4PLYYY 2 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 0 ..... NO HARDWARE 2 ..... 0.236" PCB SIDE 4 ..... 0.237" PCB SIDE 1 ..... 0.098" PCB SIDE 3 ..... 0.236" MATING SIDE 5 ..... 0.224" PCB SIDE RoHS COMPLIANT N C ALL DIMENSIONS ARE ±0.010 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 4 4 681S21WA4PLYYY 2
681S21WA4PL001 价格&库存
很抱歉,暂时无法提供与“681S21WA4PL001”相匹配的价格&库存,您可以联系我们找货
