ROB
ROB
MINIATURE
ALUMINUM
ELECTROLYTICCAPACITORS
CAPACITORSFOR
FORAUDIO
AUDIO
MINIATURE
ALUMINUM
ELECTROLYTIC
For
Audio
GREEN
CAP
Miniature Standard Capacitors for Audio
TONEREX
Adopting the newly developed formation method and composite electrolytic paper
for audio application has reduced distortion, achieving high-quality sound.
All lead wires are oxygen-free copper wires to reduce distortion.
Marking color : Gold print on a black sleeve
Specifications
Item
Performance
ー40 to +85
±20
Less than 0.01CV or 4 whichever is larger (after 5 minutes) C : Rated capacitance (µF) ; V: Rated voltage (V)
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
6.3
0.24
10
0.20
16
0.16
35
0.12
50
0.10
63
0.09
100
0.08
(20℃,120Hz)
0.02 is added to every 1000µF increase over 1000µF
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
Endurance (85℃)
(Applied ripple current)
Shelf life (85℃)
Applicable standards
1000 hours
The initial specified value or less
Within ±20% of initial value
150% or less of the initial specified value
Test time : 1000 hours. Other have same as endurance. Voltage application treatment : According to JIS C5101 -1
JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985)
Outline Drawing
Coefficient of Frequency for Rated Ripple Current
Unit : mm
Sleeve
Vent (except φ5)
Rated voltage (V)
φd±0.05 copper wire (tinned)
Frequency (Hz)
CV (µF×WV)
6.3 to 16
F±0.5
φD±0.5max.
L+αmax.
50 to 100
5
min.
15min.
6.3
2.5
0.6
α
8
3.5
0.6
10
5.0
0.6
12.5
5.0
0.8
120
1k
10k
100k
0.8
0.8
0.8
0.8
0.8
1
1
1
1
1
1.1
1.5
1.2
1.6
1.2
1.2
1.7
1.3
1.9
1.3
1.2
1.7
1.3
1.9
1.3
Part numbering system (example : 25V100µF)
ROB
5
2.0
0.6
50・60
All CV value
≤1000
1000<
≤1000
1000<
25 to 35
φD
F
φd
25
0.14
(20℃,120Hz)
(20℃)
16
7.5
0.8
Series code
18
7.5
0.8
25
V
Rated voltage
symbol
101
M
G3 # ̶
Rated capacitance Capacitance
symbol
tolerance symbol
Taping (Forming)
symbol
Casing
symbol
2.0
(φ10,16L or less : 1.5)
1.5
Case symbol
Case
φD×L (mm)
5×11
6.3×11
8×11.5
Casing
Symbol
E3
F3
G3
Case
φD×L (mm)
10×12.5
10×16
10×20
Casing
Symbol
H3
H4
H5
Case
Case
Casing
Symbol φD×L (mm)
16×31.5
Ⅰ5
16×35.5
Ⅰ6
18×35.5
J6
18×40
φD×L (mm)
12.5×20
12.5×25
16×25
Casing
Symbol
J7
J8
K8
K9
6.3
Rated voltage (V)
Rated
capacitance (µF)
Item
Case
φD×L (mm)
10
22
1
2.2
3.3
4.7
10
Case
Rated ripple
current
(mArms)
φD×L (mm)
16
Rated ripple
current
(mArms)
5×11
50
Case
φD×L (mm)
25
Rated ripple
current
(mArms)
Case
35
Rated ripple
current
φD×L (mm)
(mArms)
5×11
25
Case
φD×L (mm)
50
Rated ripple
current
(mArms)
Case
φD×L (mm)
63
Rated ripple
current
(mArms)
Case
φD×L (mm)
100
Rated ripple
current
(mArms)
Case
φD×L (mm)
Rated ripple
current
(mArms)
5×11
10
5×11
5×11
25
5×11
35
5×11
35
6.3×11
60
8×11.5
70
8×11.5
100
10×12.5
120
5×11
35
5×11
40
5×11
45
5×11
50
5×11
60
5×11
60
6.3×11
75
6.3×11
80
6.3×11
5×11
15
5×11
25
5×11
30
6.3×11
40
33
5×11
55
5×11
65
5×11
70
6.3×11
80
90
8×11.5
110
8×11.5
115
10×16
160
47
5×11
65
5×11
75
6.3×11
95
6.3×11
100
8×11.5
120
8×11.5
130
10×12.5
165
10×20
210
100
6.3×11
110
6.3×11
120
8×11.5
150
165
10×12.5
210
10×16
250
10×20
285
12.5×20
340
620
8×11.5
220
8×11.5
185
8×11.5
200
10×12.5
265
10×16
310
10×20
365
12.5×20
440
12.5×20
470
16×25
330
10×12.5
265
10×12.5
290
10×16
350
10×20
410
12.5×20
500
12.5×20
540
12.5×25
620
16×31.5
820
470
10×12.5
315
10×16
380
10×20
460
12.5×20
550
12.5×25
640
16×25
800
16×25
840
18×35.5
1000
1000
10×20
550
12.5×20
670
12.5×25
810
16×25
1000
16×25
1050
2200
12.5×25
980
16×25
1200
16×25
1350
16×35.5
1650
18×35.5
1900
3300
16×25
1300
16×31.5
1600
16×35.5
1800
18×40
2100
4700
16×31.5
1700
16×35.5
1900
18×35.5
2400
6800
16×35.5
2100
18×40
2600
18×40
2800
10000
16×31.5
1200
18×35.5
1500
(Note) Rated ripple current : 85℃, 120Hz
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
171
CAT.No.2015/2016E
FOR AUDIO
ALUMINUM
Standard Ratings
很抱歉,暂时无法提供与“ROB-100V470MH5#”相匹配的价格&库存,您可以联系我们找货
