LAO
LAO
LARGE
CAPACITANCE
ALUMINUM
ELECTROLYTIC
LARGE
CAPACITANCE
ALUMINUM
ELECTROLYTIC
CAPACITORS
FOR
AUDIO
CAPACITORS FOR AUDIO
For
Audio
GREEN
CAP
Power Supply Smoothing Use,Standard Capacitors for Audio
Best suited as power supply filters for sound quality priority audio equipment.
Printed circuit board terminal snap-in type.
For audio
LAO
LA5
Marking color : Gold print on a black sleeve
Specifications
Performance
ー40 to +85
±20
Less than 0.03CV or 5mA whichever is smaller (after 5 minutes) C : Rated capacitance (µF), V : Rated voltage (V)
Item
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
Characteristics at high
and low temperature
16
0.40
25
0.40
(20℃,120Hz)
(20℃)
50 to 100
0.30
35
0.35
(20℃,120Hz)
Rated voltage (V)
Impedance ratio
Z−25℃/Z+20℃
Z−40℃/Z+20℃
(max.)
16 to 35
4
15
50 to 100
3
10
(120Hz)
Endurance (85℃)
(Applied ripple current)
1000 hours
The initial specified value or less
Within ±20% of initial value
150% or less of the initial specified value
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
Test time : 1000 hours. Other have same as endurance. Voltage application treatment : According to JIS C5101 -1
JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985)
Shelf life (85℃)
Applicable standards
Outline Drawing
Unit : mm
Printed circuit board snap-in type (Series LAO)
Frequency (Hz)
Rated voltage (V)
0.9
4.7
5.4
φD+1max.
1
0.
4.0±0.5
1k
10k
20k
0.95
0.95
1
1
1.10
1.16
1.15
1.30
1.15
1.33
10
10
Vent
120
Part numbering system (example : 63V6800µF)
LAO
L+2max.
50
0.9±0.1 Thickness : 0.8t
1.5±0.1
Markings
kings
16 to 50
63 to 100
Lug terminal details
2−φ2
Sleeve
Coefficient of Frequency for Rated Ripple Current
Position of PC board holes
(‒)Negative terminal
indicated by cross notching
2.1
(For 4.0±0.5)
Series code
63
Rated voltage
symbol
V
682
M
Rated capacitance
Capacitance
symbol
tolerance symbol
S57 PX #
Casing
symbol
B
Optional
symbol
FOR AUDIO
ALUMINUM
CAT.No.2015/2016E
176
NOTE : Design, Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
LARGE CAPACITANCE
ALUMINUM
ELECTROLYTIC
LARGE CAPACITANCE
ALUMINUM
ELECTROLYTIC
CAPACITORS
FOR
AUDIO
CAPACITORS FOR
AUDIO
Standard Ratings
16
Rated voltage (V)
25
35
50
63
LAO
LAO
80
100
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated
Rated
Rated
Rated
Rated
Rated
Rated
Item capacitance
current
current
current
current
current
current
current
capacitance
capacitance
capacitance
capacitance
capacitance
capacitance
Case
Casing
φD×L (mm)
symbol
(µF)
(Arms)
(µF)
(Arms)
(µF)
(Arms)
(µF)
(Arms)
(µF)
(Arms)
(µF)
(Arms)
(µF)
(Arms)
22×20
S21
3300
1.2
22×25
S22
4700
1.5
2200
1.0
1500
0.8
1000
0.8
680
0.7
22×30
S23
3300
1.3
2200
1.3
1500
1.1
1000
0.9
680
0.7
22×35
S24
2.0
4700
1.7
3300
1.7
1500
1.2
1000
1.0
680
0.8
22×40
S25
22×45
S26
10000
2.7
22×50
S27
25×25
S32
3300
1.7
25×30
S33
6800
2.5
4700
2.1
25×35
S34
10000
3.2
25×40
S35
25×45
S36
25×50
S37
10000
3.0
6800
2.6
4700
2.4
3300
2.0
2200
2.0
1500
1.8
30×25
S42
6800
2.6
4700
2.2
3300
2.3
2200
1.9
1500
1.6
1000
1.3
680
1.1
30×30
S43
10000
3.3
6800
2.7
4700
2.8
3300
2.4
2200
1.9
1500
1.6
1000
1.4
30×35
S44
30×40
S45
10000
3.1
2.7
4700
2.4
3300
2.1
2200
2.1
1500
1.8
30×45
S46
30×50
S47
10000
3.4
6800
3.1
4700
2.6
3300
2.2
2200
1.8
35×25
S52
10000
3.4
6800
2.8
4700
2.9
3300
2.4
2200
2.0
1500
1.7
1000
1.5
35×30
S53
10000
3.1
6800
2.7
4700
2.5
3300
2.1
2200
2.1
1500
1.8
35×35
S54
35×40
S55
10000
3.5
6800
3.1
4700
2.6
3300
2.2
2200
1.8
35×45
S56
35×50
S57
6800
3.3
4700
2.7
6800
6800
6800
2.2
2.7
2200
1.5
2.3
2200
1.6
3300
2.0
1500
1.3
1000
1.2
2200
1.7
1500
1.4
1000
1.2
680
1.0
3300
2.2
2200
1.8
1500
1.5
1000
1.2
680
1.1
4700
4700
6800
2.8
3300
2.3
2200
1.9
1500
1.6
1000
1.4
(Note) Rated ripple current : 85℃, 120Hz.
FOR AUDIO
ALUMINUM
NOTE : Design,
177
CAT.No.2015/2016E
很抱歉,暂时无法提供与“LAO-25V103MS37PX#B”相匹配的价格&库存,您可以联系我们找货
