42M048C1B-Z36
42M048C1B-Z36
    PORTESCAP
    STEP MOTOR PM GEARED BIPOLAR 5V
42M048C1B-Z36 数据手册
How to select your CanStack motor Selection Criteria • The Torque – Speed Curves are essential for selecting the right motor and control drive method for a specific application. • Define your application load – speed required, load inertia, torque and accuracy needed. • If the application requires no acceleration, then use the pull out torque. • If the load is inertial (acceleration is required), it is advisable to use pull in torque. • Motor temperature rise is important – so ambient temperature and duty cycle are important selection factors • It is advisable to use 1.5 to 2 times the margin over the maximum torque required. • Choosing the correct drive is important – for example micro-stepping drives will provide quieter operation. • Our engineering team is capable of designing a special coil with resistance and inductances to suit your needs. • Remember – if it is not in the catalog – it does not mean that we cannot provide a solution for you - Portescap may still be able to design a product for your needs as our team can draw from a wealth of customized designs created over the past 40 years. CANSTACK Motor Designation 26M048D2B 26 Motor Diameter (mm) 15 20 26 35 42 55 M 048 D 2 B Rotor Dia S = Small M = Medium L = Large Steps per Rev 020: 20 ppr 024: 24 ppr 048: 48 ppr 100: 100 ppr Magnet Type B = Ferrite C = He Ferrite D = Neodymium Voltage 1=5V 2 = 12 V Coil U = Unipolar B = Bipolar
42M048C1B-Z36 价格&库存
很抱歉,暂时无法提供与“42M048C1B-Z36”相匹配的价格&库存,您可以联系我们找货
