ROB-11593
ROB-11593
    SPARKFUNELECTRONICS
    Brushed DC 5VDC Supply 4A
ROB-11593 数据手册
4 Channel Motor Control Unit Designed originally for the Rover 5 chassis this driver PCB is ideal for any small robot using either Omni or Mecanum wheels. Current sensing for each motor allows the processor to determine if a motor has stalled or is under excessive load. Features include: • • • • • 4x low resistance FET “H” bridges. Each channel rated for 4A stall current. Easy to use control logic. Current monitoring for each channel. Quadrature encoder mixing circuitry. Power connectors: The PCB has two power connectors. One is +5V for logic (Vcc) and one for the motor power supply. The motor power supply should not be connected without first connecting the +5V for logic. This device is rated for a maximum motor supply voltage of 12V. Exceeding this voltage may permanently damage the device. The encoder mixing circuit: Unlike most motor controllers this PCB includes 4 mixing circuits for use with up to 4 quadrature encoders. The mixing circuit takes the 2 inputs from a quadrature encoder and mixes them into a single output. Note that the interrupt output changes state when either input changes. This allows a single interrupt pin to monitor both inputs of a quadrature encoder. Because the interrupt output is twice the frequency of either input it also allows speed and distance to be measured with twice the resolution. Current output: Each channel has a current sensing circuit. The output of this circuit is approximately 1V for each amp the motor draws (5V maximum). This output can be connected directly to the analog input of any 5V micro controller. Control logic: The built in control logic allows each motor to be controlled by 2 pins. Driving the direction pin high or low will cause the motor to run forward or reverse. The PWM pin is used to control the motor speed. When this pin is low, the motor is off. When this pin is high the motor is at full power. To vary the speed of the motor this pin must be Pulse Width Modulated. Motor output: Each channel has a motor output socket. Connect any 4.5V –12V DC motor with a stall current of less than 4.5A to these pins. Exceeding 4.5A on these pins may permanently damage this device.
ROB-11593 价格&库存
很抱歉,暂时无法提供与“ROB-11593”相匹配的价格&库存,您可以联系我们找货
