2 x 2032 Coin Cell Battery Holder - 6V
output with On/Off switch
PRODUCT ID: 783
DESCRIPTION
This tiny coin cell battery holder is ideal for small portable or wearable projects. It
holds two 20mm coin cells (2032 are the most popular size) in series to generate
6V nominal. (If you want only 3V, we suggest sticking a crumpled piece of tin foil in
one of the slots.) 20mm coin cells are popular as they are used in keychain lights,
so they are easy to get, and fairly low cost. They tend to have about 220mAh
capacity so this holder would give you 6V @ 220mAh with two cells.
The holder is made of plastic and snaps open and closed. You can tape it closed if
you need more security than just the plastic snap. A nice extra is the on/off switch
up top. We had the factory place a 2mm JST PH connector on the end but you can
cut it off if you want to solder on a different connector.
This item does not include any 2032 coin cells. We do stock those separately, so if
you want batteries to go with this, please pick up two of them!
http://www.adafruit.com/product/783
11/12/2015
Technical Details
Weight: 4.7 grams when empty, 10.5 grams with two 2032 batteries installed
Size: 53mm x 23mm x 6mm
6" long (150mm) wires
很抱歉,暂时无法提供与“783”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16.372901+1.98050
- 国内价格 香港价格
- 3+20.043073+2.42359
- 国内价格 香港价格
- 1+20.081981+2.42830
