266
    KEYSTONE
    LAMP INCAND 5MM MIDG GROOVE 2.5V
266 数据手册
R TI F I ED 9 VOLT STRAPS & CONNECTORS 2 T Y CE 900 ISO Q I UAL SHIELDED 9 VOLT BATTERY STRAPS • Insulates and shields 9 Volt battery • Protects 9 Volt batteries and battery packs when they are not in use • Snap-fits onto battery contacts • Both male and female contacts are covered, minimizing physical damage snap-on connector contacts • Assures safe secure use, reduces the potential of short circuits and prevents tampering with battery contacts • Protects circuits, prevents unwanted electrical discharge due to unintended grounding • Protects battery contacts from dust, dirt, and physical damage • Ideal for rugged applications, made of high impact molded plastic with integral wire lead strain relief SPECIFICATIONS Base: Polypropylene Male/Female Contacts: Brass, Nickel Plate Wires (Red & Black): #26AWG, Tinned, .187 end strip, UL/CSA1007 CAT. NO. 84-4 84-6 84-8 *LEAD LENGTH 4.00 6.00 8.00 I -STYLE *Tolerance on lead length +/-.250 which can occur during battery handling, shipping and storage • Shields the battery contacts and reduces the potential of a short circuit between battery poles • Protects sensitive electronic equipment, systems and circuits, cap prevents unwanted electrical discharges • Protects the battery contacts from damage due to dust, dirt and contamination MATERIAL: Impact Resistant Polypropylene, Black CAT. NO. 81-4 81-6 81-8 *LEAD LENGTH 4.00 6.00 8.00 CAT. NO. 96 T -STYLE with Strain Relief *Tolerance on lead length +/-.250 VERTICAL 9 VOLT PC SNAP-ONS • Space saving, economical • Excellent mechanical strength • Low contact resistance PROTECTIVE BATTERY CAP • Durable fibre base • Wave solderable • Anti-Wicking Design BATTERY SNAP-ONS For most electronic applications requiring a quick connect and disconnect of circuit. Commonly used with 9 Volt or other batteries designed with snap fasteners. Ideal for temporary or permanent means of connecting without soldering. Can be cascaded together for multiple connections. DIMENSIONS FOR REFERENCE ONLY FIG. 1 FIG. 3 Stud only 22 FIG. 4 Socket only • Cost saving design • Ideal for custom applications • Attach your own terminals and wire leads CAT. NO. 68 - Without PC Pins on Phenolic Washer FIG. 6 Mounting Detail CAT. NO. 968 - With PC Pins SPECIFICATIONS Base: .062 Fibre Contacts: Steel, Nickel Plate FIG. 5 Stud w/Crimp Lugon FIG. 2 SPECIFICATIONS Base: .062 Fibre Contacts: Steel, Nickel Plate Pins: Brass, Tin Plate (Miniature and Standard) CAT. NO. 261 262 269 270 263 264 271 272 265 266 273 274 FIG. NO. 1 1 2 2 3 3 4 4 5 6 5 6 Socket w/Crimp Lugon A .225 .283 .205 .265 .225 .283 .205 .265 .225 .205 .283 .265 B .135 .143 .156 .156 .170 .185 .200 .185 .205 .205 .200 .225 C .312 .425 — — .790 .840 .790 .835 .500 .500 .500 .500 Jr. Sr. Jr. Sr. Jr. Sr. Jr. Sr. Jr. Jr. Sr. Sr. on Phenolic Washer DESCRIPTION Stud only-.093 hole Stud only-.125 hole Socket only-.093 hole Socket only-.125 hole Stud w/ Lug Stud w/ Lug Socket w/ Lug Socket w/ Lug Stud on Phenolic Washer Socket on Phenolic Washer Stud on Phenolic Washer Socket on Phenolic 31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040 e-mail: kec@keyelco.com • WebSite: keyelco.com
很抱歉,暂时无法提供与“266”相匹配的价格&库存,您可以联系我们找货
