Additional Resources:
Product Page
3D Model
date
04/24/2022
page
1 of 5
SERIES: SWI5-N │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 6 W continuous power
DoE Level VI efficiency
universal input voltage range
ultra-compact case
no load power consumption < 0.075 W
over voltage, over current, and short circuit protections
UL/cUL, PSE, FCC safety approvals
Class II construction
IEC 62368-1
black and white case options
MODEL
output
voltage
output
current
output
power
ripple
and noise1
typ
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
SWI5-5-N
5
1
5
300
VI
SWI5-5B-N
5
1.2
6
300
VI
SWI5-9-N
9
0.6
5.4
300
VI
12
0.5
6
300
VI
SWI5-12-N
Notes:
efficiency
level
1. At full load, 25°C, at 115/230 Vac input, 20 MHz bandwidth oscilloscope, output terminated with 0.1 µF and 10 µF capacitors.
PART NUMBER KEY
SWI5 - XX - NX - XXX - CXX
Reserved for Custom
Configurations
Base Number
Output Voltage
AC Input Type:
North America
Case color:
“blank” = black
W = white
cui.com
DC Plug Type:
XXX = See output plug options
on page 4 for more details
Product Page
3D Model
CUI Inc │ SERIES: SWI5-N │ DESCRIPTION: AC-DC POWER SUPPLY
date 04/24/2022 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
typ
90
frequency
47
current
at nominal input voltage
leakage current
at nominal input voltage & frequency
at 115/230 Vac, 60/50 Hz
max
units
264
Vac
63
Hz
0.2
A
0.25
mA
0.075
W
max
units
OUTPUT
parameter
min
typ
line regulation
±5
load regulation
±5
start-up time
hold-up time
3
at nominal input voltage & full load
5
s
ms
PROTECTIONS
parameter
over voltage protection
5 Vdc output model
5 Vdc output B model
9 Vdc output model
12 Vdc output model
min
over current protection
output shut down, auto recovery
5 Vdc output model
9 Vdc output model
12 Vdc output model
typ
max
units
6.5
8.0
18.0
15.6
Vdc
Vdc
Vdc
Vdc
1.8
2.4
1.2
0.9
A
A
A
A
max
units
SAFETY & COMPLIANCE
parameter
min
isolation voltage
input to output at 10 mA for 1 minute
safety approvals
62368: UL
60950: PSE
EMI/EMC
FCC Part 15B Class B
MTBF
as per Telcordia SR-332 (Issue 2), at 115/230 Vac,
full load, 0°C~40°C
RoHS
2011/65/EU
typ
3,000
4,242
Vac
Vdc
50,000
hours
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
max
units
typ
40
°C
-20
60
°C
operating humidity
non-condensing
storage humidity
non-condensing
5
95
cui.com
Product Page
3D Model
date 04/24/2022 │ page 3 of 5
MECHANICAL
parameter
dimensions
66.5 x 25.4 x 51.3
inlet plug
North America, 2-pin
min
typ
max
units
mm
weight
58
MECHANICAL DRAWING
units: mm
DC CORD
units: mm
Table 1
MODEL NO.
CABLE
CORD LENGTH
SWI5-5-N
UL2468, 24 AWG
1,500 mm ±50
SWI5-5B-N
UL2468, 24 AWG
1,500 mm ±50
SWI5-9-N
UL2468, 24 AWG
1,500 mm ±50
SWI5-12-N
UL2468, 24 AWG
1,500 mm ±50
cui.com
g
Product Page
3D Model
date 04/24/2022 │ page 4 of 5
DC PLUG TYPE PART NUMBER KEY
XXX
Plug Polarity:
P = Center Positive
Plug Code:
X = Choose a code from the
options below
Plug Angle:
“blank” = Straight
R = Right Angle
N = Center Negative
Plug Polarity
Code
Dimensions (mm)
Plug Angle
Center Pos.
Center Neg.
Option
Type
A
B
C
Straight
Right
5
Standard
5.5
2.1
9.5
6
Standard
5.5
2.5
9.5
7
Standard
3.5
1.35
9.5
8
Standard
3.8
1.35
9.5
9
Standard
3.8
1.05
9.5
10
Locking2
5.5
2.1
9.5
N/A
11
Locking2
5.5
2.5
9.5
N/A
12
EIAJ-1
2.35
0.7
9.5
13
EIAJ-2
4.0
1.7
9.5
14
EIAJ-3
4.75
1.7
9.5
N/A
N/A
ST
N/A
N/A
N/A
MUB
N/A
N/A
USB
Micro USB Type B
1. Contact CUI for additional plug options
2. Maximum insertion depth is 10mm
Locking
C
A
B
B
C
Right Angle (R)
C
A
C
Straight
Straight
Right Angle (R)
Stripped & Tinned
USB
5.8±0.5
2.5±0.3
A
B
C
EIAJ
A
A
B
Standard
B
Note:
Stripped & Tinned
P5(-)
cui.com
P1(+)
Product Page
3D Model
date 04/24/2022 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
11/23/2016
1.01
company logo updated
09/21/2020
1.02
safety marks updated
04/22/2021
1.03
specification updated to show 62368 on safety line
05/12/2021
1.04
updated datasheet
08/09/2021
1.05
product image updated
08/20/2021
1.06
minimum current ratings updated
11/04/2021
dc plugs updated
04/24/2022
1.07
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“SWI5-5-N-P5”相匹配的价格&库存,您可以联系我们找货
