Additional Resources:
Product Page
3D Model
date
06/15/2022
page
1 of 5
SERIES: SWI6-E │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 6 W continuous power
DOE Level VI, CEC, ErP Stage 2
no load power consumption < 0.1 W
compact size
universal input voltage range
over voltage, over current, and short circuit protections
CE safety approvals
EN 62368 compliant
MODEL
input
voltage
input
frequency
output
voltage
output
current
output
power
ripple
and
noise1
efficiency
level
no load power
consumption
range
(Vac)
range
(Hz)
nom
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
average2
10%
typ
(W)
SWI6-3.3-E
90 ~ 264
47 ~ 63
3.3
1.5
4.95
100
74.0
63.3
0.03
SWI6-5-E
90 ~ 264
47 ~ 63
5
1.5
7.5
100
77.5
66.7
0.05
SWI6-5.9-E
90 ~ 264
47 ~ 63
5.9
1.2
7.08
100
78.7
65.0
0.05
SWI6-7.5-E
90 ~ 264
47 ~ 63
7.5
1.0
7.5
100
80.3
70.1
0.04
SWI6-9-E
90 ~ 264
47 ~ 63
9
0.67
6.03
100
79.9
66.6
0.04
SWI6-12-E
90 ~ 264
47 ~ 63
12
0.6
7.2
120
80.9
65.1
0.05
SWI6-15-E
90 ~ 264
47 ~ 63
15
0.5
7.5
150
80.9
63.3
0.06
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, each output terminated with 0.1 μF multilayer ceramic and 47 μF low ESR electrolytic capacitors.
2. Average efficiency is measured at 25%, 50%, 75%, and 100% load.
PART NUMBER KEY
SWI6 - XX - E - XXX - CXX
Reserved for Custom
Configurations
Base Number
Output Voltage
AC Input Type:
Europe
cui.com
DC Plug Type:
XXX = See output plug options
on page 4 for more details
ST = Stripped and Tinned
Product Page
3D Model
CUI Inc │ SERIES: SWI6-E │ DESCRIPTION: AC-DC POWER SUPPLY
date 06/15/2022 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
90
frequency
47
typ
current
inrush current
at 240 Vac, full load, 25°C, cold start
leakage current
max
units
264
Vac
63
Hz
0.19
A
60
A
0.25
mA
0.1
W
max
units
OUTPUT
parameter
min
regulation
hold-up time
typ
±5
at full load
10
ms
PROTECTIONS
parameter
over voltage protection
output shut down
over current protection
output shut down, auto recovery
min
typ
max
units
min
typ
max
units
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output at 10 mA for 1 minute
isolation resistance
input to output at 500 Vdc
safety approvals
EN 62368
EMI/EMC
CE
MTBF
as per Telcordia SR-332, 25°C
RoHS
2011/65/EU
3,000
Vac
10
MΩ
300,000
hours
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
max
units
typ
40
°C
-20
60
°C
operating humidity
non-condensing
storage humidity
non-condensing
10
90
cui.com
Product Page
3D Model
date 06/15/2022 │ page 3 of 5
MECHANICAL
parameter
dimensions
56 x 28 x 60
inlet plug
Europe
min
typ
96
MECHANICAL DRAWING
units: mm
DC CORD
cord length
80±5
units
mm
weight
units: mm
max
Table 1
MODEL NO.
CABLE
CORD LENGTH
SWI6-3.3-E
UL2468
1,500 mm ±30
SWI6-5-E
UL2468
1,500 mm ±30
SWI6-5.9-E
UL2468
1,500 mm ±30
SWI6-7.5-E
UL2468
1,500 mm ±30
SWI6-9-E
UL2468
1,500 mm ±30
SWI6-12-E
UL2468
1,500 mm ±30
SWI6-15-E
UL2468
1,500 mm ±30
cui.com
g
Product Page
3D Model
date 06/15/2022 │ page 4 of 5
DC PLUG TYPE PART NUMBER KEY
XXX
Plug Polarity:
P = Center Positive
Plug Code:
X = Choose a code from the
options below
Plug Angle:
“blank” = Straight
R = Right Angle
N = Center Negative
Plug Polarity
Code
Dimensions (mm)
Plug Angle
Center Pos.
Center Neg.
Option
Type
A
B
C
Straight
Right
5
Standard
5.5
2.1
9.5
6
Standard
5.5
2.5
9.5
7
Standard
3.5
1.35
9.5
8
Standard
3.8
1.35
9.5
9
Standard
3.8
1.05
9.5
10
Locking2
5.5
2.1
9.5
N/A
11
Locking2
5.5
2.5
9.5
N/A
12
EIAJ-1
2.35
0.7
9.5
13
EIAJ-2
4.0
1.7
9.5
14
EIAJ-3
4.75
1.7
9.5
N/A
N/A
ST
N/A
N/A
N/A
N/A
MUB
USB
Micro USB Type B
N/A
N/A
N/A
CUB
USB
USB Type C
N/A
Note:
Stripped & Tinned
1. Contact CUI for additional plug options
2. Maximum insertion depth is 10mm
cui.com
Product Page
3D Model
date 06/15/2022 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
08/07/2015
1.01
added models
08/12/2015
1.02
updated drawing
12/16/2015
1.03
company logo updated
09/21/2020
1.04
updated dc plug options & model table
12/04/2020
1.05
safeties updated
12/09/2020
1.06
plug polarity symbols updated
09/16/2021
1.07
dc plugs updated
06/15/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“SWI6-5-E-P6R”相匹配的价格&库存,您可以联系我们找货
