date 09/2010
page 1 of 8
a division of CUI INC
SERIES:
DESCRIPTION:
40 W DESKTOP
SWITCHING POWER SUPPLY
FEATURES
•universal AC input
•regulated output voltage
•short circuit, over load protection
•LED indicator for power on
•meets EISA / efficiency level IV regulations
•custom designs available
MODEL
output voltage
nominal
(V dc)
min
(A)
max
(A)
ETS090400U
9
ETS120416U
12
ETS150270U
15
ETS240170U
24
output wattage
ripple*
max
(W)
max.
(mVp-p)
36
150
IV
1000 +150/-0
4.16
49.9
120
IV
1530 +150/-0
2.7
40.5
150
IV
1500 +150/-0
1.7
40.8
150
IV
1830 +150/-0
nt
in
output current
ue
d
RoHS
efficiency level
cord length
(mm)
D
is
co
*at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
ETS120416U T C - PXXXX - SZ - CXX
Base Number
Reserved for custom
configurations
example of 12 V dc, 4.16 A
AC Input Plug:
blank = IEC 320 C14 plug
T = IEC 320 C6 plug
Factory
Designation
Input Cable:
C = included
blank = no cable
20050 SW 112th Ave. Tualatin, Oregon 97062
DC Plug type:
see output plug options
on page 5
phone 503.612.2300
fax 503.612.2382 www.v-infinity.com
date 09/2010
page 2 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
INPUT
parameter
max
units
rated input voltage
conditions/description
min
100
nom
240
V ac
input voltage range
90
255
V ac
rated frequency
50
60
Hz
frequency range
47
rated input current
63
Hz
1.2
A
115 V ac, full load, cold start, 25°C
230 V ac, full load, cold start, 25°C
50
100
A
A
no load power consumption
0.5
W
max
units
ue
d
inrush current
OUTPUT
parameter
min
line regulation
load regulation
output shut down
short circuit protection
output shut down and auto-restart
nt
SAFETY & EMI
in
over voltage protection
HI-POT
input to output at 10 mA for 1 second
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1)
EMI standard
is
co
parameter
±1
±5
110%
min
nom
150%
V dc
max
units
1500
3000
V ac
V ac
100
M
FCC part 15 class B, CE (EN55022, EN55024)
3.5
mA
yes
D
leakage current
RoHS compliant
nom
ENVIRONMENTAL
parameter
min
max
units
°C
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
operating temperature
phone 503.612.2300
nom
date 09/2010
page 3 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
MECHANICAL DRAWING (9, 15, 24 V models)
107.5 L x 56 W x 33.7 H mm
tolerance: ±1 mm
ue
d
case size
56±1
co
is
D
107.5±1
nt
in
33.7±1
phone 503.612.2300
date 09/2010
page 4 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
MECHANICAL DRAWING (12 V model)
97 L x 62 W x 33 H mm
tolerance: ±1 mm
D
is
co
nt
in
ue
d
case size
phone 503.612.2300
date 09/2010
page 5 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
Black wire, white stripe: Positive
80±20
Cable Gauge
18 AWG
ETS090400
18 AWG
ETS120416
18 AWG
ETS150270
18 AWG
ETS240170
80
co
D
is
Cable Length: refer to page 1
nt
Ferrite core:14.2X28.5X8.2(003)
in
48B
ue
d
60±5
S&T
DC CORD
phone 503.612.2300
date 09/2010
page 6 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
OUTPUT PLUG OPTIONS
3.5 mm Phono Plug
14 ±0.5
14 ±0.5
*Tip positive
P1R
Standard DC Plug
C
in
B
2.1
2.5
1.3
1.35
1.05
CU
9.5
9.5
9.5
9.5
9.5
nit
mm
mm
mm
mm
mm
co
A
5.5
5.5
B
2.1
2.5
CU
9.5
9.5
nit
mm
mm
D
is
A
B
P10
P11
EIAJ
A
B
P12/P12R EIAJ-1 2.35 0.7
P13/P13R EIAJ-2 4.0 1.7
P14/P14R EIAJ-3 4.75 1.7
B
B
A
C
A
A
5.5
5.5
3.5
3.8
3.8
Right Angle PXR
Locking DC Plug
EIAJ Plugs
P5/P5R
P6/P6R
P7/P7R
P8/P8R
P9/P9R
nt
Standard PX
C
B
A
B
A
C
ue
d
P1
C
9.5
9.5
9.5
DU nit
NA mm
5.0 mm
5.0 mm
C
Standard PXX
D
Right Angle PXXR
PART NUMBER GUIDE
PXX X X
Plug type
Plug angle:
“blank” = standard
R = right angle
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
*Contact CUI for additional output plug options.
phone 503.612.2300
date 09/2010
page 7 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
AC CORD
C14
D
is
co
nt
in
ue
d
C6
*Contact CUI for additional ac cord input blade options.
phone 503.612.2300
date 09/2010
page 8 of 8
SERIES:
DESCRIPTION:
40 W DESKTOP
INDIVIDUAL PACKAGING
tolerance
± 1 mm
RoHS Compliant
tolerance
+7 / -0 mm
D
is
PACKAGING
co
nt
in
ue
d
CORRUGATED PAPER
phone 503.612.2300
ETS240170UTC-P5P-SZ 价格&库存
很抱歉,暂时无法提供与“ETS240170UTC-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
