date 03/2010
page 1 of 8
a division of CUI INC
SERIES:
DESCRIPTION:
60 W DESKTOP
SWITCHING POWER SUPPLY
FEATURES
•universal AC input
•regulated output voltage
•short circuit, over load protection
•meets EISA / efficiency level IV regulations
•custom designs available
MODEL
output voltage
nominal
(V dc)
min
(A)
max
(A)
ETS120500U
12
ETS150400U
15
ETS190315U
19
ETS240250U
24
output wattage
ripple
max
(W)
max.
(mVp-p)
60
240
IV
1830 +150/-0
4
60
240
IV
1830 +150/-0
3.15
60
240
V
1830 +150/-0
2.5
60
240
V
1830 +150/-0
nt
in
output current
ue
d
RoHS
efficiency level
cord length
(mm)
D
is
co
*at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
ETS120500U T C - PXXXX - SZ - CXX
Base Number
Reserved for custom
configurations
example of 12 V dc, 5 A
AC Input Plug:
blank = IEC 320 C14 plug
T = IEC 320 C6 plug
Factory
Designation
Input Cable:
C = included
blank = no cable
20050 SW 112th Ave. Tualatin, Oregon 97062
DC Plug type:
see output plug options
on page 5
phone 503.612.2300
fax 503.612.2382 www.v-infinity.com
date 03/2010
page 2 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
INPUT
parameter
max
units
rated input voltage
conditions/description
min
100
nom
240
V ac
input voltage range
90
264
V ac
rated frequency
50
60
Hz
frequency range
47
rated input current
63
Hz
1.5
A
115 V ac, full load, cold start, 25°C
230 V ac, full load, cold start, 25°C
50
100
A
A
no load power consumption
0.5
W
max
units
ue
d
inrush current
OUTPUT
parameter
min
line regulation
load regulation
output shut down
short circuit protection
output shut down and auto-restart
HI-POT
input to output at 10 mA for 1 second
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1),
RCM
EMI standard
co
parameter
is
nt
SAFETY & EMI
in
over voltage protection
±5
140%
min
nom
160%
V dc
max
units
1500
V ac
100
M
3.5
mA
yes
D
LPS power supply
±1
FCC part 15 class B, CE (EN55022, EN55024)
leakage current
RoHS compliant
nom
yes
ENVIRONMENTAL
parameter
min
max
units
°C
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
operating temperature
phone 503.612.2300
nom
date 03/2010
page 3 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
MECHANICAL DRAWING
116 L x 50 W x 31 H mm
tolerance: ±1 mm
D
is
co
nt
in
ue
d
case size
phone 503.612.2300
date 03/2010
page 4 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
Cable Gauge
18 AWG
ETS120500
18 AWG
ETS150400
18 AWG
ETS190315
18 AWG
ETS240250
Black wire, white stripe: Positive
co
D
is
Cable Length: refer to page 1
nt
in
ue
d
DC CORD
phone 503.612.2300
date 03/2010
page 5 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
OUTPUT PLUG OPTIONS
3.5 mm Phono Plug
14 ±0.5
14 ±0.5
*Tip positive
P1R
Standard DC Plug
C
in
B
2.1
2.5
1.3
1.35
1.05
C
12
12
9.5
9.5
9.5
Unit
mm
mm
mm
mm
mm
co
A
5.5
5.5
B
2.1
2.5
C
9.5
9.5
Unit
mm
mm
D
is
A
B
P10
P11
EIAJ
A
B
P12/P12R EIAJ-1 2.35 0.7
P13/P13R EIAJ-2 4.0 1.7
P14/P14R EIAJ-3 4.75 1.7
B
B
A
C
A
A
5.5
5.5
3.5
3.8
3.8
Right Angle PXR
Locking DC Plug
EIAJ Plugs
P5/P5R
P6/P6R
P7/P7R
P8/P8R
P9/P9R
nt
Standard PX
C
B
A
B
A
C
ue
d
P1
C
9.5
9.5
9.5
D
NA
5.0
5.0
Unit
mm
mm
mm
C
Standard PXX
D
Right Angle PXXR
PART NUMBER GUIDE
PXX X X
Plug type
Plug angle:
“blank” = standard
R = right angle
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
*Contact CUI for additional output plug options.
phone 503.612.2300
date 03/2010
page 6 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
AC CORD
C14
D
is
co
nt
in
ue
d
C6
*Contact CUI for additional ac cord input blade options.
phone 503.612.2300
date 03/2010
page 7 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
INDIVIDUAL PACKAGING
± 1 mm
D
is
co
nt
in
ue
d
tolerance
phone 503.612.2300
date 03/2010
page 8 of 8
SERIES:
DESCRIPTION:
60 W DESKTOP
PACKAGING
+7 / -0 mm
D
is
co
nt
in
ue
d
tolerance
phone 503.612.2300
ETS150400UTC-P5P-SZ 价格&库存
很抱歉,暂时无法提供与“ETS150400UTC-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
