ETS120500UTC-P5P-SZ
ETS120500UTC-P5P-SZ
    CUIDEVICES
    AC/DC DESKTOP ADAPTER 12V 60W
ETS120500UTC-P5P-SZ 数据手册
date 03/2010 page 1 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY FEATURES •universal AC input •regulated output voltage •short circuit, over load protection •meets EISA / efficiency level IV regulations •custom designs available MODEL output voltage nominal (V dc) min (A) max (A) ETS120500U 12 0 5 ETS150400U 15 0 ETS190315U 19 0 ETS240250U 24 0 output wattage ripple max (W) max. (mVp-p) 60 240 IV 1830 +150/-0 4 60 240 IV 1830 +150/-0 3.15 60 240 V 1830 +150/-0 2.5 60 240 V 1830 +150/-0 nt in output current ue d RoHS efficiency level cord length (mm) D is co *at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output PART NUMBER KEY ETS120500U T C - PXXXX - SZ - CXX Base Number Reserved for custom configurations example of 12 V dc, 5 A AC Input Plug: blank = IEC 320 C14 plug T = IEC 320 C6 plug Factory Designation Input Cable: C = included blank = no cable 20050 SW 112th Ave. Tualatin, Oregon 97062 DC Plug type: see output plug options on page 5 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com date 03/2010 page 2 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY INPUT parameter max units rated input voltage conditions/description min 100 nom 240 V ac input voltage range 90 264 V ac rated frequency 50 60 Hz frequency range 47 rated input current 63 Hz 1.5 A 115 V ac, full load, cold start, 25°C 230 V ac, full load, cold start, 25°C 50 100 A A no load power consumption 100 ~ 240 V ac input 0.5 W max units ue d inrush current OUTPUT parameter conditions/description min line regulation load regulation output shut down short circuit protection output shut down and auto-restart conditions/description HI-POT input to output at 10 mA for 1 second insulation resistance input to output at 500 V dc safety approvals UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1), RCM EMI standard co parameter is nt SAFETY & EMI in over voltage protection % ±5 % 140% min nom 160% V dc max units 1500 V ac 100 M 3.5 mA yes D LPS power supply ±1 FCC part 15 class B, CE (EN55022, EN55024) leakage current RoHS compliant nom yes ENVIRONMENTAL parameter conditions/description min max units 0 40 °C operating humidity 20 80 % storage temperature -10 70 °C storage humidity 10 90 % operating temperature 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 nom fax 503.612.2382 www.v-infinity.com date 03/2010 page 3 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY MECHANICAL DRAWING 116 L x 50 W x 31 H mm tolerance: ±1 mm D is co nt in ue d case size 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com date 03/2010 page 4 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY Cable Gauge 18 AWG ETS120500 18 AWG ETS150400 18 AWG ETS190315 18 AWG ETS240250 Black wire, white stripe: Positive co D is Cable Length: refer to page 1 nt in ue d DC CORD 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com date 03/2010 page 5 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY OUTPUT PLUG OPTIONS 3.5 mm Phono Plug 14 ±0.5 14 ±0.5 *Tip positive P1R Standard DC Plug C in B 2.1 2.5 1.3 1.35 1.05 C 12 12 9.5 9.5 9.5 Unit mm mm mm mm mm co A 5.5 5.5 B 2.1 2.5 C 9.5 9.5 Unit mm mm D is A B P10 P11 EIAJ A B P12/P12R EIAJ-1 2.35 0.7 P13/P13R EIAJ-2 4.0 1.7 P14/P14R EIAJ-3 4.75 1.7 B B A C A A 5.5 5.5 3.5 3.8 3.8 Right Angle PXR Locking DC Plug EIAJ Plugs P5/P5R P6/P6R P7/P7R P8/P8R P9/P9R nt Standard PX C B A B A C ue d P1 C 9.5 9.5 9.5 D NA 5.0 5.0 Unit mm mm mm C Standard PXX D Right Angle PXXR PART NUMBER GUIDE PXX X X Plug type Plug angle: “blank” = standard R = right angle Plug polarity: “blank” = N/A P = center positive N = center negative *Contact CUI for additional output plug options. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com date 03/2010 page 6 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY AC CORD C14 D is co nt in ue d C6 *Contact CUI for additional ac cord input blade options. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com date 03/2010 page 7 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY INDIVIDUAL PACKAGING ± 1 mm D is co nt in ue d tolerance 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com date 03/2010 page 8 of 8 a division of CUI INC SERIES: DESCRIPTION: 60 W DESKTOP SWITCHING POWER SUPPLY PACKAGING +7 / -0 mm D is co nt in ue d tolerance 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 www.v-infinity.com
ETS120500UTC-P5P-SZ 价格&库存
很抱歉,暂时无法提供与“ETS120500UTC-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
