EPS120050-P7P
EPS120050-P7P
    CUIDEVICES
    AC/DC WALL MOUNT ADAPTER 12V 6W
EPS120050-P7P 数据手册
Additional Resources: Product Page date 04/18/2013 page 1 of 5 SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY up to 6 W power compact size single output from 3~24 V over voltage and short circuit protections custom designs available U • • • • • ED FEATURES output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) 1 3 100 IV 1 3.3 100 IV 1 4.5 100 V 1 5 100 V 1 6 100 V 7.5 0.8 6 100 IV 9 0.66 6 100 V 12 0.5 6 120 V 15 0.4 6 150 V 18 0.33 6 180 V 24 0.25 6 240 IV 3 EPS033100 3.3 EPS045100 4.5 EPS050100 5 EPS060100 6 N EPS030100 EPS075080 EPS090066 EPS180033 EPS240025 efficiency level 1. At full load, 100 ~ 132 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors. IS C Notes: O EPS120050 EPS150040 TI MODEL N RoHS D PART NUMBER KEY Base Number example of 3 Vdc, 1 A EPS030100 - PXXXX - CXX DC Plug Type cui.com Reserved for Custom Configurations Additional Resources: Product Page CUI Inc │ SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 04/18/2013 │ page 2 of 5 INPUT parameter conditions/description min voltage 47 current inrush current1 no load power consumption 15V, 18V and 24V model at 100 Vac at 132 Vac all other models at 132 Vac level IV models level V models 1. inrush lasts no longer than 0.5 ms before settling to steady state current conditions/description line regulation all other models 7.5V model min load regulation N parameter U OUTPUT temperature coefficient 0 ~ 40°C, full load, after initial 1 hour warm-up start-up time needed to reach regulation hold-up at 115 Vac, full load conditions/description clamped by internal protection zener short circuit protection continuous, auto-recovery upon removal of short isolation voltage isolation resistance safety approvals EMI/EMC typ 63 Hz 0.15 A 15 30 A A 40 A 0.5 0.3 W W max units % % ±5 % ±0.02 %/°C 3 input to output at 500 Vdc s ms min typ min typ max units max units 3,000 4,242 Vdc Vdc 100 MΩ UL 1310 class II FCC Part 15 Class B leakage current RoHS compliant Vac ±1 ±2 input to output at 10 mA for 1 minute IS C safety conditions/description O parameter N parameter over voltage protection SAFETY & COMPLIANCE units 132 10 TI PROTECTIONS max ED frequency Notes: typ 100 0.25 mA max units yes ENVIRONMENTAL parameter conditions/description min 0 40 °C storage temperature -10 70 °C operating humidity 20 80 % 10 90 % D operating temperature typ storage humidity cui.com Additional Resources: Product Page CUI Inc │ SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 04/18/2013 │ page 3 of 5 MECHANICAL min input plug fixed US MECHANICAL DRAWING units: mm tolerance: X.X ±0.5 X.XX ±0.03 42 1.0 26.8 1.0 12.7 62.33 1.0 IS C O N TI 22.3X18.0 1830 100 6.3 D 3.0 (TYP) cui.com max units mm N 17.06 1.18 typ ED conditions/description 62.33 x 26.8 x 42 (2.454 x 1.055 x 1.654 inch) U parameter dimensions Additional Resources: Product Page CUI Inc │ SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 04/18/2013 │ page 4 of 5 OUTPUT PLUG OPTIONS IJĵġƲıįĶ ED ǹĴįĶġĬıİĮıįIJ ǹĴįĶġĬıİĮıįIJ 3.5 mm Phono Plug IJĵġƲıįĶ P1 P1R ń Standard PXX C Unit 121 mm 5.5 2.5 12 mm P7/P7R 3.5 1.35 9.5 mm P8/P8R 3.8 1.35 9.5 mm 3.8 1.05 9.5 mm P9/P9R N ł O IS C Ń ń B 2.1 P6/P6R Notes: Ń ł Ń ń A 5.5 N Right Angle PXR Locking DC Plug EIAJ Plugs P5/P5R TI Standard PX Ń ł Ń ł ń ł U Standard DC Plug 1. EPS050100-P5P has a 9.5mm dc plug length A B 5.5 2.1 9.5 mm P11 5.5 2.5 9.5 mm EIAJ A B C D Unit P12/P12R EIAJ-1 2.35 0.7 9.5 NA mm P13/P13R EIAJ-2 4.0 1.7 9.5 5.0 mm P14/P14R EIAJ-3 4.75 1.7 9.5 5.0 mm Right Angle PXXR Ņ D Stripped and Tinned ijĶƲĶ DC PLUG TYPE stripped and tinned PXX X X Plug type Plug angle: “blank” = standard R = right angle Plug polarity: “blank” = N/A P = center positive N = center negative cui.com Unit P10 ń ST C Additional Resources: Product Page CUI Inc │ SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 04/18/2013 │ page 5 of 5 REVISION HISTORY rev. description date initial release applied new spec template 06/29/2006 1.02 removed multiple models, applied new spec template 1.03 updated P7/P7R B dimension 1.04 V-Infinity branding removed, safety and EMI/EMC data updated 08/16/2012 1.05 added 7.5V model 09/24/2012 1.06 updated P5 & P6 plug lengths ED 1.0 1.01 12/28/2010 05/26/2011 04/13/2012 U 04/18/2013 D IS C O N TI N The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
EPS120050-P7P 价格&库存
很抱歉,暂时无法提供与“EPS120050-P7P”相匹配的价格&库存,您可以联系我们找货
