MSA150012A
MSA150012A
    INVENTUSPOWER
    Open Frame AC DC Converter 1 Output 12V 12.5A 85 ~ 264 VAC Input
MSA150012A 数据手册
MSA150 Series 150 Watt Medical Open Frame Power Supply High Efficiency: Level V Up to 180W with Forced Air High Power Density 9.8W/in3 Lifetime Expectation >5 years Hold­up Time >25ms at full load EISA & CEC Compliant Floating Output Medical Approval ­ EN60601­1 Class I 3rd Edition Elpac Part Number Output Voltage Output Forced Air Total Typical Current1 Current2 Regulation3 Efficiency4 MSA150012A 12.0V 12.5A 15.0A ±5% 91% MSA150015A 15.0V 10.0A 12.0A ±5% 91% MSA150018A 18.0V 8.3A 10.0A ±5% 91% MSA150024A 24.0V 6.3A 7.5A ±5% 92% MSA150028A 28.0V 5.4A 6.4A ±5% 92% MSA150048A 48.0V 3.2A 3.75A ±5% 94% Notes 1 With convection cooling. Peak load (180W) lasting up to 500ms with a maximum 10% duty cycle. 2 Sustained output current with minimum 100 LFM 3 Includes initial setting, line regulation, load regulation, and thermal drift. 4 Typical at 115VAC. Input Input Voltage 85 ­ 264VAC 100 ­ 240VAC Nominal Input Frequency 47 ­ 63Hz Input Current
MSA150012A 价格&库存
很抱歉,暂时无法提供与“MSA150012A”相匹配的价格&库存,您可以联系我们找货
