Additional Resources:
Product Page
rev.
page
page
1 of 3
date
date
04/2010
DESCRIPTION: ac-dc converter
SERIES: FSC-S15
features
INPUT
ue
in
AC
AC
AC
AC
AC
input
voltage
85-264V / DC 110-340V
output
voltage
3.3V @ 3.0A
5V @ 3.0A
12V @ 1.3A
15V @ 1.0A
24V @ 0.65A
conditions/description
input current
AC input of 110 VAC
AC input of 220 VAC
measured at 110 VAC at full load, cold start
measured at 220 VAC at full load, cold start
measured at 110 VAC
measured at 220 VAC
leakage current
ripple & noise
max.
80 mVp-p
80 mVp-p
120 mVp-p
150 mVp-p
200 mVp-p
min
47
85
110
nom
(50~60)
max
440
264
340
0.31
0.16
30
60
0.5
0.75
units
Hz
VAC
VDC
A
A
A
A
mA
mA
min
-2%
-1%
-1%
-1%
-3%
-1%
nom
max
+2%
+1%
+1%
+1%
+3%
+1%
400
units
is
co
parameter
input frequency
input voltage
inrush current
power
max.
9.9 W
15.0 W
15.6 W
15.0 W
15.6 W
nt
model
number
FSC-S15-3R3U
FSC-S15-5U
FSC-S15-12U
FSC-S15-15U
FSC-S15-24U
d
·UL, C-UL, CB, CE marking
·encapsulated compact case
·high efficiency
·universal input
·surface mounting technology
·built in EMI filter
·inrush current limit
·67kHz fixed frequency
·fixed output voltage
·thermal shutdown
·short circuit protection
·low output ripple and noise
·isolated output
·2 year warranty
efficiency
75
75
78
78
78
D
OUTPUT
parameter
voltage tolerance
ripple and noise
line regulation
load regulation
dynamic load regulation
temperature drift
rise time
hold-up time
10
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383
ms
ms
www.v-infinity.com
Additional Resources: Product Page
rev.
page
2 of 3
date
04/2010
SERIES: FSC-S15
PROTECTION CIRCUIT
works at over 105% of the rating and recovers automatically.
145 ºC
GENERAL
NOTE:
min
-10
-20
20%
20%
nom
max
60
70
90%
90%
units
ºC
ºC
RH
RH
ue
in
non-condensing
non-condensing
applied for 1 minute, 10mA
primary to secondary, 500 Vdc @ 100 MΩ
3000
VAC
at 10G 3 minute period
10
55
Hz
50G for 11mS, once on each X, Y, Z axis
3.5 x 10 5
hours
yes
approved to UL60950(E222889), CSA C22.2 NO.60950, CB(IEC 60950), CE(EN60950)
5W, 10W single output: approved; EN61204-3 class B, EN 61000-3-3, EN 61000-3-2 (through TUV)
standard warranty length
2
years
nt
parameter
operating temp.
storage temp.
operating humid.
storage humid.
isolation voltage
(HI-POT)
vibration
impact
MTBF
RoHS
safety
EMC 1
warranty
d
parameter
output over current
over temperature
1. to meet the standard of EN61204-3 class B, use the external noise filter between L and N
D
is
co
DERATING CURVE
EXTERNAL EMI FILTER
L
L
C1
224MK P
LOAD
S MP S
N
N
LF 1
FG
+V
-V
LF 2
FG
jXGdGYYWmGVGY^\}SGYGjG
smXGdGYWoGjGtGsGmSG{GG ɐX[UW͑
smYGdGYWoGjGtGsGmSG{GG ɐX[UW͑
www.v-infinity.com
Product Page
REV.
A
DATE
9/11/2007
tin
ue
d
3.5 0.138
(4 PLCS) 0.2
DESCRIPTION
NEW DRAWING
1
7
50.8 2.000
2
5
3
40.64 1.600
(2 PLCS) 0.2
D
8.8 0.346
PC FILE NAME:
FSC-S15
SCALE: 1:2
26.0 1.024
is
c
17.5 0.689
on
81.28 3.200
(2 PLCS) 0.2
COPYRIGHT 2007 BY CUI INC.
RoHS
TOLERANCE:
±0.5mm UNLESS OTHERWISE
SPECIFIED
91.6 3.606
20050 SW 112th Ave.
Tualatin, OR 97062
Phone: 503-612-2300
800-275-4899
Fax: 503-612-2383
Website: www.cui.com
TITLE:
PIN ASSIGNMENTS
1. FG
2. AC (N)
3. AC (L)
5. +Vout
7. -Vout
REV:
AC-DC CONVERTER
PART NO.
FSC-S15
DRAWN BY:
ZRJ
A
UNITS:
MM [INCHES]
APPROVED BY:
SCALE:
1:1
很抱歉,暂时无法提供与“FSC-S15-3R3U”相匹配的价格&库存,您可以联系我们找货
