TRC-120S035DT
TRC-120S035DT
    THOMASRESEARCHPRODUCTS
    LEDDRIVERCCAC/DC20-34V3.5A
TRC-120S035DT 数据手册
TRC-120 Series–Fixed Output and Dimmable 120W Switch Mode LED Drivers Constant Current Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ 75-100% load, 100-277V Input Current: 1.50 A @ 100 Vac, 0.75 A @ 220Vac Maximum Power: 120W THD: < _ 20% @ 75-100% load, 120-277V Line Regulation: ± 1% Load Regulation: ± 3% Turn-on Time Delay: 120V: 1.2S Typical, 2.0S max 220V: 0.6S Typical, 1.2S max Output Protection: Over-Voltage, Over-Current, Over-Temperature, Output Short Circuit Protection • Total Power: 120 Watts • Input Voltage: 100-277 Vac Nom. • UL Dry & Damp Location Rated • IP67 • High Efficiency • High Power Factor with Active Correction • Output and Lightning Protection Environmental Specifications Minimum Starting Temp: -35ºC Max Case Temperature: 90ºC (DT models), 88.2ºC (350mA ST), 89.5ºC (all others) Storage Temperature: -40ºC to +85ºC Humidity: 10% to 100% Cooling: Convection Sound Rating: Class A MTBF: 250,000 Hours @ 80% load, 110Vac, 25ºC ambient conditions per MIL-HDBK-217F Lifetime: 67,000 Hours @ 220V, 80% load, Tc=60ºC Constant Current - Product Specifications Model Number Safety Certification Standard CUL UL8750, UL1012, CSA-C22.2 No. 107.1 CE EN 61347-1, EN61347-2-13 EMC Standard Notes EN 55015 Conducted emission EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations and flicker EN 61000-4-2 Electrostatic discharge EN 61000-4-3 RFE Field Susceptibility test EN 61000-4-4 Electrical Fast Transient EN 61000-4-5 Surge Immunity Test, AC Power Line: line to line 4 kV; line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Output Voltage Range (Vdc) Max. Output Power (W) Typical Efficiency 92% TRC-120S035ST 350 206-343 120 TRC-120S045ST 450 160-266 120 92% TRC-120S070ST 700 103-171 120 92% TRC-120S105ST 1050 68-114 120 91% TRC-120S140ST 1400 52-86 120 91% TRC-120S175ST 1750 41-68 120 91% TRC-120S210ST 2100 34-57 120 91% TRC-120S245ST 2450 29-49 120 91% TRC-120S280ST 2800 26-43 120 91% TRC-120S315ST 3150 23-38 120 90% TRC-120S350ST 3500 20-34 120 90% TRC-120S420ST 4200 17-28 120 90% TRC-120S490ST 4900 14-24 120 89% Output current is adjustable at the factory from 50-100% Dimming - Product Specifications Model Number E332160 Output Current (mA ±3%) Output Current (mA) Output Voltage Range (Vdc) Max. Output Power (W) Typical Efficiency TRC-120S035DT 350 206-343 120 92% TRC-120S045DT 450 160-266 120 92% 92% TRC-120S070DT 700 103-171 120 TRC-120S105DT 1050 68-114 120 91% TRC-120S140DT 1400 52-86 120 91% TRC-120S175DT 1750 41-68 120 91% TRC-120S210DT 2100 34-57 120 91% TRC-120S245DT 2450 29-49 120 91% TRC-120S280DT 2800 26-43 120 91% TRC-120S315DT 3150 23-38 120 90% TRC-120S350DT 3500 20-34 120 90% TRC-120S420DT 4200 17-28 120 90% TRC-120S490DT 4900 14-24 120 89% Typical Efficiency Full load @ 220Vac Specifications subject to change without notice. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com Rev 9-1-15 TRC-120 Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 3 Black (L) White (N) Green (GND) 210±20 45±5 35±5 25±5 Ø7.8±0.2 50±5 50±5 Yellow (10V) Purple (0-10V) Green (GND) 15±2 15±2 Output Red (+) Black (-) 230±20 36.5 650±20 36.5 Dimming 67.5 221 194 190 Input 5±1 Dimming: WIRE SPECS: AC Input: UL SJTW, 18AWG DC Output: UL STW, 18AWG Dimming Control: UL2464, 22AWG 208 205 10.5 5 Ø8.9±0.2 50 34 5 8 Ø4.2±0.2 Fixed: 221 194 190 Input Black (L) White (N) Green (GND) 36.5 Output 50±5 15±2 50±5 67.5 15±2 Ø8.9±0.2 Ø7.8±0.2 Red (+) Black (-) 230±20 36.5 650±20 208 205 WIRE SPECS: AC Input: UL SJTW, 18AWG DC Output: UL STW, 18AWG 5 10.5 50 34 5 8 0.90 45% 0.80 40% 0.70 THD 25% 120Vac 277Vac 0.30 20% 60% 70% 80% Load 90% 100% 0% 50% 60% 70% 80% Load 90% 120 105 75 100 100 80 80 30 40 50 60 70 Case Temperature (°C) 80 90 0 -35 100% 20 20 15 90% 40 40 45 80% 60 60 60 70% Normalized Output Voltage Derating Curve Load (%) 90 30 70% 60% 100% Derating Curve Lifetime / Case Temperature 135 120Vac 277Vac 75% 10% 0.10 85% 80% 15% 0.20 Lifetime (kHrs) 120Vac 277Vac 90% Load (%) PF 0.40 0 95% 30% 0.50 Typical Efficiency / Load 100% 35% 0.60 0.00 50% THD / Load 50% Efficiency Power Factor / Load 1.00 -20 -5 10 25 40 Ambient Temperature (°C) 55 70 0 90 120 150 180 210 240 Input Voltage (V) 270 300 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com 330 TRC-120 Series SSL Solutions Faster Than The Speed Of Light® Pg 3 of 3 Dimming Control Details Parameters Vcc 10V output source current Absolute maximum voltage on the 0-10V input pin Source current on 0-10V input pin Value of Rin ( the resistor inside the LED driver which locate between the 1-10V input and 10V output pin) Minimum Typical Maximum 11.8 V 14.7 V 0 mA -2 V 0 mA 12 V 15 V — — — 12.2 V 15.3 V 10 mA 12 V 0.5 mA 19.8 K 20 K 20.2 K Option 1 - DC Input Output Current / Dimming Voltage 10V Output (Yellow) Rin TRC-120SxxxxDT 1-10V Input (Purple) 1-10Vdc V Dim (Green) Normalized Output Current Vcc 100% 80% 60% 40% 20% 0% 0 2 Option 2 - External Resistor 1-10V Input (Purple) Rx Dim (Green) Option 3 - External Resistor Vcc 8 10 100% 80% 60% 40% 20% 0% 0 10 20 30 Rx (kΩ) 40 50 100% 10V Output (Yellow) Rin 6 Vdim (V) Output Current / Rx (Vcc=15V) Normalized Output Current TRC-120SxxxxDT Normalized Output Current 10V Output (Yellow) Rin 4 Output Current / Rx (Vcc=12V) Vcc Notes For 4900mA For Other models 1-10V Input (Purple) TRC-120SxxxxDT Rx Dim (Green) 80% 60% 40% 20% 0% 0 6 12 18 Rx (kΩ) 24 30 Notes: 1. If the dimming function is not used, the dimming leads should be floated. 2. Io is actual output current and Ir is rated current without dimming control. 3. For the driver to operate properly, the load voltage must be maintained above the minimum voltage threshold (approx. 50% of the max. output voltage for any given model). 4. If the output voltage is maintained above 50% of the maximum output voltage, the dimming control may be operated over the entire 1-10V range with output current varying from 100% down to practically 10%. 5. The dimming signal is allowed to be less than 1V, however, when it for 0-1V, the output current can maintain about 10%Ir. When it for 8.5-10V, the output current can maintain about 100%Ir. 6. Do not connect the GND of dimming to the output; otherwise, the LED driver cannot work normally. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TRC-120S035DT 价格&库存
很抱歉,暂时无法提供与“TRC-120S035DT”相匹配的价格&库存,您可以联系我们找货
