TSC-75W Series
Dimmable LED Drivers
Constant Current
Aluminum Housing
Electrical Specifications
Input Voltage Range:
277 - 480 Nom. Vac (249 - 528 V Min/Max)
Frequency:
50/60 Hz Nom. (47-63 Hz Min/Max)
Power Factor:
>0.90 @ full load, 277V through 480V
Inrush Current:
135.0 Amps max @ 480 Vac, cold start 25ºC
Input AC Current:
0.34 A max 277VAC, 0.21 A max 480Vac
Maximum Power:
75W
Line Regulation:
± 1%
Load Regulation:
± 3%
THD:
_ 20% @ full load
Leakage Current:
0.7 mA 480 Vac 50Hz
Typical Efficiency
85-87% at 480Vac
Turn-on Delay:
1 S typical
Output Current Ripple:
20%
Output Protection:
Over-Voltage, Over-Temperature,
and Short Circuit Protection
Environmental Specifications
Minimum Starting Temp:
-40ºC
Maximum Case Temp.
90°C
Storage Temperature:
-40ºC to +85ºC
Humidity:
5% to 100%
Cooling:
Convection
Sound Rating:
Class A
MTBF:
380,000 Hours (700 mA model) at 480Vac input, 80%
load and 25ºC ambient conditions per MIL-HDBK-217F
Lifetime:
50,000 Hours @ Case Temperature = 60ºC
Weight:
2.2 lbs. (1.0 kg)
• Total Power: 75 Watts
• Input Voltage: 277-480 Vac Nom.
• UL Dry, Damp & Wet Location Rated
• IP67
• High Power Factor
• UL Type HL Rated
* UL8750
Constant Current - Product Specifications
Model Number
Output Current Output Voltage
(mA ±5%)
Range (Vdc)
Max. Output
Power (W)
Typical
Efficiency
TSC-075S035ST
350
107-214
75
87%
TSC-075S070ST
700
53-107
75
86%
TSC-075S105ST
1050
36-72
75
87%
TSC-075S140ST
1400
26-53
75
87%
TSC-075S210ST
2100
18-36
75
86%
TSC-075S315ST
3150
12-24
75
85%
Dimming Versions - Product Specifications
Model Number
E332160
(mA ±5%)
Range (Vdc)
Max. Output
Power (W)
Typical
Efficiency
TSC-075S035DT
350
107-214
75
87%
TSC-075S070DT
700
53-107
75
86%
TSC-075S105DT
1050
36-72
75
87%
TSC-075S140DT
1400
26-53
75
87%
TSC-075S210DT
2100
18-36
75
86%
TSC-075S315DT
3150
12-24
75
85%
US/Canada
US Only
The output current is adjustable at factory from 50% to 100%.
Class 2:
Note:
LED drivers are designed and intended to operate LED loads only.
Non-LED loading may be outside the specified design limits of our
LED drivers, and therefore cannot be covered by any warranty.
If you desire to use our LED drivers to operate non-LED loads
please contact us to discuss compatibility.
Specifications subject to change without notice.
Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
Rev 6-6-16
TSC 75W Series
SSL Solutions Faster Than The Speed Of Light®
Pg 2 of 3
Dimensions - mm
50±5
15±2
220±20
70
Black (ACL)
White (ACN)
Green (GND)
Red (V+)
Blue (V-)
88.9
AC INPUT (3*AWG18)
38.1
15
DC OUPUT (2*AWG18)
Tc = 90°C max
230±20
115
12
650±20
30±2
40±2
50±2
5±1
15±2
50±5
86
222
188
184
Dimming Control (3*AWG22)
Purple (Dim+)
Gray (Dim-)
Black/White (VC)
45
202
45
4.4
Ø9.5
Derating Curve
100
120
Lifetime (kHrs)
105
Load (%)
80
60
40
Lifetime / Case Temperature
135
90
75
60
45
30
15
-10
40
50
Ambient Temperature (°C)
60
70
30 35 40 45 50 55 60 65 70 75 80 85 90
Case Temperature (°C)
Efficiency / Load
Power Factor / Output Voltage
1.00
0.95
90%
Efficiency
0.90
0.85
PF
350mA Model
95%
0.80
0.75
277 Vac
480 Vac
0.70
0.65
0.60
50%
60%
70%
80%
90%
Normalized Output Voltage
85%
80%
277 Vac
480 Vac
75%
100%
70%
50%
60%
70%
80%
Load
90%
100%
TSC 75W Series
Pg 3 of 3
Dimming Control
Parameters
12V output voltage
Vc source current
Absolute maximum voltage on the 0~10V input pin
Source current on 0~10V input pin
Minimum
Typical
Maximum
10.8 V
10 mA
-2 V
150 µA
12 V
15 mA
200 µA
13.2 V
20 mA
15 V
250 µA
The dimmer control is operated from an input signal of 1 – 10 Vdc.
V+ (Red)
Vac
L
V- (Blue)
N
Vc (Black/White)
TSC-75xxxDT
G
Output Current/Dimming Voltage
100%
Dim+ (Purple)
Dim- & Vc Return
(Gray)
Normalized Output Current
Implementation with 0-10V Dimming
0-10V
Dimmer
80%
60%
40%
20%
0%
2
3
4
5
6
7
Dimming Voltage (V)
8
9
10
Notes:
1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener.
2. The dimming signal is allowed to be less than 1V, when it is between 0 and 1V, the output level is 10%.
3. Do NOT connect the Gray Wire (Vdim-) to Blue Wire (V-) together.
4. The dimming section is not isolated from the output.
5. Vc is an auxillary 12V/15mA output.
6. If 0-10V dimming is not used, Dim+ can be either capped-off or connected to Vc.
Safety
Certification
Standard
UL/CUL
CE
UL8750, UL1310, UL1012, CAN/CSA-C22.2 No. 223-M91, CSA-C22.2 No. 107.1-01
EN 61347-1, EN61347-2-13
EMC Standard
Notes
EN 55015
EN 61000-3-2
EN 61000-3-3
EN 61000-4-2
EN 61000-4-3
EN 61000-4-4
EN 61000-4-5
EN 61000-4-6
EN 61000-4-8
EN 61000-4-11
EN 61547
Conducted emission Test & Radiated emission Test with 6 dB margin
Harmonic current emissions: Class C
Voltage fluctuations & flicker
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge Level 3, Criteria A
Radio-Frequency Electromagnetic Field Susceptibility Test-RS Level 3, Criteria A
Electrical Fast Transient / Burst-EFT Level 3, Criteria A
Surge Immunity Test: AC Power Line: line to line 4kV, line to earth 6 kV
Conducted Radio Frequency Disturbances Test-CS Level 3, Criteria A
Power Frequency Magnetic Field Test 3A/m , Criteria A
Voltage Dips Criteria B
Electromagnetic Immunity Requirements Applies To Lighting Equipment
Note:
Disconnect power to LED driver for at least 30 seconds before connecting or disconnecting Driver output and LED Engine. This prevents potential arcing transients
that can damage the Engine and Driver. See Hot Plugging in our Driver Application Guide for more information.
很抱歉,暂时无法提供与“TSC-075S070DT”相匹配的价格&库存,您可以联系我们找货
