LED Power Supplies
200W
LED Power Supply
Constant Voltage Power Supplies
LED POWER
next generation power
source
FEATURES
• High Efficiency 93%
• IP67 Waterproof
• Active PFC (Typical 0.97)
• OVP, SCP, OTP
• -35 to 70°C deg operation
• Universal Input 90-264VAC
• UL8750 recognised
• EN61347-1, -2-13 compliant
The LXV200 series of constant voltage LED power supplies from
Excelsys Technologies can deliver up to 200W of output power in an
extremely compact package size.
LED Power
200W
LXV200 series
The LXV200 series of constant voltage power supplies provides a range of
output voltage solutions for specific LED requirements. With industry leading
efficiencies, and an extensive protection feature set, the LXV200 series
provides high reliability and high performance in a compact package
The LXV200 series carries the CE mark for safety and is also RoHS
compliant. For more details contact sales@excelsys.com
Model
Number
Output
Voltage
Output
Current
Input
Voltage
OVP
Max
OCP
Hiccup
Efficiency
LXV200-012S
LXV200-024S
LXV200-036S
LXV200-042S
LXV200-048S
LXV200-050S
LXV200-052S
LXV200-054S
LXV200-081S
LXV200-105S
12V
24V
36V
42V
48V
50V
52V
54V
81V
105V
14.6A
8.33A
5.56A
4.76A
4.17A
4.00A
3.84A
3.70A
2.47A
1.90A
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
90-264VAC(3)
18V
36V
54V
63V
72V
75V
78V
81V
122V
158V
120-170%
120-170%
120-170%
120-170%
120-170%
120-170%
120-170%
120-170%
120-170%
120-170%
92.0%
92.0%
92.5%
92.5%
92.5%
92.5%
93.0%
93.0%
93.0%
93.0%
Input Specifications
Parameter
Input Voltage Range
Input Frequency Range
Input Current
Inrush Current
Power Factor
Conditions/Description
Universal Input. see Note 3
Min
90
47
100VAC in, 200W output
230VAC in, 25°C, Cold Start
220VAC, 110VAC
0.97
Min
Nom
Max
264/305
63
2.3
65
0.99
Units
VAC
Hz
A
A
Output Specifications
Parameter
Line Regulation
Load Regulation
Voltage Accuracy
Ripple and Noise
Dynamic Response
Overshoot
Turn-on Delay
Short Circuit Protection
Over Voltage Protection
OverTemperature Protection
Nom
% of Vout
20MHz Bandwidth. See Note 1
Output Deviation R/S : 1 A /uS
Settling Time Load : 25% ~ 75% full Load
Measured at 220VAC and full load
Auto Recovery
Latching. See individual models OVP levels
Internal Component Temperature
Max
±1
±2
±5
2.0
5
10
10
3
Units
% pk-pk
mS
s
110
°C
General Specifications
Parameter
Isolation Voltage
Efficiency
Safety Agency Approvals
No load Power Dissipation
MTBF
Lifetime
Weight
Operating Temperature
Storage Temperature
Relative Humidity
Power Derating
Note 1.
Note 2.
Note 3.
Input to Output
See Note 2
Input to Chassis
UL8750, EN61347-1, -2-13 pending
Measured at 120VAC and 220VAC
MIL HDBK-217F, 110VAC input, 80% load, 25°C
220VAC input, 80% load, 45°C
Min
3750
1500
Nom
Max
Units
VAC
VAC
2.0
W
Hours
Hours
g
°C
°C
93.0
247,000
55,000
1000
-35
-40
Non-condensing (operating)
10
At 100 VAC, derates linearly from 100% at 60°C to 80% at 70 °C
+70
+85
100
1
Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor.
Primary to Secondary Isolation test not to be carried on power supply.
90-305VAC input voltage range available. Add Suffix “W” to part number e.g. LXV200-012SW
Europe/Asia
Excelsys Technologies Ltd
27 Eastgate Drive
Eastgate Business Park
Little Island, Cork, Ireland
IRELAND
t: +353 21 4354716
f: +353 21 4354864
e: sales@excelsys.com
North America
519 Interstate 30, #309
Rockwall, TX 75087
USA
t: (972) 771 4544
f: (972) 421 1805
e: salesusa@excelsys.com
LED Power Supplies
200W
EMC
LED Power
200W
Parameter
Emissions
Conducted
Radiated
Harmonic Distortion
Flicker and Fluctuation
Immunity
ESD
Radiated RFI
Fast Transients - burst
Input Line Surges
Conducted RFI
Power Freq Magnetic Field
Voltage Dips
Standard
Level
EN55015
EN55015
EN61000-3-2
EN61000-3-3
Level B
Level B
Compliant
Compliant
EN61000-4-2
EN61000-4-3
EN61000-4-4
EN61000-4-5
EN61000-4-6
EN61000-4-8
EN61000-4-11
Level 4
Level 3
Level 4
Level 4
Compliant
Compliant
Compliant
Units
INPUT / OUTPUT WIRING
INPUT CABLE
SJTW 18AWG 2C
Black (L) and White(N), Green (Earth) 650±20mm
OUTPUT CABLE
SJTW 18AWG 2C
Black (-V) and Red (+V) 220±20mm
MECHANICAL SPECIFICATIONS
226 ± 0.5
199 ± 0.5
195 ± 0.5
67.5
67.5
40
15±0.5
50 ± 2
50 ± 2
650 ± 20
15±0.5
40
220 ± 20
50
10.5
34
5
8
5
209 ± 0.5
213 ± 0.5
50
10.5
LXV200-012S model
34
5
8
2
209 ± 0.5
213 ± 0.5
All Tolerances ± 0.2mm unless specified
Specifications are subject to change without notice
LXV200 Datasheet 27 April 2011
Europe/Asia
27 Eastgate Drive
IRELAND
North America
t: +353 21 4354716
f: +353 21 4354864
e: sales@excelsys.com Rockwall, TX 75087
USA
t: (972) 771 4544
f: (972) 421 1805
很抱歉,暂时无法提供与“LXV200-081SW”相匹配的价格&库存,您可以联系我们找货
