AS-Interface
DC/DC converter with 4A
SLAD4.100
Data sheet
EMC and
Low Volt.
Directive
Input: DC 24V
Output: 30.55V / 4A
AS Interface data decoupling
For highly demanding industrial
applications
Short description
The primary switched mode DIN rail DC/DC converter SLAD4.100 specif®
ically supplies AS Interface systems with energy. The AS-Interface bus
technology allows to connect up to 62 participants to a control and to
supply them with energy with a single two-conductor cable.
When connecting slaves, the yellow AS-Interface cable offers the high
degree of protection IP67 in conjunction with the insulation displacement. The communication signals of the individual network participants
are modulated onto the supply voltage. For this purpose, specific DC/DC
converter units with integrated
data decoupling are required for AS-Interface systems.
Output
Input
Rated voltage
DC 24V
Rated voltage
DC 30.55V +/- 3% ( not adjustable )
Input voltage range
18.0-32.4Vdc Continuous operation
See Fig.2
14.0-18.0Vdc max. 60 seconds or with derating
max. 36.0 Vdc Absolute maximum continuous
input voltage with no damage to the DC/DC
converter.
Rated current
4A
Input / output
separation
SELV IEC / EN 60950-1
Allowed voltage be- max. 60Vdc or 42.4Vac
tween input and earth
(ground)
Allowed input ripple max. 5Vpp, 47Hz-40kHz, the momentary input
voltage
voltage must always be within the specified
limits.
Turn-on voltage
typ. 17.5Vdc Steady-state value
Reverse input polarity Included, unit does not start when input
protection
voltage is reversed
Shut down voltage
typ. 14.0Vdc Steady-state value
typ. 35Vdc Steady-state value
Input current
typ. 5.6A at 24Vdc input and output 30.55V, 4A
Inrush current
Max. 1.8A peak at -25°C up to +70°C
Inrush energy
Typ. < 1A2s at -25°C up to +70°C
Start-up delay
typ. 650ms
Rise time
typ. 100ms constant current load 4A
typ. 200ms constant current load 4A with
external 5mF capacitor
Integrated internal
fuse
T10A HBC ( not accessible)
PELV IEC 60364-4-41, EN 60204-1, IEC 62103
Double or reinforced insulation,
Max. allowed voltage between any input pin
and ground: 60Vdc or 42.4Vac
Current limitation
> 4.4A
Overload behaviour
Continous current, see Fig. 3
Short-circuit current
min. 5A , max. 9A
Load regulation
< 250mV Static value, 0A 4A 0A
Line regulation
< 5mV Input variations between 18 to 32.4Vdc
Ripple
< 50mVpp ( 500kHz bandwith, 50 Ohm measurement, ohmic load)
Noise (spikes)
< 100mVpp ( 20Hz to 20MHz bandwith, 50
Over-voltage
protection
Max. 36V
Operating indicator
Green LED (extinguishes at overload)
Output is protected against short-circuit, open circuit and overload.
Use AS-Interface DC/DC converters only together with AS-Interface
lines.
External capacitors on the input voltage bus are allowed without any
limitations.
Order information
slad4e100 / 071026
Order number
Description
SLAD4.100
SLZ10
ZM1.Wall
ZM11.SIDE
DIN-Rail bracket for S7-300 Simatic-Rail
Wall mounting bracket
Side mounting bracket
1/4
Data sheet
SLAD4.100
Efficiency, Reliability
Electromagnetic Compatibility (EMC)
Efficiency typ.
Emissions
EN 61000-6-3 (also includes EN 61000-6-4)
Class B (EN 55011, EN 55022)
Immunity
EN 61000-6-2 (also includes EN 61000-6-1)
Operating and environmental data
Electrostatic
Discharge
EN 61000-4-2
Non-operating
temperature range
-40°C up to +85°C
Electromagnetic EN 61000-4-3 80MHz-2.7GHz
RF fields
10V/m Criterion A
Operating
temperature range
-25°C up to +70°C
(measured at 25mm below the unit)
Fast transients
(Burst)
4kV
2kV
Derating
from 60°C 3W/K onwards,
power reduction necessary, see Fig. 6
1kV
Surge voltage on EN 61000-4-5 + + / - chassis ground2kV
input
Cooling
natural convection,
no forced air-cooling necessary
500V Criterion A
Surge voltage on EN 61000-4-5 + + / - chassis ground500V Criterion A
output
Over-temperature
protection
Yes, output shutdown with automatic
restart
Conducted
disturbance
Humidity
protect from moisture and condensation
Criterions:
Vibration sinusodial
2-17.8Hz: ±1.6mm; 17.8-500Hz: 2g;
2 hours / axis;
IEC 60068-2-6
A: DC/DC converter shows normal operation behavior within the defined limits.
C: Temporary loss of function is possible. DC/DC converter might shut-down and
restarts by itself. No damage or hazards will occur to the DC/DC converter.
Shock
30g 6ms, 20g 11ms 3 bumps / direction,
18 bumps in total;
IEC 60068-2-27
Degree of pollution
2 ( EN 60950-1)
Overvoltage category
II ( IEC 60950-1)
III ( IEC 62103)
90.5% (input 24Vdc, output 4A) , see Fig. 4
Power dissipation typ. 12.7W (input 24Vdc, output 4A), see Fig. 5
EN 61000-4-4
EN 61000-4-6
Contact discharge
Air discharge
Input lines
Output lines
0,15-80MHz
Criterion A
8kV
15kV Criterion A
10V
Criterion A
Criterion A
Criterion A
Criterion A
Criterion A
Schematic
Fig.1
AS-i ok
(green)
Input Fuse
Input Filter
Reverse
Polarity
Protection
Inrush
Limiter
AS-i +
Power
Converter
2/4
AS-i
Decoupling
Unit
AS-i +
Shield
AS-i AS-i -
Chassis
Ground
OverTemperature
Protection
Output
Filter
Output
OverVoltage
Protection
slad4e100 / 071026
SLAD4.100
Data sheet
Operating indicators and elements
Plastic slider:
• Mounting: Place the unit onto the DIN-rail and push it downwards and against the lower front edge until it snaps into place.
• Detachment: Push downwards and detach the unit from its DINrail mounting bracket.
Plastic slider
Machine ground
connection
Output terminals:
Dual terminals for
AS-Interface + and
AS-Interface –
Green LED:
ON: AS-Interface voltage is
within the limits.
OFF: at overload or
missing input voltage
DIN-rail mouting bracket
Input terminals
Connectors and terminals
Terminals
Fingertouch-proof terminals with captive
screws for 5.5 mm slotted screwdriver or Philips
cross-recessed screwdriver No. 2
Position
Easy to reach terminals on the front panel;
Input and output clearly separate from each
other
Construction / Mechanics
Housing
Robust metal housing for built-in installation
Degree of protection
IP20 (EN 60529)
Class of protection
1 (IEC 60536)
Width w
Height h
Depth d
40mm
124mm
102mm (without DIN rail)
Appr. 500g
Tightening torque
0.8 Nm
Wire gauge
• flexible cable
• solid cable
0.5-4mm2 (20-10AWG)
0.5-6mm2 (20-10AWG)
Weight
Ferrules
Admissible
Installation notes
Stripping length
7mm
Front elements
Input DC 24V
+ Input
- Input
Chassis Ground Ground this terminal to minimize high-frequency
emissions.
Output DC 30.5V /4A
brown
Positive AS-Interface output voltage (twice)
blue
Negative AS-Interface output voltage (twice)
Shield
External fusing
Not necessary (internal fuse)
Mounting position
Vertical; input below, output above
Free space for
cooling
Above / below 25mm recommended
Left / right 15mm recommended
Operation without AS-Interface:
This AS-Interface DC/DC converter has an inductive output. When operating without AS-Interface structure (e.g. in a laboratory test) you
should connect a 470µF / 35V capacitor between AS-Interface + and ASInterface - as commercial electronic loads in combination with the data
decoupling often tend to oscillate, and the oscillation may exceed the
permitted modulation voltage.
Otherwise, equipment may be destroyed.
Connection of machine ground.
Functional earth for balancing the AS-Interface output. Connection is recommended for EMC purpose
slad4e100 / 071026
3/4
SLAD4.100
Data sheet
Functional diagrams
Fig. 2 Start behaviour
Fig. 3 Output characteristic
Output Voltage
35V
Rated input range
POUT
30
Turn-on
Shut-down
25
15
32.4Vdc
35.0Vdc
17.5Vdc
18.0Vdc
14.0Vdc
VIN
10
5
Output Current
Fig. 4 Efficiency
1
2
3
4
5
6
7
8
9A
Fig. 5 Losses
Efficiency
Power Losses
91%
18W
90
15
89
12
88
9
87
6
86
3
Output Current
85
0.5
1
1.5
2
2.5
Output Current
4.5
4A
2
3
4A
Fig. 6 Derating
Allowable Output
4A
3
2
1
Ambient Temperature
60 70°C
Unless otherwise stated, specifications are valid for DC 24V input voltage, +25°C ambient temperature, and 5 min. run-in time. They are subject to change without prior notice.
Your partner in power supply:
European
Power Supply
Manufacturers
Association
Bayerns Best 50
Czech 100 Best
Europe’s 500
PULS GmbH
Arabellastraße 15
D-81925 München
Tel.: +49 89 9278-0
Fax: +49 89 9278-199
www.puls-power.com
4/4
slad4e100 / 071026
很抱歉,暂时无法提供与“SLAD4.100”相匹配的价格&库存,您可以联系我们找货
